a transistor is basically a relay, depends on which type though.
http://www.technologystudent.com/elec1/transis1.htm
Printable View
Finished the project and everything works perfectly. Camera goes on and off with the ignition and the switch works as a manual override to keep the power on with no key in the ignition.
I'm a little confused though because with the key in the on position terminal 15a reads only .4 volts. I hooked it up initially and only had power from the switch, not ignition, found the lack of voltage and moved it over to 75x. No problems now. The camera doesn't shut down when starting since it switches to battery power briefly until power resumes, if it doesn't get power in 5-10 seconds it will shut down as desired though.
Here's the completed harness ready to install.
http://i346.photobucket.com/albums/p...ps254c74b9.jpg
This is the relay I ended up using, a 205 instead of the 204 I normally use. The 205 has an 87a pin where the 204 doesn't. I used a stock relay plug and patched it into the relay panel.
http://i346.photobucket.com/albums/p...psca8771b0.jpg
Harness for the switch connection.
http://i346.photobucket.com/albums/p...psc082e948.jpg
Quick disconnect plugs so that I can pull the knee bolster easily, this was a requirement of the install. There's enough length on the wires to allow me to drop the bolster to the floor without worrying about tugging on anything.
http://i346.photobucket.com/albums/p...psb9d8b383.jpg
Used a matte knife and scissors to cut a hole in the bolster sound deadening.
http://i346.photobucket.com/albums/p...psb511493f.jpg
Insulated the terminals and connected the harness. The wire I used was way overkill for the project but it was all I had laying around, too lazy to go get more today! Everything is protected by 1 amp fuses on both power feed lines.
I have the ground wire running to the bolt for the knee bolster below the fuse box, automatically disconnects the ground as I unbolt it.
http://i346.photobucket.com/albums/p...ps15a336e9.jpg
Everything mounted up. With that lip on the edge of the bolster you can only see the switch by putting your head below the dash.
I think this is the first picture I've posted of the LED light bars I use under the dash and seats. They're held on with velcro for ease of removing the bolster.
http://i346.photobucket.com/albums/p...ps56eb72f7.jpg
The LED on the switch is super dim when activated. Whatever, don't really care.
http://i346.photobucket.com/albums/p...pse4fd5470.jpg
And here's the dash camera, mounted below the rear view mirror.
http://i346.photobucket.com/albums/p...psa5f43b78.jpg
I just finished a major maintenance service on my dad's B5. He was driving to work a few weeks ago when his battery light came on, he lost power steering, and the coolant temp started to rise. Turns out his serpentine belt snapped.
I raced down to where his car broke down, he took my car to work, and I escorted his car back home on the tow truck.
I started ripping into the car and it snowballed from there. One thing led to another which led to another. A lot of "well, if we're gonna replace that we might as well replace this too."
Here is a list of what was done or replaced.
Timing belt + tensioner, pulley, roller, and water pump
Serpentine belt, water pump belt, AC belt
Intermediate shaft seal and o-ring
Both camshaft seals were leaking, replaced
Turbo oil return line gasket replaced
Cam chain tensioner seals and valve cover gasket replaced
Cracked fan blade replaced with fan blade from junkyard
Intercooler removed and completely cleaned and washed out
All boost hoses cleaned inside and out, found the DV hose had a gash in it, replaced with a junkyard replacement
Installed 710N DV and NGK BKR7E spark plugs in anticipation of chipping the car
Airbox removed and cleaned, filter cleaned
Cabin air filter replaced
Snub mount replaced (OEM)
Oil filter replaced, new Rotella T6 5w40 oil
Fresh coolant of course
Then the intake manifold came off…
Breather hose was cracked (it was fixed with OEM plastic parts 2 years ago), replaced with an 034 breather hose kit
Turbo oil feed line replaced along with both crush washers beneath the adapters
Fuel injectors cleaned and o-rings replaced
Coolant flange replaced (OEM) and new o-rings
Throttle body and intake manifold fully cleaned, intake manifold and throttle body gaskets replaced
Oil cooler gasket replaced
Oil cap gasket replaced
All vacuum hoses replaced with Forge black silicone hose including turbo vacuum lines
Removed the fender liner and fully tested the cruise control hardware, lack of cruise control isolated to an electrical problem. Remounted cruise control pump as it had come loose.
