Results 1 to 5 of 5
    Junior Member Two Rings
    Nov 27 2022
    NA
    Headlights and DRL
    On the 2013 I’ve noticed my DRL leds are starting to lose some of their white punch, that is I see a little “yellowing.” Wondering, what if I just turn off DRLs and use the main headlights all the time instead? Surely the cost of xenon bulbs is cheaper than a new headlight assembly.
    Veteran Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5, 1988 ASC Mclaren Mustang 5-speed
    LI, NY
    yeah I've definitely noticed some lack of brightness in my DRLs not necessarily yellowing though... I believe you can turn off the DRLs in the MMI settings but I haven't done it so I'm not sure.
    14 B8.5 S4 6MT Current Daily
    01.5 B5 S4 6MT SOLD
    04 C5 A6 2.7T S-line SOLD
    02 B6 A4 1.8TQM DG Sport Package SOLD
    Motoza Stage 2, USP front & Cupra lip, S4 rear bumper, 18" BBS CH, OBX exhaust, PSI concepts test pipe, Genesis 380cc injectors, Stratmosphere Hyperboost DV, CX Racing FMIC, Forge TIP, B6 S4 BBK, etc...
    Oct 23 2014
    Buffalo, NY
    You can turn up the DRL brightness with VCDS and many other OBD tools, maybe a little more intensity will bring out some white.
    Otherwise, not only can you buy replacement DRL LED modules but you can also buy replacement DRL light tubes, hell they even sell a kit; you’d have to take the headlight apart however to complete these swaps which isn’t too hard.
    https://www.ebay.com/itm/196848465293
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Nov 27 2022
    NA
    Great ideas, thanks!
    Senior Member Three Rings ad03avant's Avatar
    Jun 21 2008
    2003 A4 Avant Quattro
    Olympia, WA
    Quote Originally Posted by bakedziti View Post
    Does anybody know if that kit will fix the LED module code? When I get this code is it that little circuit board that comes with the kit (https://www.ebay.com/itm/196848465293) that goes bad or the is LED Module for DRL and Parking Light something else? Thanks
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
    012 - Electrical Fault in Circuit - Intermittent
    Andy
    -2003 A4 Avant Quattro
    -APR Stage 2 +, Achtuning Snub, Avic D3, USP Front, S4 blades and bi-xenons, APR stealth, 034 HFC, ASA JH3 18', platinum VMR sport gauge, h-sport sways, ABT springs, Koni sports, Zimmerman sport rotors, Stoptech stage 1
