Results 1 to 4 of 4
    Veteran Member Four Rings EvoRam's Avatar
    Jul 30 2012
    2006 Imola S4 Avant
    Tacoma
    B7 S4 JHM Crank Pulley, 034 MAF Hose, ECS Luft-Technick Scoop & Cam Adj. Solenoids
    I have a few things for sale. Some new some used. Pictures below.
    First is a used JHM 5 Rib lightweight crank pulley I had on my B7 S4. Used but in great condition. **SOLD**
    Also used 034 Intake MAF Hose. Comes with clamps. **SOLD**
    BNIB ECS Luft-Technick Intake snorkel scoop for B7 A4, S4 & RS4. $100
    BNIB Pierburg (7.06117.37.0) Camshaft Adjustment Control Valves (03H.906.455). These are an extra set I had for my B7 S4. These are to replace the factory solenoids for the mechanical adjusters (non serviceable from Audi). May need to extend the factory harness on bank 2 as it’s slightly short. $150
    Jackal Tuned / BMC Panel Filter / Tweetler 93mm TB Adapter / SAI Delete / JHM IM Spacers / AWE 2.5" Downpipes / Corsa RSC / JHM SSB / 034 Zero-Gap Snub / 034 FSB Links / SD Mounts & Diff Inserts / 034 RSB & Links / Bilstein Sports / Neuspeed Springs
    Jul 30 2012
    2006 Imola S4 Avant
    Tacoma
    Bump
    Jul 30 2012
    2006 Imola S4 Avant
    Tacoma
    ttt
    Jul 30 2012
    2006 Imola S4 Avant
    Tacoma
    Bump