Since this car is an automatic, to put the car in service position the auto tranny cooler hard lines must be disconnected from the lock carrier. After seeing the grey sludge "fluid" that came out from the lines coupled with a leaking tranny pan gasket, we decided to do a transmission service as well. Bought an auto tranny kit from Blauparts for $125 that came with a new filter, filter o-ring, tranny pan gasket, fill and drain plug o-rings, fluid, and a hand pump.
http://i346.photobucket.com/albums/p...psd88d832e.jpg
http://i346.photobucket.com/albums/p...ps50d034c9.jpg
http://i346.photobucket.com/albums/p...pse6c18f85.jpg
http://i346.photobucket.com/albums/p...ps5300c77b.jpg
He was due for a timing belt replacement and having one belt snap doesn't inspire confidence in the others, so into service position it went and I "assumed the position."
http://i346.photobucket.com/albums/p...psb354d3a0.jpg
Parts to be installed.
http://i346.photobucket.com/albums/p...ps5de4cebb.jpg
The mess I started with.
http://i346.photobucket.com/albums/p...ps7d3a246a.jpg
http://i346.photobucket.com/albums/p...ps192af749.jpg
http://i346.photobucket.com/albums/p...ps397fa4ad.jpg
http://i346.photobucket.com/albums/p...psaad373e7.jpg
Pile-o-parts.
http://i346.photobucket.com/albums/p...ps593ba3f5.jpg
Dirty ass intake manifold.
http://i346.photobucket.com/albums/p...ps0f9918ce.jpg
More parts, clean intake manifold.
http://i346.photobucket.com/albums/p...psa0e58f7d.jpg
Who says cleaning isn't fun? Look at that! Ready to throw it in a pan and fry it up!
http://i346.photobucket.com/albums/p...ps65ed9d55.jpg
http://i346.photobucket.com/albums/p...ps23f6a5a6.jpg
DV hose with a gash in it, nearly broke through. Replacement hose behind it.
http://i346.photobucket.com/albums/p...ps4e921196.jpg
http://i346.photobucket.com/albums/p...psb071d9e8.jpg
Cracked fan blade, replaced with junkyard blade.
http://i346.photobucket.com/albums/p...ps69a8ad47.jpg
Dirty intercooler prior to cleaning.
http://i346.photobucket.com/albums/p...psc38836f4.jpg
Frame rails cleaned.
http://i346.photobucket.com/albums/p...ps98b7c42f.jpg
New timing components installed.
http://i346.photobucket.com/albums/p...ps5beac0c6.jpg
Valvetrain.
http://i346.photobucket.com/albums/p...ps58e27336.jpg
Top end buttoned back up.
http://i346.photobucket.com/albums/p...ps327b16ce.jpg
Nearly finished reinstalling everything.
http://i346.photobucket.com/albums/p...ps1034c12c.jpg
Looks a little bit better now right? And a whole lot easier to work on or take apart again if need be. No more glued together boost hoses.
http://i346.photobucket.com/albums/p...ps4c6d959b.jpg
New timing belt sticker ready to fill out.
http://i346.photobucket.com/albums/p...psbac36dfc.jpg
Transmission pan dropped.
http://i346.photobucket.com/albums/p...ps259d3aa9.jpg
Old nasty filter.
http://i346.photobucket.com/albums/p...ps771b6ce9.jpg
Tranny pan magnets covered in metallic sludge.
http://i346.photobucket.com/albums/p...ps3c8b3e2b.jpg
http://i346.photobucket.com/albums/p...ps1ac4b48d.jpg
Cleaned magnet.
http://i346.photobucket.com/albums/p...pscda04de2.jpg
Cleaned pan.
http://i346.photobucket.com/albums/p...psad2b5eeb.jpg
Transmission valve body.
