The CF trim on my center console and one end of the dash are coming loose. The dash piece has just come undone one side, should be an easy fix. However, the center console "side" is peeling away from the gearshift side and actually curling up on the edge somewhat. I read some older threads and it looks like a blow dryer or heat gun on low can be used to "soften" the CF and then clear 2-part epoxy used to secure it back down. Is this still the best/only approach for this issue? I've never worked with true CF before and have no idea how much "give" it has before it or the clear coat starts cracking/breaking....
I've got some Gorilla 2-part clear epoxy on order.
