Will the B8 A6 3.0t fit and bolt up to a B8 A5 6sp?
Printable View
If you're trying to swap the A5 6spd transmission into the A6, it won't work even if the transmission bolts up to the motor because the transmission has the front axle outputs in the wrong location. The correct transmission for a C6 chassis would be an 01E or 0A3, but AFAIK there is no tune for a C6 3.0T manual transmission available.
