Results 1 to 3 of 3
    Established Member Two Rings VA_S3's Avatar
    Sep 01 2017
    DMV
    Prospective Allroad Purchase
    Hi all,
    I've been looking to add a wagon to my fleet recently. Brown interior is the main requirement, so it's making it a little more challenging.
    I found one that checks a lot of boxes. As it seems like with many, this came from ME/MA. 65k miles. Actually held up a bit better than expected. Bolts can be replaced and the rest should respond well to a wool wax type.
    My question is, any common causes for what looks like a stained/wet area around the rear tub heat shield?
    Sorry I've spent 5 mins trying to figure out how to rotate the photo thats fine in iPhoto...audizine in 2003 still.
    Currently:
    2017 991.2 911 c2s
    2020 Q3
    Previously:
    2020 Nardo RS3
    2016 Sepang S3
    May 07 2021
    2020 A$ Allroad, 2013 911, 95 -993 convert
    Covington, KY
    Look inside around spare wheel make sure no oil or water. If its oil only on outside, check rear diff it could be laking
    Sep 01 2017
    DMV
    Thanks good points.
    Currently:
    2017 991.2 911 c2s
    2020 Q3
    Previously:
    2020 Nardo RS3
    2016 Sepang S3
