Hi guys&gals. My 2.0tfsi, BUL engine has engine light eith error code P2187-running lean going on and off. Sometimes it stays away several days. OBD11 shows long term fuel trim >6%, short term around zero. When I erase the code, engine almost dies and short term trim shoots to 25-27%. Then the values slowly return to about the same values as before the code erase. I checked the hose starting from booster, intact, can’t blow through it, doesn’t hiss. The next hose to vacuum pump has small (superficial) cracks at ends, and the socket to the vacuum pump has 1-2mm up/dowm play when engine is off. I thought the cracks or the socket was the leak, but as engine runs, the vacuum sucks the socket firmly down. It doesn’t jump around like in some videos I’ve seen. When I spray engine starter on/around this vacuum hose/pump socket, there is no change in rpm, nor any up/down peak in the short term fuel trim (there should be if the hose was sucking in air, right??) I’ve sprayed engine starter at/around all air hoses/connections, around the the PCV and breather hoses… with no rpm/fuel trim response. One thing still points to something being off with the brake vacuum, as when I press the pedal long it starts slowly going down and the rpm strats to climb well over 1000 (or is this normal?). The booster still seems to hold vacuum, as the depressed pedal doesn’t force itself up when turning off the engine. Any Idea what this is about? Could this be connected to lead idle error code?
If this was exhaust leak, should the engine react so strongly to erasing the code and resetting fuel trims? I mean, the mixture isn’t actually lean if the leak is in exhaust, or what is the chain of events then? I’m out of ideas, what should I check next. I have the cam chaing replaced next week at the shop and they’ll take a look at the lean idle issue, so no emergency. I’d just like to find the fault before I take the car to the shop.
