Hi. I am a 2016 A7 owner living in Korea.
I get a lot of information about Audi from here. (But my English is not good, so I rely on translation.)
My hobby is self-maintenance, and I installed S7 brakes on my A7.
I am satisfied with the great braking performance, but there is a lot of noise and vibration when braking at high speeds.
My guess is that it is thermal deformation due to high temperature, as the discs are stained.
I replaced the discs and pads with new ones, but the same problem occurred again shortly after.
After much thought, I found a part called a damping plate that goes between the brake caliper piston and the pad.
I haven't been able to replace this part yet, but I'm wondering if this is causing the problem, so I'm leaving a post.
* My damping plate is currently covered in lithium grease and has no adhesive at all.
