Registered User
Two Rings
2005 s4 avant stage 2 PES supercharger
Ok so people said i should start a thread with my info and specs.So here it is and no im not an english major so might be run together some.It was purchased out of nj in June thinking chip intake and exhaust would be enough.Well i was wrong having owned many 300plus hp vws and a4 avant started looking for the forced induction fix.I looked at all the options there are supposed to be like 4 or 5 different options but none really surfaced or put down any numbers.Then when i sold my 2000a4 avant it was time to buy and PES came to market on time.Had the kit for prolly a month before it actually went on car.So here ar the specs.Want to know anything about avant ask.
2005 s4 avant 6spd
bilstien pss9 coilovers
Stratmosphere intake
JHM intake spacers
JHM short shifter
Apikol snub mount
20% tint and 35%on front
ebay heat exchanger bigger than came with kit
PES stage 2 supercharger
3" downpipes and exhaust with x pipe
18x8.5 rs4 reps
12.77@110
Registered User
Four Rings
Why did you get bigger heat exchanger?
Registered User
Four Rings
Nice setup. You definitely need to post a vid for a good sound clip.
REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
Registered User
Three Rings
Registered User
Three Rings
Nice.... good 60ft and 12.77 @110? -> the fastest yet  .... post this up in the faq's & diy
CLEARING OUT THE GARAGE -> TAKING OFFERS!
HRE COMP 90 (MACHINE) 19 x 8.5
O.Z. ULTRALEGGRAS (BLACK) 20 X 8.5
TSW CATALUYNA (GUNMETAL/SILVER LIP) 18 X 8.5
KW v3 FOR (B6/B7) S4 & RS4, B6/B7 F.I. DOWNPIPES W/ CATS, B7 RS4 GAUGE CLUSTER, B6 & B5 A4 BLACK INTERIOR, B5 A4 FRONT AXLES, B5 S4 FRONT AXLES, B5 A4 AXLES, B5 A4 MOTOR MOUNTS, B5 CONTROL ARM SET & MORE......
Registered User
Four Rings
mpg's lol
Registered User
Two Rings
The reason for the bigger heat exchanger is the same as on cobras with similar charger more coolant cooler intake temps more power and i do track days and that takes its toll on a car and creats more heat.Thanks for all the props still in progress NEEDS bigger brakes.
Registered User
Four Rings
I think we need a bigger coolant tank. The one that PES provides is small.
Did you notice any difference with bigger intercooler? Did you log it? How much of the temparature drop did you notice?
Registered User
Three Rings
Is that exhaust custom made?
Registered User
Three Rings
It must be. Look at all those welds.
OP, That's one fast Avant you have. Do you have any plans for reducing the rotating mass (i.e. lightweight rotors, lighter wheels, jhm pulley, etc)?
Registered User
Four Rings
Good stuff bro. Not sure you needed the 3" exhaust but it works I guess.
Love the continued modifacation to the system. Props to that.
The 355/385.. not the strongest numbers but I think this may be one more reason why I tend to shy away from dynos. Bottom line with a 110mph you could get a 200whp dyno reading for all I care. Performance is there
Agent 91 to the bat cave we have 2.0T and 2.7T crime running out of control.
AMA member
USMC member (active)
Facts first member. Built and supported by many
Registered User
Three Rings
If so, I'd like to know where he had it done as he's local to me and I'm looking to get an exhaust fabbed up on my car.
Registered User
Four Rings
no doubt!
Awesome Ride!!
I don't know how to tell you this,but ........I 'am kinda a BIG deal! People know me.
Registered User
Four Rings
Been reading through the drama on the other S/C threads... really like this one since it is clean and has everything with pictures to support it.
Your car is very tastefully modded and dang fast! Congrats.
Registered User
Four Rings
Registered User
Three Rings
what kind of intake is that?
Registered User
Four Rings
Look at the original post.
Registered User
Three Rings
clean your car!!! i hate when ppl dont take care of their car. but yet put all these upgrades into it.. bring it over to nj again ill detail it for freeee
Intake spacer, clear corner mod, custom suede trim, Awe non-res. cat back... more to come
"speaking my mind isn't an act. nor is it a product of me allowing myself to be a con artist, but it is simply to express something that i suppose shouldn't be held in."
Forum Moderator
Four Rings
Absolutely awesome. Way to represent for the Avants (and B6's). I'd also like to echo Eye4Speed's post above...way to go on being up front and clear from the start.
