    Jan 21 2018
    Melbourne
    AUSTRALIAN B5 RS4 (Running&complete BUT low comp bank2 suspected bottom end)
    Hi guys,
    I have B5 RS4 I’ve been building for a while. This is very modified for an RS4 in Australia and I know that isn’t for everyone but IMO my mods I’ve done have longevity and serviceability in mind but far from OEM+.
    Last time I drove it did a pull and heard a pop in the gearbox, at first i thought the box broke but it turned out I had torn the throw-out bearing in half! On the truck and a year later after all the mods where done realised couldn’t get it to go lower than 91KPA on MAP tune and did a compression test resulting in bank2 being low as 75psi dry and 100psi wet.
    I have spent a fortune and blood, sweat on this car, this was my dream car for a long time but life happens and don’t have time/space to rebuild the motor again.
    The price I’m looking for it think is reasonable the other RS4's on the market are High kms stock and needing all the 2.7 big ticket items you would need to spend big $. A cheap sub 50kAUD/$30kUsd car with 200,000+kms and leaks everywhere and tired K04's, just to spend thousands on getting it back to roadworthy condition. If you do the math in parts this car is worth alot more, just no time and space to do builds like this anymore.
    >>>$30,000 USD ONO<<< I CAN ASSIST WITH IMPORT AND SHIPPING MORE THAN HAPPY TO ASSIST ANY US BUYERS
    THE CAR HAS IDLED TWICE! SO ALL THESE MODS ARE BRAND NEW
    2001 B5 RS4 140,000kms
    Moderately spec’d
    has Alcantara pillars and headliner (bit saggy common material is very thick high qual= heavy)
    Had white seats with black everything else, I put black rear bench from another RS4 so it has the proper rs4 logos and is black leather. But fronts are white with covers was going to go pole positions but, seat warmers.
    car is extremely clean always garaged all weather seals are still soft and rubbery ever the windscreen cowl under the wipers
    ENGINE
    -2.8 NA rebuilt heads Ported polished with 034 oversized 1mm valve set with valve spring set dual springs with titanium retainers (OEM RS4 heads are crack-prone so ive heard)
    -Original block RS4
    -Pauter Rods
    - 980CC injectors
    -Bosch 044 Billet 034 fuel pump with drop in kit to run in-tank
    - High RES map sensor with THE-TUNER adapter
    - Integrated engineering SAI delete
    - Wagner Coolers with carbon Fiber shrouds
    - New 034 Diverter Valves
    - 034 density line engine mounts
    - ECS tuning 2.0T coil pack conversion kit with loom and billet plate 6x Bosch OEM R8 coil packs
    - Gates Kevlar timing Belt
    - ALL OEM SUPPLIER BRANDS service items i.e.: all cams seals, timing chain tensioner seal, thermostat, waterpump, pulleys, belts timing, turbo gaskets seals everything i mean everything over $2keuro in just seals and sevice items all shipped from Europe, and with spares.
    - Refreshed the EVAP system with new plastic hoses and one way check valves
    - Brand new AC condenser
    - SS line with metal clutch slave
    - New clutch fork, thorwout bearing, pivot pin
    -Fluid Dampr USA harmonic balancer
    -TTH-TurboTechnikHamburg: 2.7TB5RS6+ Turbos (From 2.7T motorsport in Sweden, being the "+" model its a RS6 rear end with a TTH-800 wheel CNC'ed to fit into a CNC ported RS4 front housing with high flow port front and rear and upgraded RS6 wastegates). Turbo rear housing is also Coated from RACECOATINGS in Warragul in their high temp ceramic. Extremely high quality and high price on those $4.5k+ alone not including shipping pair of RS6 turbos from USA to Sweden and shipping my old K04's from Aus and THEN shipping it all back as 1 pair with headers.
    - Custom 3.5" SS down pipes to suit Rs6 rear housing into a Y pipe to single 4"which then steps down into a 3" into a brand-new old stock Scorpion muffler (good sound only idled) the thing is CATLESS with 1x muffler but the (NOS) scorpion and the step down makes it very quiet for what it is. Also all V-banded for ease.
