Originally Posted by
joe_momma
Picked up a '14 S7 last week, one owner 108k miles. Has a couple of issues I need some guidance on:
1 - cruise doesn't work, error on the dash is "ACC and Audi brake guard: currently unavailable. No sensor vision". I haven't checked the two (?) sensors up front for damage yet, anything in particular to check for? Loose connections, dirty contacts, etc?
2 - driver heated/cooled seats - don't appear to work. The dash indicator for heating comes on for 15-20 seconds and then turns off (all 3 levels do the same thing). Seats don't appear to warm. Nothing seems to happen with the cooling feature when it turns on. Massage function works well. Any ideas here?
100k mile service - I don't know if this was completed or not. Manual says timing belt inspection is due - best to just replace it while you're in there I'm guessing?
So far, loving the car.
The type of people on this forum that could answer your questions might ask for a VCDS log to check for errors etc it’s a plug in diagnostic tool for VAG cars.
There’s a atleast one large thread regarding the ACC errors. In some cases the actual rear view mirror integrated camera sensor board has failed. Apparently you can send it in to a 3rd party repair type place that will “re-ball” the solder on the board. Last time I read it, the story was that dealers are on indefinite back order even if you have the couple thousand they charge for a new unit.
In my experience I’ve had auto cruise control disable, and side warning disable when there were loose connectors up in the front bumper area, and once was the home link module corrosion on a wire. (Garage door opening stopped functioning)
Changing all your fuses in (both ? ) fuse box(es) is inexpensive and worth a try
Electric cleaner spray and clipping in all the various connections would be more involved and require some DIY aptitude
