Results 1 to 15 of 15
    Apr 20 2025
    Pa
    4.0t replace/update
    After some long searching I have finally become the owner of an 2018 S6. The car has a blown motor (stage 3 build) that I knew when I purchased it. My plan is to replace the engine with a used one and I would like recommendations as to what items or systems need attention on this motor when replacing? Timing Chains, fuel injectors, valve seals, ?? I’m new to this engine platform but not new to engine rebuilding.
    Veteran Member Four Rings SteveKen's Avatar
    Jan 11 2005
    Pittsburgh, PA
    Quote Originally Posted by PaS6 View Post
    I did something similar last year by swapping a long block.
    I kept my chains but replaced the tensioners and guides.
    Also remove the intakes and inspect the valves for carbon and have them cleaned if needed.
    Also have the injectors serviced since it's really hard to do when the engine is installed.
    Water Pump, turbo oil screens and PCV are easy to do and not too expensive as preventive maintenance while the engine is out.
    Steve
    2013 S6 • 2012 Q7 TDI S-line • 2010 GTI • 2001 Honda S2000 • 1977 Honda CB750 F2 • 1965 GMC 1500 WideSide
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    All good advice. I'd definitely make sure to get the valves cleaned and the injectors serviced before reassembly.
    Oh, do you know why the engine blew up? I'd figure out the cause of that too so you don't have a repeat.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Apr 20 2025
    Pa
    Thanks for the insight and recommendations. Most of your suggestions are things that had considered. Was there a particular reason you changed guides? Are they noted for failure? As to the valve carbon, is walnut blasting sufficient or is head removal and disassembling recommended?
    Apr 20 2025
    Pa
    Valve cleaning and injector cleaning/testing in the plan. As to the blow up, I haven’t disassembled anything yet but the bore scope inspection was ugly. Looks to be a 1/4” by 1” hole at the top of the bore into the water jacket . I suspect lean, piston, ring failure and then continued operation under boost until the cylinder wall gave way?? One indication why the injection cleaning and testing is in the plan also. Do you guys have any injection shops that you have used and would recommend?
    Feb 22 2021
    San Antonio
    Yep, just walnut blast it, no need to disassemble.
    Maybe run WMI or Port injection to keep em clean.
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    Why wouldn't you refresh ALL the chains and guides while you have the motor out? Is their proof that it's been done on the donor recently?
    I make it a policy to replace RMS's and any unaccessible parts (chains, seals, etc...) that are buried while I have them out. I can't imagine swapping a motor, not refreshing the chains and 6mo later having a death rattle or leaky seal/o-ring requiring the motor to come out again.
    With the motor out, it's not really all that much work and after seeing the condition of several low and high mileage V6 motors guides, I'd never pass on the chance on anything with rear chains. I just pulled my 4.0t pan, and even with fully documented dealer maintenance @ 130k there were guide chips in it, so I'm already planning a 150k refresh!
    To each their own, but I buy once, cry once and hate doing a job twice!
    Cheers,
    KS
    Active Member One Ring markc34's Avatar
    Mar 16 2025
    Texas - SA
    Quote Originally Posted by Burkeomatic View Post
    (Sorry Quick hijack here) - Just bought a C7.5 'stage 4+' with port injection, but not 'activated/tuned', 60k miles. Would you think I'd need to have it walnut blasted before finishing that portion of the build? I'm in SA as well.
    Jul 26 2018
    Humidity, NC
    Quote Originally Posted by markc34 View Post
    WMI can reduce the build up depending on it's composition. It might simply stop the new build-up, meaning a blasting would be needed.
    There's no way to tell. I have had 2.0s on WMI self clean and not. No telling!
    Cheers,
    KS
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    with port, if it was running it then no you dont need to walnut blast
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Mar 16 2025
    Texas - SA
    Quote Originally Posted by Audibellybutton View Post
    60k miles no PI, now has PI. Maybe I’ll start a thread. As I know there are some guys here that may have added PI without cleaning first. But I know it’s a case by case basis, probably should wait until I need some other major service and blast it then and start the PI…
    Jun 28 2019
    California
    Nobody is walnut blasting these. That doesnt mean they dont get carbon build up, but it is not as big of an issue as previous engines. I am running water/methanol for the last 30k miles, I did not do any cleaning prior and my valves are nearly spotless the last time I had the car apart. Port is not the same as WMI, but assuming you are running ethanol, your valves should be pretty clean after term use
    IG:@stolens6
    Mar 16 2025
    Texas - SA
    Thanks for the input!
    2018 S6 DS1 Tuned • SRM TCU • TurboSystems TS1 Turbos • TGK Wastegate • 034 Intercooler / Heat Exchanger • JHM Oil Line and Strainer Relocation • SRM Flex Fuel Sensor • Autotech Fuel Pump HPFP • KYLE LPFP dual pumps • KYLE Supplemental Port Fuel • HPA catted downpipes • APR Catback • SRM Level 2 clutch pack • Eurocode Endlink / Swaybars
    Apr 20 2025
    Pa
    Thanks everyone for your input and suggestions. Donor engine on the engine stand now. Will be assessing and disassembling in the near future. Quick question. What is the reason for the aluminum bolts mating the engine to trans? Can they be replaced with steel 10.9 bolts?
    Jul 26 2018
    Humidity, NC
    Weight savings mostly but there is also the possibility of galvanic corrosion occurring with steel hardware.
    There's no real reason to upgrade them. It's not a weak link in the system or guys with 3x the power of stock motor would be addressing it.
    Cheers,
    KS
