If I had dried foam it would have been easy. The original foam deteriorated into a sticky gooey paste that quickly filled up the brush bristles. The putty scraper worked very well to remove the bulk of the gunk, I used solvent on what was left.
Other things I learned:
The new liner dulls cutter blades very quickly, having a fresh supply helps. I went through six exacto blades making the small cutouts for the lights and visors. Also, my shop scissors are hand me downs from the kitchen; They also were lacking. The newer kitchen scissors worked much better, ideally I should have had a set of real fabric shears. The headliner material was surprisingly tough.
I for the initial glue up, I placed the material over the frame and folded it back, leaving the section over the back seats exposed (I split it at the sunroof opening). I spray glued the frame and the fabric and glued it from the center to the back window, pulling it taught as I worked it down. Once the back half was done it did the same thing for the front. I cut and glued the openings after I had the main sections done.
Three of my original trim pieces were broken, no idea when or by who. It may have been from when I got the car painted and they pulled the glass. The black trim set I got on Ebay was in decent shape and saved a lot of time over redoing my existing trim to black. Of the entire set that I bought, two clip mounts were damaged. I fixed them by doing a bit of plastic welding using a soldering iron and scrap plastic from my old trim. Not pretty, but its hidden and it works.
The pillar covers with the seatbelts got me the first time around and had to be redone. I did not realize that they need to engage with the seatbelt mechanism that is built into the door. Lesson learned.
I took the back seats out so that I could remove the trunk liner. That little bit of extra space made feeding the headliner assembly back in a lot easier. Talk about a giant pile of parts! I also learned to make sure that all the old clips come out. One had stayed behind in the windshield pillar, since I had new trim I never noticed that one was missing. Once I got the old one out the install was a lot smoother. Also, double checking that the wiring harness is dressed back and all the wires are accessible is important. I did not feed the passenger side mirror wire down and on the driver's side one section of the harness ended up in the way of a support. Super easy fixes, I just took my time and did not force any parts. If it seemed like a problem I did not force it.
I'm glad that people on the board talked me out of leaving the pillars gray. The black looks so much better!!!! I have a few things to finish up today. It's down to the trim for the 1/4 windows and putting the back seat seat and trunk liner in. I'm not fast at this, but so far the results are good.
