Results 1 to 9 of 9
    Aug 18 2019
    Utah
    B6 A4 Performance Parts
    *Updated List*
    Clearing out the garage. All parts are new and never installed unless noted. If you see something you need or want, give me an offer. Everything is best offer. You can package parts together for a discount. Looking to move things quickly. Parts are as follows:
    -eBay GT2871R Journal Bearing Turbo $100
    -Engine gasket set $100
    -Maxpeeding Forged H beam rods, 19mm wristpin, ARP bolts $550
    -Wiseco forged pistons, 19mm wristpin $700
    -Vent mount duel gauge pod 52mm $50
    -Prosport boost gauge 52mm $85
    -Prosport wideband air and fuel gauge kit 52mm $200
    -ARP head stud kit $250
    -ECS Tuning RA4 flywheel, machined for a B7 RS4 clutch $400
    -RS4 clutch kit, comes with pilot bearing, throw out bearing, hardware $170
    -Oil pump, chain, and tensioner $125
    -Timing belt kit, comes with tensioner, tensioner pulley, water pump $230
    -Bosch 550cc injectors with harness adapters $450
    -CX Racing aluminum cold air intake with heat shield $250
    -Stainless steel turbo exhaust adapter, goes from turbo to a v band $30
    -Aluminum injector cups $50
    -AEM ethanol 340LPH fuel pump kit with an 034 motorsports billet adapter $230
    -B6 S4 front and rear rotors with pads, drilled and slotted, black zinc coating $450
    -Used FSI crank for stroker build for manual transmission $350
    -B6 S4 stainless braided brake lines front and rear, ECS Tuning brand $140
    I can add more photos upon request since I'm limited to how many I can upload here.
    Thanks for looking.
    Aug 18 2019
    Utah
    More pictures
    Mar 12 2013
    Houston, Texas
    Can you throw up a pic of the steering wheel?
    Sep 10 2021
    Pennsylvania
    DM sent. Let me know what you think.
    Aug 18 2019
    Utah
    Quote Originally Posted by ye1low View Post
    Here you go.
    Aug 18 2019
    Utah
    Quote Originally Posted by Mike Tries View Post
    Reply sent.
    Aug 18 2019
    Utah
    Updated list
    Apr 24 2025
    Washington
    Quote Originally Posted by AUDIMAN5000 View Post
    *Updated List*
    Thanks for looking.
    You don’t happen to have an exhaust, do you?
    Aug 18 2019
    Utah
    Quote Originally Posted by MidRebuilder View Post
    Not one that I'm willing to sell right now.
