The car is never tracked and never launched, though she does receive "Italian tune-ups" on a fairly regular basis.
All was running trouble-free since then until a couple months ago. I was cruising on the highway (NOT high-RPM, full-throttle conditions) and lost all gears, with the dash lit up like a Christmas tree. Coasted to side of the road and had the car towed. Engine would not rev past idle and VCDS chucked a bunch of codes, including something about shift forks out of position. I was hoping that maybe it was caused by low fluid level (I suspected a leak in my transmission cooler line as I had been noticing some drips on the driveway a few weeks prior) and that I could simply top things up and she'd be fine, but when I got her up on jackstands and dropped the under trays, I was met with chunks of metal coming out of the inspection hole. No bueno!
Fast forward to this past month as I've been dropping the transmission in a buddy's garage (with a proper lift)... finally got it out today and it's pretty clear why it wouldn't go into gear. The hub of the Clutchmasters flywheel is completely shattered. This was literally the FIRST production one they released, so maybe they hadn't worked all the bugs out of it, but this thing is supposedly pretty well built and should withstand much higher HP/TQ... they're running the same or a similar one in Stage 2 S6s and S7s, after all. So, the question is... is the busted flywheel the disease, or merely a symptom? I don't want to go through all the trouble of replacing it only to have this happen again a few weeks or months down the road. Anyone have any experience with this aftermarket part and/or pushing the DL501 to its limits?
Thanks for any insight you can provide.
-Jon
