I've got a project 2011 A4 2.0L CVT FWD Sedan. I'm rebuilding the engine now, but I still don't know for sure that the CVT transmission even works. Even if it does, I've only heard bad things about them, and it's still 2WD.
My friend has a 2010 A4 2.0L A/T Quattro Avant Wagon that he is essentially parting out.
Is it possible to swap out my A4's FWD CVT transmission for the Avant's Automatic transmission, ECM and rest of the Quattro drive train? (which is all in good running shape) I can take any/all parts I would need from the Avant.
I gather that the Avant's ECM would have to be reprogrammed for my sedan and I would need to use the Avant's engine wiring harness too, right? But would the Quattro transmission and 4WD drive train bolt up to my car?
Would there be other considerations or other parts that I would need to swap from his Quattro to my FWD sedan?
I can pull, rebuild, and install these engines, and am getting half decent with VCDS. But this swap might be a pretty big undertaking! What do you guys think?
FWIW:
My sedan's VIN: WAUAFAFL9BN047***
His Avant's VIN: WAU4FAFL1AA107***
As far as I can see the only main differences in the VINs are the series number, and the NHTSA code.
