Results 1 to 3 of 3
    Junior Member Two Rings
    Mar 01 2024
    Boulder Colorado
    Getting new wheels but I don’t know what specs to decide on (long question)
    right now I am on the Kansei KNPs. They are 18/8.5 + 35 with a 12 mil spacer. As a kid buying his first set of wheels I wasn’t even thinking about them clearing the brake calipers (17z front and rear) just figured “hey OEM offset should be fine with a spacer” and with both of those I have maybe a few mills of clearance on my calipers.
    The point is…
    I want to buy TE37s but now that I’ve bought a set of wheels once and it worked by chance of luck, clearance issues are on my mind and wondering what you guys would recommend. As said I’m on 18/8.5 but want to go to 19/8.5 or maybe 19/9. My fitment is very tight in the back (can’t fit my fingers) So I’m asking what you guys think I should do because I want to go with a overall larger wheel but I want them to fit the first time regarding caliper and wheel well clearance (don’t want to be driving on my body panels).
    So should I keep the specs and just up the size, consider not running spacers changing spacer size, offset etc…
    Also I know if I go 9” wide I’m probably gonna ditch the spacer but if I want to keep it I don’t know what offset to go with
    Thanks in advance
    Mar 01 2024
    Boulder Colorado
    Nobody replied but just in case I figured it out so don’t bother
    May 10 2018
    MA
    The short answer is, it really depends.
    There are multiple types of TE37. None are 19x9 in 5x112, and of the 4 types of TE's that are 19 and 5x112, only 2 of them offer width/offset that would even work on a standard body car in the first place, without spacers. Both are either 19x8.5 +38, or 19x8.5 +22. +22 isn't going to come close to working up front on an narrow body car unless you're rolling/pulling fenders, making custom fender liners, and have a way to dial in some camber. Even out back, 8.5 +22 is going to be close. This is assuming you're using a tire that fits the wheel, and not stretching something narrow. 8.5 +22 would work on a widebody/RS4, albeit a bit weak of a fitment.
    The diameter of the wheel has the least amount to do with it.
