Results 1 to 10 of 10
    Junior Member Two Rings
    Mar 17 2025
    Ohio
    New owner with questions
    Hello all
    I have just arrived to the forum and first time owning Audi, especially SQ5. I didnt know S suspensions and S differentials were even a thing. I dont race, just driving enthusiastically from time to time, does it matter if I missed those options ?
    Can I may be swap them in later down the road If I missed too much ?
    Thanks
    Established Member Two Rings Txlifter's Avatar
    Oct 10 2024
    Wife's car 2018 SQ5 Prestige, completely stock which is how she wants it!
    San Antonio, TX
    What did you buy? It's a real rabbit hole, but suspension packages aren't feasibly 'swappable'. Improvements can be had but it's not worth trying to swap major components like that.
    2018 SQ5 florett silver prem+ with all the things.
    Mar 17 2025
    Ohio
    Just got a 25 SQ5 premium plus
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Look in your Maintenance Manual or what typically was the spare tire well under the boot floor, for a white sticker with a lot of 3 Letter/Number combinations. Those are PR codes and identify what components are factory fitted to your SQ5. Contact Audi of America with your VIN and ask them for the Mulroney Sticker and the full list of PR codes. Let folks on here know what you find and we can help from there.
    The SQ5 by definition will already have a sportier suspension than the regular Q5; other sports related components like differential then build on from that already sportier base.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Veteran Member Three Rings B6_Dolphin's Avatar
    Apr 10 2005
    PNW
    Looks like in MY '25, the brake calipers are already red, which was one feature of the Sport Package on my '21 SQ5 Sportback.
    As for Air Suspension and Sport Differential, the "S Sport Package" is a $2,600 USD option on a MY2025 model, and that is not retrofitable. The Air Suspension is nice for adjusting ride height, based on conditions, and works well when pulling a trailer w/factory tow hitch (auto-leveling). As for the Sport Differential, it has torque-vectoring, which helps transition the SQ5 through corners, for example.
    When the S Sport Package first appeared on the B9 SQ5 in 2018, here's a quote from Road & Track:
    Underneath is where the best changes are. The new SQ5 has Audi's air suspension available, which lowers ride height by 30 millimeters and allows for height and damper adjustment. It also can have Audi's sport differential, which is a torque vectoring rear diff that can send nearly 100 percent of the power to one wheel.
    Do you NEED these features? No, they are "nice to haves" depending on your expectations of the driving experience.
    2023 RS5 Coupe - Ascari Blue/Black; Mods: IE A2A IC, 034 Strut Brace, ECS Poly Trans Mount, APR CF Intake, EuroCode FRT & RR STB + Endlinks, PB Pedal Tuner; AskCarbon Steering Wheel
    2021 SQ5 S/B Prestige - Daytona Gray/Black
    Mar 17 2025
    Ohio
    Yes, I realized it too little too late just right after 3 days of taking possesion of the SQ5 that the dealer had the exact same model and color but just added Sport package. As the first time Audi buyer, I didnt know the differences :(. The standard one drive amazingly well though, may even be too sporty for my wife and that she demanded me to make it more quiet, that I had to remove the D4 fuse for the soundaktivator system
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by a4audi4fun View Post
    Monroney
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Jan 30 2024
    Tampa, FL
    ‘24 Prestige with all options selected (when I ordered in back in Jan of last year) except the hitch. Red calipers, air suspension, sport rear diff, sport exhaust tips…
    Jul 16 2018
    Atlanta
    It seems odd to me that on the web site the US MY25 SQ5 without the S sport package (which packages the 2MB sport air suspension and GH2 sport rear diff) appears to show as being configured with 1BL standard adaptive coil spring suspension, rather than 1BQ sport adaptive coil spring suspension.
    Mar 17 2025
    Ohio
    Congratulations! Sharp ride. This style is much bettee than what is showing to be the redesign IMO