http://i346.photobucket.com/albums/p...ps436b25c2.jpg
As I was under there I noticed that the transmission output seal was leaking pretty bad. I picked up the seals to replace it and will tackle that job next month maybe. All the rear differential seals are leaking as well, so it'll be a full driveline service. I did replace the fluid in the center diff while I was there.
http://i346.photobucket.com/albums/p...ps45eceae9.jpg
Finished! …for now. Oh, and I did chip the car as well, what an improvement!
http://i346.photobucket.com/albums/p...psbf2cded4.jpg
I forgot to mention, after getting it all put back together and firing it up, I noticed the serpentine belt tensioner was moving around excessively. I believe the busted tensioner plus the worn belt is what caused the failure. I pulled an OEM tensioner off a car at the junkyard and it is solid with no movement now.
https://www.youtube.com/watch?v=G6A0At_z-2w
Also, I made a little video of the valve action. Spark plug 1 was not tightened down which is why you only hear three "breathes."
https://www.youtube.com/watch?v=7z59wZ9EC20
I absolutely love this sort of work. Good job man! [up]
Thanks Rich! Your Avant looks great by the way.
I have to say though, doing the transmission service on your back sucks. Tightening the 27 tranny pan bolts in a circular pattern, going over all of them again to make sure I didn't miss one, then torquing them in a circle pattern, and again around the circle to make sure I didn't miss one, sucks!
Yeah man, it's hard to even keep track of 12 bolts in a star pattern, 27 in a circular seems like a huge pain.
I need you to do a similar service to my car.
Let me know if you want to work something out, can be done.
Reno, going back over the bolts in a complete circle was necessary as I definitely missed a bolt here or there on the initial tightening. Fun stuff.
Quick little update on my car.
I picked up a replacement Audi fender logo from a parts car today. The passenger side one on my car had the plastic finish peeling and looked like doo doo. The replacement isn't perfect, but it looks a helluva lot better.
Old.
http://i346.photobucket.com/albums/p...ps0a98d7bf.jpg
New.
http://i346.photobucket.com/albums/p...psc7b784b6.jpg
There is also a 97 europa blue mica car that arrived at the pick n pull 30 miles away a few days ago. Sunday I'm planning to go up there and check it out. If the doors are good condition I'll be picking both the passenger side door skins to replace my keyed doors. Hopefully the paint is a close match! I asked them what they would charge for the door skins today and they said $35 each, sounds much better than the $800 it would cost to get both doors fixed and repainted.
Ok so I love this thread. Took me like 30 min to go through everything and I must say I am impressed sir! I picked up a B5 a few months back and would love to have the engine bay look half as good as yours. I must ask where is this magic PnP you find these 1.8's? I live in OC I hope it's closer.
B5 A4 1.8t AWM
Thanks, I appreciate that. It has been a labor of love.
Glad you enjoyed the thread, there are 45 more pages of earlier stuff here on AF if you didn't check out any of the early links in my table of contents.
I'm quite lucky that there are 6 Pick n Pulls within 50 miles of me. There's almost always two or three B5s at each lot with a new one coming in every week or two.
Your commitment to quality is awesome, keeping b5's alive
What cities dude?
B5 A4 1.8t AWM
So much better now that the grille is black and you removed that silly chrome edging..
Yesterday I saved my motor's life by going back into service position to replace the front crankcase gasket. I was setting the engine to TDC when I noticed that that timing belt was not tensioned as it should be. Turns out that the timing belt hydraulic tensioner failed and was completely blown out.
https://www.youtube.com/watch?v=6Tlmjfs0ouk
NSFW warning on the 2nd video, foul language.
https://www.youtube.com/watch?v=KIm2v6cYTv8
I did a timing belt service last year with an enhanced TB kit from Blauparts. The tensioner I received in the kit was not an NTN brand as listed, but a TQ (Teile Qualitat) tensioner. I did not notice or pay attention to this at the time and it nearly cost my motor. Lesson learned. They mentioned that they may have switched part suppliers within the last year, but I did not get confirmation of this, so it's still unclear as to whether they shipped an incorrect part or not.
