Going to be changing my oil on my 2016 Audi S6 C7.5 and couldnt seem to find the torque specs for the drain plug anywhere. If anyone could help me out it would be greatly appreciated. Thanks!
Printable View
Most aluminum plans are between 23-25ft/lbs. What I would do, sharpie the bolt and pan so you have an idea of the original spot. From there, drain as usual and use a new crush washer. Then torque to 23-25ft/lbs and you should be very close to the original sharpie mark. I know dealerships do this with oil canister style filters.
SM says 30 Nm = 22.1 foot-pounds
Which SM?
Mine says 20Nm = 15 ft-lbs. in both the maintenance section and the Engine repair overview diagram.
Also the Amsoil website has pretty good references for drain plug torques and confirms 15 ft-lbs.
https://www.amsoil.com/lookup/auto-a...rbo/us-volume/
Désolé . -- did not notice the question was for an S5
Désolé *3 . keyboard is fighting me ! -- did not notice the question was for an S6
For reference....
Audi S6/S7 4.0T
Audi # N0160276 Oil Drain Plug
Audi # N0138157 M14 Oil Drain Plug Crush Washer
Oil Drain Plug Torque value is 20 NM (14.75 Ft-Lbs) for 4.0 TFSI (corrected)
Easy to change oil filter on ramps. Remove lower panel cover. There is a small allen head screw to allow draining the filter housing before removal.
Use a 32mm socket to remove oil filter housing.
There are one O-ring for the filter one O-ring for the housing & one O-ring for the small drain screw.
Oil filter housing drain plug torque is 4NM (3 ftlbs).
Oil filter housing torque spec. is 25N (18.4 ftlbs)
Oil filter (Mann) Audi OEM # 079198405D
8.7L (9.2qt) VW 502 oil