P.S. - put your rings back on the front.
Registered User
Three Rings
Registered User
Two Rings
Did just clean it went to a get together for the sagball rally going to oc tomorrow and took a few people for rides then it stormed it a$$ off.Clean the Blue really looks deep.Exhaust was done locally in greatbridge.
Registered User
Four Rings
nicely setup car.
have you considered going back to the stock airbox? also, i'd put the rings back on the front.
05 S4 6MT Light Silver/Black-Silver Alcantara
BBS LM 19 x 8.5, Nitto Invo 235/35/19 tires, H&R coilovers, H&R rear sway bar, Hawk HPS, Goodridge ss lines, Oettinger bumper, Oettinger sideskirts, Milltek downpipes, Fast Intentions 8" resonated X-pipe cat-back, GIAC tune, Stratmosphere short shifter, ITG air filter, Huper Optik 40% tint, E-codes, Phillips Ultinon 6K bulbs, RNS-E, Euro RS4 steering wheel, RS4 pedals, RS4 shift knob, RS4 e-brake cover, LED license plate bulbs, Vag'd.
Registered User
Four Rings
English please?
Stage 1 Advertiser
Three Rings
 Originally Posted by Todeshandler
English please?
He did just clean the car than went to a get together for the sagball rally . While there he took a few people for rides. Than it stormed it ass off.
He is going to Ocean City Maryland tomorrow.
When clean, the blue really looks deep.
The Exhaust was done locally in Greatbridge.
Forum Moderator
Four Rings
 Originally Posted by drew
nicely setup car.
That's what I said!
Registered User
Three Rings
Patrick, I thought translation services only came with Meth injection installs
2005.5 S4 | PES Stage 2 G4 supercharger| Labree Catback | piggies | PSS9s | RS4 rep 19"s | K&N
Registered User
Four Rings
i never really liked avants, but DAMN your car looks hot
Stage 1 Advertiser
Three Rings
haha. I was sorta bad with my writing also. It got better when I was a flat rate technician. The better your writing the more you got paid. That would make anyone a better scribe.
P.S. Was that Meth Injection comment a hint at something? haha
Registered User
Two Rings
Patrick are you going to be in tomorrow?Of course meth inj. is next to see if i cant hit 12.5sor better before track closes down for winter.
Stage 1 Advertiser
Three Rings
Ya, Ill be in. We have been out of town for the past week and I'm just getting back to all the phone calls and e-mails. Its ALOT
Forum Moderator
Four Rings
Congrats to PES and VWrcer
AMA and YES! Together we can all defeat 2.0t and 2.7t crime...
And lastly for the grammar police that are bound to step in
I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
Registered User
Three Rings
Yes, congratz to PES and vwrcer. Newb question coming. Does the SC only kicked in at a certain rpm or triggered by how much you depress the accelerator?
B6 S4 | MT6 | F.I. Full Exhaust | ECS Snub | JHM LW Rotors | JHM Chip | JHM SS | JHM LW Pulley | JHM Stage III Clutch | LW OZ Ultraleggeras | K&N Filter | Uber Cabracco85 MAF MOD
Registered User
Four Rings
Registered User
Three Rings
Thanks. So from what read and understand, it's basically always on.
Registered User
Four Rings
Is that 60ft a 1.8 or a 1.6?
Registered User
Four Rings
Holy sh1t!!!! Your avant is my car's evil twin!!!!!
See what happens when you go to Chi-town for a trade show for the week...almost overlooked this thread.....congrats on the great times!
2004 B6 S4 Avant 6MT Moro Blue - mostly stock for now
1998 VW GTi-VR6 - mmmmm....listen to that VR6 growl! -sold-
Registered User
Four Rings
can someone say sleeper. who would ever think that an avant would hold the record congrats!!! she is 1 sexy beast
Phantom black, Titanium pkg, 35% tint, H&R springs, Tinted tails, Demon eyes, Forge DV, Revo flash,
My name is Shnab, and I shnab bitches
Registered User
Three Rings
English please?
Jealous?....
Registered User
Four Rings
i do track days
Are you by any chance going to be at the Audi club track day at VIR? Would love to see this beast in action!
05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
The only standing start, straight line racing I enjoy is on the way to the first corner.
Registered User
Four Rings
 Originally Posted by blkonblkS4
Jealous?....
I can see this thread going south like mine did already...LOL
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