I got in contact with Blauparts today and they are warrantying the timing belt kit and sending me a new INA brand timing belt kit with proper NTN brand (or Lintens…which is apparently also OE, but I really hope it's an NTN) tensioner. They are also shipping it overnight priority which means it should be here monday morning. I was quite disappointed at first when I found the failure, but I'm pleased with how Blauparts handled the issue. It's horrifying to think that I had the car wound up to 5500 rpm the other day with a loose timing belt. I'm counting my blessings that there was no engine damage and the timing was still spot on when I took it apart.
What brought me into service position in the first place was this leak from my crank case cover that I noticed when I was doing the TB service last year but didn't get around to fixing.
https://www.youtube.com/watch?v=RYBVnrs-KjA
Can't have a post about service position without my classic picture "back into the position."
http://i346.photobucket.com/albums/p...ps868e23b6.jpg
http://i346.photobucket.com/albums/p...ps15b66cfd.jpg
And finally down to where I needed to go. Crank pulley and crank case cover removed.
http://i346.photobucket.com/albums/p...ps65670cb1.jpg
Dirty cover ready to be cleaned and the old gasket debris.
http://i346.photobucket.com/albums/p...ps353dedb5.jpg
Block cleaned and ready for the new gasket.
http://i346.photobucket.com/albums/p...psc44c9ee2.jpg
If your engine code is AEB they should not be sending you a "Litens" tensioner but I hope it's just a miscomunication. I really hope they didn't mess things up again. The Litens tensioner is only for AWM so if they send you an AWM kit then there is going to be problems...
Yes, I'm AEB. I also hope that was a miscommunication. I confirmed that the kit they are sending me is this one though, which is for AEBs. So hopefully all is well.
Glad to hear that Blau came through and are sending you a new TB kit (with the right components, haha). But it's weird that they sent you a TQ tensioner, I thought all of their TB kits used a NTN tensioner? So I'm confused as to why they were using them or had them in stock (unless that was a result of their supplier change).
That was my understanding as well, I'll try to get some clarification on whether there was a part change or not after the new kit arrives. I've started work on my crank pulley locking tool as well, should have it done tomorrow.
New gasket in place (and oil pan cleaned.)
http://i346.photobucket.com/albums/p...psa8ecdf56.jpg
Crank case cover installed, new crank seal in place, and snub mount bracket bolted on. This Victor-Reinz PTFE crank seal I got actually came with the installation ring. Made installing the new seal super easy. Without the tool it's next to impossible to get the inner lip seated correctly without messing it up or having it fold over. I learned that the last time around.
http://i346.photobucket.com/albums/p...pse786dda5.jpg
I also set up my dash camera on the ceiling of my garage and have been recording this whole service which I'll make into a time-lapse when I'm done.
http://i346.photobucket.com/albums/p...ps3dc34c95.jpg
As I was cleaning parts last night I discovered that my TIP had a massive rip in it. I have a feeling that I ripped it when I was removing it, but I don't know for sure. I wasn't getting any lean codes.
http://i346.photobucket.com/albums/p...ps7531c12f.jpg
I wasn't planning on going to the junkyard this morning, but sometimes life throws little wrenches in your plans. I was starting to get worried after seeing 2.8 after 2.8, probably 8 of them before I found a passat with a 1.8T that had an intact TIP. I also snagged another set of aero wiper arms (and blades) off a B5.5 passat. These arms are in better condition that the ones I pulled a couple weeks ago. I'll either put the old set on my dad's B5 or sell them.
http://i346.photobucket.com/albums/p...psb1a28d9c.jpg
The new timing belt kit arrived this morning from Blauparts with the proper NTN tensioner and INA components. Woot woot!
I installed the new TB kit based off my reference marks from a year ago, however I don't believe those marks were actually correct. When I went into service position to install the HFC and new turbo earlier this year I posted a picture of my timing marks and it definitely looked off a tooth. I didn't change the timing as the car ran fine and I didn't want to deal with it.