    -THE-TUNER cast manifolds also coated at RACECOATINGS in high temp ceramic (also eye watering price but, these are the best for flow+fitment, with a cast design you can get shapes you can’t achieve with welds especially in a compact enginebay)
    - CLUTCH MASTERS 850SERIES with twin 1x ceramic 1x organic. Big $$ Big grab
    -MAXXECU from Sweden this was an absolute nightmare to get to Aus bec of EU laws but some of it came from US distributors. Its the plug n play kit for 2.7T currently running on 4.2 LSU with 2x 4.9 LSU WBO expansion modules. works extremely good out of all the pnp kits I’ve used.
    Chassis
    - Work Meister M1 3piece custom on 255 tires travelled maybe 15,000
    - Have some 8 Piston B7 rs4 brakes to go in with girodisk 2pce 380mm but don’t fit the wheels
    - KW V3 Coilovers
    - 034 Sway bar kit
    - 034 Rear Adjustable sway bar links
    - 034 Motorsport Front Sway Bar End Links
    - 034 Sway bar rear reinforcement
    - 034 Density line Control arms
    - JXB Centre drive shaft bearing
    - VERKLINE FRONT TUBULAR SUBFRAME powder coated in red ( this thing is a god-send makes the b5 actually serviceable without removing the motor can access both turbos easily, engine mounts, downpipes, wastegates, clutch slave etc.. must buy imo if you got silly coin, also insane $ to get it to Aus from Europe think it was just under $4,000aud shipping VAT and Duty)
    - VERKLINE Rear Differential Mount (Track Hardness)
    - VERKLINE Gearbox mounts (Track Hardness)
    - VERKLINE Rear Differential Polyurethane Carrier Mounts (Track Hardness)
    - VERKLINE Polyurethane front snub engine mount Black
    - Rg customs Audi B5 Quattro 01E Gearbox mounts (to clear the gigantic downpipes)
    - CAE shifter Anodised BLACK with ALU green knob and machined M10 thread. Big$$$ but imo the shifter feel is 2nd to none with CA shifters and also rids of the oem terrible design. another $3.5k+AUD European adventure.
    Probably more mods I’ve forgotten but that’s the core of the stuff I’ve got for it over the last 9months EVERYTHING I BUY FOR THIS CAR HAS TO COME FROM EUROPE so you could imagine the logistical and financial nightmare.
    Yes the bottom end. I have pulled the sump and found nothing the motor is very new, possibly a cracked ringland, impropper gap or something else havent done a teardown on the motor, currently as the car stands its running on base map just to move around the shop. Best case scenario it just needs new pistons, since the cars running fine most of the rotating assembly if not all of its is re-usable since its brand new.
    Thanks for reading.
    At this point im not interested in part out even it would net more $ , I'm looking to sell complete to someone that wants a hardcore B5 and possiblly the most modified RS4 outside of Europe.
    link: https://www.ozaudi.com/forums/index....tom-end.58314/
    Veteran Member Four Rings belms4's Avatar
    Apr 17 2019
    2000 silver S4, 2001 imola S4, 2002 Avant nogaro RS4 conversion
    Sounds awesome, but the link isn't working for me to see it. Maybe requires a login on the ozaudi site? Or audizine butchered the link after you added it?
    Sent from my SM-F741U1 using Audizine Forum mobile app
    Nov 21 2019
    About a dozen very modified cars.
    Tacoma, Wa
    This?
    Snazzy. But you have to be logged in to see anything more than the tumbnails. Can you post pictures?
    Junior Member Two Rings
    Oct 16 2010
    S4 2.7T - 996
    Montreal, Quebec
    Interested
    Senior Member Two Rings milehighkid24's Avatar
    Oct 25 2013
    Nardo Grey B8.5 S4, Casablanca White B5 S4
    Scottsdale, AZ
    Emailed you.
