Reduce flow restriction and enhance supercharger sounds and performance with the 034Motorsport High Flow Throttle Body Intake Hose for the 4M Audi Q7 3.0 TFSI! This upgraded intake hose is designed to replace the restrictive corrugated plastic unit and integrated intake silencer and features a larger cross-sectional area and smooth insides for higher flow and increased performance. This durable, high-quality silicone hose was modeled directly off of the factory part to ensure perfect fit and finish and extensively tested at 034Motorsport with the help of independent Audi enthusiasts. In addition to cloth reinforcement, this hose features stainless steel wire reinforcement to prevent collapse under vacuum.
Features:
- Wire-Reinforced Multi-Ply Silicone Construction - Gloss Black
- Maintains Smooth Inside Surface for Optimum Flow
- Eliminates Restrictive Factory Intake Muffler for Increased Induction and Supercharger Whine Sounds, as well as Improved Performance
- 24.6% Increase in Flow Over OE (Hose, Throttle Body and Filter Assembly):
- OE: 447.9 CFM
- 034: 558.0 CFM
- Noticeable Top-End Horsepower & Torque Gains
- Plastic Breather Tube Connection Nipple
- Direct Drop-In Replacement of Factory Hose
CFM Comparison Chart:
Part Number Interchange:
- 06E 129 616 D
- 06E 129 616 C
What’s Included:
- 1x) Wire-Reinforced Multi-Ply Silicone Hose
- 2x) Hose Clamps
- 1x) Barbed Fitting
Click Here to Learn More!