With the cam aligned to TDC, the crank was advanced and did not line up with the factory TDC mark on the lower TB cover and dampener. I marked the crank pulley for TDC based on the dowel in cylinder #1 method, however I think I missed the mark on it. I double checked the accuracy of the factory crank TDC mark and it lined up with the dowel method. With the crank at TDC the camshaft pulley was retarded by nearly a tooth.
What I ended up doing was leaving the crank at TDC, pulling the belt off the cam pulley and advancing it one tooth. After re-tensioning the belt and checking everything it looks to be spot on now. Cam mark, crank mark, and dowel pin all point to TDC at the same point. We'll see if I notice any difference in performance. I kind of doubt I'll notice anything though.
With the timing finally set I torqued and stretched the new crank bolt using the crank pulley tool I made. It ain't pretty, but it definitely got the job done. I used a 3" wide piece of 3/8" thick steel and drilled the proper holes. I used a boring bar in my drill press to open up the middle hole to the proper size. In it's current form it can only be used with the snub mount cage removed, but that's fine. It doesn't require a 2nd set of hands to hold it either as it gets wedged against the left edge of the snub mount plate and rests just behind the AC compressor bracket locking it in place. I had my buddy look for any deflection in the plate when torquing it and didn't see any.
Torqued to 66ft lbs + 90 degrees. Paint mark on the bolt was to indicate the 90 degree rotation.
http://i346.photobucket.com/albums/p...pse6d2dbea.jpg
http://i346.photobucket.com/albums/p...ps02df4fb7.jpg
http://i346.photobucket.com/albums/p...psa31eb9fb.jpg
I ran into a new problem when I was replacing the spark plugs. Two of the crush washers decided to stay embedded in the head instead of coming out with their respective plugs. I'm baffled on why that would happen twice on the same set of plugs when I've never had it happen before. All the plugs were anti-siezed up and torqued to spec. I was able to use a long pick to get in there and pop them free, but it was not particularly easy. Hopefully it doesn't happen with the new set of plugs…
Finished progress for the day. Should have it running tomorrow. Oh yeah, forgot to mention, I also replaced the crush washer for the turbo oil feed line adapter as I saw some weeping in that area.
http://i346.photobucket.com/albums/p...psbd48b73c.jpg
Obligatory glamour shot with the VC re-bead blasted and clear coated. Should be a lot easier to keep clean now.
http://i346.photobucket.com/albums/p...psf3301c7a.jpg
You'll love the aero wipers. They are so much better than the stock ones. Second greatest thing I've done to my car.
Sweet, do they function better in addition to looking better? Now I'm curious, what was the single best thing you did to your car? (The 4.2 swap?)
Buttoned everything up and about ready to swing the lock carrier back into position.
Replaced all the turbo vacuum lines and vac lines under the intake manifold with black hose, cleaned and serviced the diverter valve, cleaned the intercooler and straightened any bent fins, and did a boost leak test (no leaks.)
http://i346.photobucket.com/albums/p...pscaecfd01.jpg
We get a lot of rain here and the aero wipers work great. The thing you will notice immediately is that when you sit in the car, you'll barely be able to see them. The best mod was probably the independent fog lights....or the V8.
Your car is looking good and I'm glad you got that tensioner sorted out before it became a BIG problem.
Those are some stealthy wiper arms. I installed them today and they're great (well the blades on them suck, but that can be fixed.) I love how low they sit, barely noticeable now.
And thanks, got the car up and running yesterday. It's hard to say if the small timing change made any difference, it feels smoother, but it could all be in my head. Definitely dodged a bullet on this one.
I pulled the upper timing cover and checked the components on my dad's B5 today and his car has the proper NTN tensioner and INA components, so luckily I don't have to re-do his car as well.
I like you're style. Cleaning stuff instead of just putting greasy grimey parts back in the bay (a huge pet peve of mine) I actually pay my little sister to clean all the grease off parts that are off the car. Man i need a bead blaster, i restored a pair of dirt bike pegs, they were stock, dull and the black paint was all but peeled off. Using a Dremmel i sharpened each little spike, then sand blasted them at my work, followed by a few lairs of clear coat.... Needless to say the transformation was incredible, It was like they were new. Love that sand blast finish it leaves on metal, just "clean" looking.
