Results 1 to 4 of 4
    Jul 02 2022
    DC
    **Urgent** Where does this connector go?
    Hello I recently purchased a 2012 Audi A4, the seller said he ran into a ditch on the front right side no airbags deployed, upon cleaning under the front right wheel well I discovered a stray connector with two wires, ground, and a white and blue wire. This connector splits off from the crash sensor as well as splits off to the front of the engine (somewhere) on one side & the other direction flows back up over the wheel well & in behind the fender (somewhere). Thanks log and pictures in google drive link
    Link: https://drive.google.com/drive/folders/1-4c8ZBwb9h1tIa4sbukw7cgJbWxD1wjk
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    I'm going to say this is for the right front fog light connection, based on the location and B8 wiring diagrams. --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Jul 02 2022
    DC
    Quote Originally Posted by DrGER View Post
    Ok that would make a lot of sense, so is it safe to say that this connector has nothing to do with my airbag light and underboost code?
    Oct 10 2012
    Zionsville and Saint John IN
    P0299 code popped up years ago on my second turbo. I just bent the waste gate rod a little towards the passenger fender and haven’t had any problems the last 60k or so miles. Airbag light, you’d have to pull up the codes and let us know.
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
