Results 1 to 13 of 13
Thread: SOS9
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    SOS9
    Need some help...
    Trying to drop my motor in an I can't quite get there
    I'm in Seymour Connecticut
    ANYONE available for 1/2 hour of work
    Drop me a line
    475 280 8284
    Sent from my SM-A146U using Tapatalk
    Apr 08 2013
    Connecticut
    I'm at this point
    Feb 23 2010
    Emmaus Pa
    Start with the front end high then lower it as you push back towards the firewall. You have to muscle it pretty good, and I’ve used a break bar to line up the motor mount studs too. It will find home.
    Apr 08 2013
    Connecticut
    Ok
    I'm in
    All set here...
    I think I strained my ball sack!!!
    Apr 08 2013
    Connecticut
    Ps
    My 72 year old ass did not like that...
    I'm writing checks next time....he he he
    Apr 08 2013
    Connecticut
    PSA
    Here's what I did
    SHORT chains on the hoist so motor is dropping at an approx 30deg angle
    push forward so you can fish the heater hose line up thru the fire wall
    JACK under the tranny in line with the tranny mounts---this is key!
    lift the tranny but be aware of the down pipes--only need a bit of clearance for them
    lower the hoist while giving a push forward and VOILA.....
    I need a Bourbon and some chemicals.....
    PS-
    Having another set of hands and eyes would help GREATLY
    Veteran Member Three Rings q20v's Avatar
    Nov 12 2014
    2001 Audi A4, 2001 Audi S4, 1988 BMW 530i
    Ottawa, ON
    Hey!
    Glad to hear you got the motor in. I would have come to help but I’m a bit far…
    Why did you pull the motor? How has the car been running?
    Apr 08 2013
    Connecticut
    car was running GREAT---had a small oil leak----oil inlet on right side turbo
    My bad---was not tightened correctly on initial installation
    I detailed this in the SPRING thread
    ALL this work to change 3 copper crush washers!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    PS- THANKS for the offer to help----everone hates on us Silver guys!
    he he he
    PSS-
    Did a COMPLETE nut-n-bolt with the motor out-ALL was good with the exception of that damn oil inlet fitting----going on 5 years since the build and some 15,000 miles of use.
    Waste gate fine-cracking pressure right where I set them, NO other oil leaks, NO other screw-ups, vac lines an other plumbing all fine.....
    I work REAL slow so it will take me a weekend to get her back to whole.
    Feb 24 2010
    Oregon, Ohio 43616
    Just want to say kudos to you for still going at it at 72 years old. I'm 78 myself and still tackling those jobs on my S4.
    Apr 08 2013
    Connecticut
    AMEN Brother
    May 10 2018
    MA
    You should have texted me I would have gladly helped
    Feb 23 2010
    Emmaus Pa
    Muscling these drivetrains in and out is a young man’s game.
    May 09 2012
    Virginia
    I’m going to be doing a motor pull this summer. By myself as well. Not looking forward to it. And I’m 50. Kudos to you for doing this in your 70’s!