Hey where did you get those colored braided vacuum lines?
Here's a couple pictures of the aero wipers installed. You'll have to excuse the dirty car, I left it outside when it rained the other day.
http://i346.photobucket.com/albums/p...ps82140305.jpg
Can barely see them!
http://i346.photobucket.com/albums/p...ps0f1311d2.jpg
I also got around to tucking my dash cam power wire inside the A pillar. Couldn't stand having it fall down out of place after leaving the car in sun, much better now.
Thanks, I unfortunately do not have a little sister to clean parts for me. Just a can of WD40 and a rag, or the bead blaster for the metal parts. Hard to beat the satin finish of the bead blaster. I wish I had clear coated my intake manifold the first time around. Only thing holding me back from blasting it again is having to go put it in a parts washer to clean it out.
I use Forge vacuum tubing, but none of it is braided.
yea i wish she could be counted on to clean parts into the late of the night but, can guess how that ends up, so i usually do most of the parts haha but use her whenever i can via bribes or something. Siblings are fun... hahah
as for WD-40 for degreaser it WORKS but not even close to as good as the CRC engine degreaser works. Seriously this stuff cuts through decades old 3" thick grease like its warm butter, I am a mechanic and have tested all kinds of different brands but hands down CRC is where its at. Walmart usually has it for -4$ a can. Thick tar grease just literally wipes off its nuts. One can cleaned my entire bay on my 98 pearl avant VRT project i had to scrap *tears up a little* (empty bay i mean)
Very clean!!
I finished editing together the time-lapse of my recent service the other night. 13 hours condensed down to 16 minutes at 400x acceleration. Check it out!
Work completed:
- New timing belt kit installed
- New front crankshaft case seal and crankshaft seal
- New VC gasket, spark plugs, oil change
- Replaced turbo oil feed line crush washer
- Serviced DV and cleaned intercooler
- Replaced ripped turbo inlet pipe
- Replaced vacuum hoses
- Bead blasted and clear coated VC
https://www.youtube.com/watch?v=NdxzSuMZmZg
I might have to check out the CRC stuff, but trusty old regular WD40 has never done me wrong.
Thank you!
Today I received an AWE boost gauge that I bought off Audifurdasleben. He said it was making a rattling noise and that AWE said it couldn't be fixed.
Can't be fixed…can't be fixed?? Well, I had to give it a shot, and I was successful. Took about an hour, but it works beautifully now.Quote:
Also talked to AWE some more and their gauges are sealed so the vibrating that its making under boost can't be fixed, sad but oh well.
The gauge arrived with the needle pointing at 10inHg. After doing some extensive high quality testing (shaking it) I determined that the needle had come loose from the gauge's shaft.
http://i346.photobucket.com/albums/p...psa4d900f5.jpg
So now the question was how to take it apart. After some more testing (trying to pull it apart) I figured out that the front cover bezel was crimped on over the metal housing of the gauge body. I was able to use a small flat blade screwdriver to carefully pry up the edge of the crimped bezel to free it. Thankfully it's made out of aluminum so this was not hard.
http://i346.photobucket.com/albums/p...ps42f8f9ff.jpg
Here you can see the raised lip on the gauge housing. The bezel has to slip over this rim.
http://i346.photobucket.com/albums/p...psd29242bd.jpg
And success! After popping the front cover off the needle immediately fell off to the side.
http://i346.photobucket.com/albums/p...ps46079509.jpg
The needle is a simple press fit and lacks any locating tabs, so I just put it at 0 and pushed it on. I then pulled the gauge from my car and tested it and it worked but the needle was very jumpy, not smooth. I pulled the needle off and pressed it back on but not quite as hard. Tested it again and it works beautifully.
http://i346.photobucket.com/albums/p...ps10021d00.jpg
I used the flat blade screwdriver to press the bezel's edge back into place. It's not nearly as tight as it came from the factory, but it will do just fine.
http://i346.photobucket.com/albums/p...ps6cf27d58.jpg
Reassembled.
http://i346.photobucket.com/albums/p...ps7a1770f4.jpg
http://i346.photobucket.com/albums/p...ps4e132832.jpg
What makes it even better is that the lower edge of the bezel sits inside the gauge housing, so you'll never see the marks from removing and installing it.
http://i346.photobucket.com/albums/p...ps7a3b9984.jpg
I'll write up a DIY article for this later for anyone else who runs into this problem. I searched and wasn't able to find anyone else who had disassembled an AWE gauge before.
