Hi all. I recently did a bunch of work to my b6 a4 1.9tdi. This includes cam belt and water pump, cam and lifters as they were warn, intercooler because it had a hole on in and all filters. The problems is that before even though the car was down on power and had a slightly later spool than I was happy with I was expecting the new intercooler to fix that. Bower now even though it has slightly more power is spools wayy later. Before was around 2000-2100 now it’s closer to 2400rpm. The cam belt was previously done incorrectly and was a tooth out so they had adjusted the cam gear to compensate. I have triple checked that the timing is now definitely correct so it can’t be that. I have noticed that the vacuum line going to the brake booster does wiggle a little bit, more than I would assume to be an acceptable amount. Is this a sign that possibly my tandem pump is on its way out? I have also noticed that the anti shudder valve looks like it does not close all the way. I have replaced some of the vacuum lines that looked a little suspicious and that also made no difference.
