Pics on Vortex as a pain to load on here:
https://www.vwvortex.com/threads/fs-...post-116584280
For Sale: Batch #1
(Serious enquires only)
1) 440cc Bosch Green Tops $130
2) Brand new ceramic coated Unorthodox ultra light crank pulley: $100
3) Billet divertor valve with horn/trumpet (so louder) with oem dump hose $60
4) New: Billet divertor valve with spring kit $65
5) AEM silicone 3" cold air intake, heat sheild, cone filter dressing, adapter ring included if running a smaller maf housing: $100
6) New: Roll of titanium 2" heat wrap: Add $15
For Sale: Batch #2 (OEMish)
1) Two new subframe motor/trans mounts:$30
2) Reconditioned starter sheild $30
3) Radiator side shrouds: $45
4) Reconditioned, ceramic coated show dbc tb: $100
5) Reconditioned, enimal coated metal timing cover: $ 30
6) Reconditioned oil coolers with low mileage o-rings: $30 each
For Sale: Batch #3 (Serious Mods)
Serious enquires only...you guys grill me 30 questions then ghost me, if not interested then not interested but my phone blows up...
1) Custom under the intake manifold stealth coolant pipe conversion. This runs the hoses/pipes under the intake so if you ever work on your car you never have to lose coolant and cleans up the . I only made so many of these and this is the very last one. $250
2) Add custom aluminum reservoir for $100 (or use your oem one).
3) Custom made one of a kind IE fuel rail: Ceramic coated, one end blocked off, all AN fittings with fuel gauge, BMM billet fuel pressure regulator holder, all metal 034 Motorsport adjustable fpr (believe it's 034), 6AN fuel fittings: Clean up your engine bay as you won't have another fuel line coming off the other end of the rail, called a dead head set up...both fuel lines come from one side of the rail. $270
4) VB high capacity aluminum radiator with high performance 12" SPAL curved blade fans:
Pulled from my showcar, never abused or raced. Has the highest capacity fans possible that can fit, extra measures have been taken to uniformly fit 2 12" fans side by side which you normally can not do. SPAL curved blade, with 30% more flow than straight blade, with a Hayden fan controller, very easy hook up, with oem AC fan operation via one wire if needed. Comes with water proof adjustable fan controller: $850
For Sale: Batch #4 (custom fueling)
1) Oem pump with oem basket: $85
2) OEM newish filter with oem mount: $40
3) Newish billet fuel filter: $25
4) ~750 HP performance drop in pump with high output specifically made relay, oem sender, seals, basket, cage, cap, wiring: $140
5) ~1500hp dual billet pump, dual fuel filter, dual relay, 5 gallon tank (140 mile range), AN fittings, on carbon fiber board, tank breather, oem harness to piggy back off the oem stock plug, to make it work. $350
For Sale: Batch #5 (Serious mods)
1) FMIC custom intercooler spray bars: Spray distilled water or wiper fluild. Take a casual drive and try touching the fins of your IC, it'll be so hot you may end up with 1st degree burns. This will cool everything off and allow the IC to do it's job without heat soak. Many varieties to choose from: $140
2) Dual fluid tanks with custom drop in plate (for those who have smoothed out your wheel well). Or, simply set the the entire assembly in your trunk ontop of your carpet like a speaker box. $200
3) $1300 APR stainless 2.5" Fronttrak catback exhaust: $650
All prices plus shipping, yet only charge what USPS Flat Rate does.