Time for another update. A couple months ago my air compressor blew its head gasket. I could get the tank up to 100psi, but no more. I finally got around to rebuilding it and it runs better than ever now. Doing this very simple rebuild makes me want to build my actual motor even more.
What I found when I pulled the head off.
http://i346.photobucket.com/albums/p...psd70b428d.jpg
All clean!
http://i346.photobucket.com/albums/p...psb27e532a.jpg
http://i346.photobucket.com/albums/p...ps9f70a34c.jpg
http://i346.photobucket.com/albums/p...ps5a012814.jpg
http://i346.photobucket.com/albums/p...ps08969528.jpg
Rebuilding the air compressor was necessary before I started work on replacing the clutch in my brother's 2000 1.8T. More info about that job in his build thread here.
http://i346.photobucket.com/albums/p...ps0667476b.jpg
In news more relevant to my own car, I'm very close to saying that "stage 1" of my engine bay is complete. One of the last pieces of the puzzle was getting a euro Passat driver side engine cover (part number 3B0 119 487C.)
http://i346.photobucket.com/albums/p...ps9668d61b.jpg
The cover is not a drop in piece though. It took a bit of fitting and problem solving to get it to sit in place properly. I'm still fussing with it, but it's very close.
The first thing that needs to be trimmed is where the cover contacts the throttle body.
http://i346.photobucket.com/albums/p...psd2b45ebe.jpg
I cut out the corner with a jig saw, hand filed it smooth, and rounded the corner off.
http://i346.photobucket.com/albums/p...pscf3adbda.jpg
A notch has to be cut near the upper radiator hose, and I was also getting some contact near the windshield washer tank. I cut a 2nd half moon near the windshield washer tank as well as shaved the lower circle of the washer cap down flat on the side. With the cover sitting properly at the bottom, it leaves a 3/4" gap near the firewall. This is not the end of the world, it's not very noticeable unless you're looking for it, but I'll probably try to fit a piece of weather stripping at the upper edge to seal it off.
http://i346.photobucket.com/albums/p...ps4defc979.jpg
The last problem was finding a way to make it sit flat. The middle of the cover hits the lower right corner of the ABS pump and acts as a pivot point. I didn't want to drill into the cover if I could avoid it, nor did I want to modify my car in some way that was not reversible. I wanted to be able to remove the cover easily as well. What I came up with was using two bar magnets wrapped in electrical tape and topped with a piece of velcro. The magnets are placed next to the hood shock and hold the top right corner of the cover down to the proper height so it's flush with the hood's weather stripping.
http://i346.photobucket.com/albums/p...psa4d9eafb.jpg
The end result.
http://i346.photobucket.com/albums/p...ps165bfd2c.jpg
http://i346.photobucket.com/albums/p...ps618a8097.jpg
http://i346.photobucket.com/albums/p...ps20dc4d42.jpg
Got a set of Apikol street rear differential carrier bushings. I was very surprised at how soft they are, without the metal insert in place they can be squished pretty easily. I expected them to be much stiffer but them being soft is not necessarily a bad thing since I'm a bit worried about excessive noise with these, but we'll find out when I get them installed. If they're too noisy I'll step down to 034 SD carrier bushings.
https://97-a4-b5-18t.s3.us-east-2.am.../DSC08111.jpeg
BaseDrifter updates [hail][up]
Haven't checked your thread in ages, but you've done some pretty awesome and neat jobs on the b5's! Before and after pics of greasy / clean parts are always awesome to look at [:D]
Really like all the work you've done. Everything is so clean.
Checking your build thread always makes me think twice about parting with my car.
