Originally Posted by
Audibot
You should use VCDS to monitor the refrigerant pressure sensor (G65 I think) and it should tell you the pressure of the system. I don't recall the measuring blocks but it's in HVAC. You should also check the fault codes to see what it says. Usually a refrigerant low pressure code is triggered. Obviously if you are low, you have a leak (probably condenser) and should have the offending component(s) checked out and replaced. And then evacuate and refill the system.
VCDS can't force it on and you should not anyway as to not risk damage.
If the pressure is too low when you put the a/c on, it will not kick on. At rest (no a/c on) it should be somewhere between ~5.5 and ~6.5 bar (~80-95) psig. When you turn the a/c on, the low side should go down to ~3 bars.
If nothing changes, it's likely your compressor is toast. In which case you will need to replace it and and should replace the orifice valve and accumulator, and flush out all the lines and condenser from metal fragments.
Finally got around to checking with my VAGCOM and here is what I see:
Car running, AC switch off,
AC regulating valve N280 - 0.000 A
Refrigerant Pressure G395 - 6.2 Bar
Car running, AC switch on,
AC regulating valve N280 - 0.600 A
I am assuming this is telling me my refrigerant pressure is good, pressure switch is also good, and compressor is bad. Am I correct?
Thank You
