Registered User
Three Rings
I want this...
It has no real purpose and it's almost $200... must have it. Do you think it'll install ok with just that set screw? Don't our's have a one-time clip holding them on?
Then: '87 Grand National
Now: '03 1.8TQ5spd Sport Pkg
- REVO'd - Lower'd - Podi'd - FMIC'd w/ 034 Tubes - Magnaflow'd - To be continue'd...
Registered User
Four Rings
yes it should be okay because the shifter has a grove in it, you worried that you wont know what gear you're on??? :-P
Summer setup: Low Rider!!!
Winter setup: snow plow
Registered User
Three Rings
Hahaha! Yeah, I have this repeated problem going 1-2-3-4-1... kidding :)
If someone had told me about this, I wouldn't have liked it... but seeing it, yeah I want it for no reason other then I think it looks kinda cool
Registered User
Four Rings
Kinda snazzy. But true, i don't recall the last time i even looked at my stick to see the gear layout.
FCDT Member #1
-Matt
Official GCC Pirate
Registered User
Three Rings
Yeah, if you can't tell by
A)Feel
2)Engine sound/rpm
Then you might want an automatic.
Registered User
Four Rings
haha that is pretty cool looking..
"You just got killed by my Daewoo Lanos"
Registered User
Four Rings
2004 Audi A4 1.8T // quattro // 6 Speed // Brilliant Red
Magnaflow 16601 Exhaust
Racetec FMIC
USP Front
VMR V708 in Gunmetal
VMR Vent Boost Gauge
Registered User
Three Rings
According to the ad you just need to supply pwr and ground... then run it through a learning phase where it learns where each gear is by running it through the gear pattern
Registered User
Three Rings
I think this is great! I mean really you don't need one (unless of course you really are having shifting issues, which I prey for all of our sake that you dont) but it is pretty sweet... I Kinda want one.
Registered User
Three Rings
^^^ Just as long as it fits well with the factory boot and trim ring, I'm all for it... Who's getting the first one?
Registered User
Four Rings
I like that shifter a lot too. I would never use the display, but it is pretty cool looking.
Registered User
Three Rings
Registered User
Four Rings
I think the only time the display changes number is when you actually change gears.
Johan
"A bear wont listen to your complaints, it will just kill you"
GCC Law/Rule #22 Enforcer.
Registered User
Three Rings
Yes. You are correct sir.
"A revolutionary product! This universal shiftknob with LCD display is not only good for looks: it also increases driving safety and helps reduce fuel consumption by up to 15 percent by means of an adapted driving style.
This shiftknob fits all cars with manual transmissions up to 6 speeds (i.e. will work with 2sp, 3sp, 4sp, 5sp 6sp etc.)and is designed to work with every gearshift pattern.
(Does not work with cars that have gear levers with reverse gear locking mechanism). If you have to push down for reverse that is fine, what this means is that you just cannot have any type of switch that is part of your current OEM shift knob that must be switched/engaged etc. to get into the reverse gear.
A light sensor in the Indy-Cator adapts the brightness of the digital display to the surrounding light by means of an automatic dimming function, ensuring optimal readability at all times.
The connection to the cars power supply and gear assignment programming is very simple, and of course the shiftknob comes with detailed instructions for installation. It does not require wiring into the transmission, ECU or any other module of the car!
Available with red, blue or green display."
I love the the claim that it'll save gas
Registered User
Four Rings
Oh, and for anyone who may want to know, TMTuning is the shit.
Also, if you're looking for any Euro-spec parts for your car (trunk, etc.), they can get it. They might not have it on the website, but just send them an email and they'll get back to you.
Won't your hand be covering it anyway while your shifting!?
Registered User
Four Rings
revo ATP GTRS DELPHI Forge NEUSPEED RACE TEC F5FUJITA
13.577 @ 102mph w/ full interior, passenger, 3 bald tires at random psi, stock clutch, 93 octane, t7, 22psi, and first time to a dragstrip
Registered User
Four Rings
its cool and all but there are better ways to blow.. i mean spend :) money on our cars...
05 1.8t 6mt | itg filter | bailey dv | UNI flash | USP front | e-codes | stay tuned
help me buy more parts!! Any work you need in SE PA area on your car or with construction let me know!! (PM me)
Registered User
Three Rings
Good point... someone buy one and I"ll buy it from you in a few months used for less $$
Registered User
Four Rings
That money would be much better spent on a TIP and like someone mentioned before it would be covered most of the time. I can't find a better shift knob than the OEM, imo.
Another silver B6
Go: APR K04-015 ~ ABD CAI ~ Neuspeed Xtreme TIP ~ Forge Splitter ~ Neuspeed turbo-back ~ B&M SS ~ H&R Sport Springs ~ Bilstein Shocks ~ VMR Vent Gauge ~ S4 F&R Sway ~ Eurocode FMIC ~ S4 Recaros ~ Dr/Sltd Adams Rotors
Show: USP Front ~ Lamin X headlights ~ Cupra Splitter ~ Oetty Grill ~ S4 Trunklip ~ Euro Roof Spoiler ~ D1S HIDs ~ Silver Interior ~ LED Tails/Licence ~ RS4 Reps ~ S4 doorblades ~ B7 rear valance ~ LED fogs
Registered User
Four Rings
 Originally Posted by Molotov
depends on your grip
the best(read: correct) grip is clasped around the neck of any shifter. not on top of the head
that's what she said
those artists in black and white photos --Kanye West, is a fucking douche
Registered User
Four Rings
"A revolutionary product! This universal shiftknob with LCD display is not only good for looks: it also increases driving safety and helps reduce fuel consumption by up to 15 percent by means of an adapted driving style."
LOL
Registered User
Four Rings
Got a Cupra Lip from them awhile back. Good stuff.
FCDT Member #1
-Matt
Official GCC Pirate
Registered User
Four Rings
Wouldn't it be quite dangerous to dip your head to look at the display while you're driving? :|. Maybe this mod is more for the passenger to look at haha
034 GT28rs, 034 exhaust manifold, Unitronics, Borla v1, Vis CF, 35%/5% tint, Blitz, 6500k HID, Carbonio v2, 18x8 Rs6, AWE Vent, A8 bbk, Valeo Ecodes, S4 front, Forge 007, Racetec, 550cc, 034 hfc, KW V1 -weekend car
TEAM|AXION
Member #2 ( in terms of AZ join date :D)
Registered User
Three Rings
last time i checked the palm of my hand would be where the number reads out. so it does nothing for me.
Registered User
Three Rings
might as well add some neon LED's under your dashboard too. biggest waste of money IMO.
02 black/black 1.8 5 speed
cold/sport package
RNS-E APR stage 1
92 gvr4-snkkky
03 r6
Registered User
Three Rings
same here.... i still want it. haha why do want to blow my $$ on this crap.... ahhhh
Registered User
Three Rings
2005 Audi A4 USP 6spd |Revo Chip|TT 225 Injectors|Evo MS Intake w/ modified stock ram air|Samco Hoses|Forge TIP|Forge DV|VMR TP|Custom SS 2.5" Magnaflow Exhaust|ECS Snub Mount|KW V2 Coilovers|BBS CH's|3.0 C/D, Slotted Rotors|USP Front, Rear Spoiler and Interior Trim|Cupra R Lip|B7 Rear Valance|Grilles|E-Codes|S4 Mirrors and Door Blades|S/w Boost Guage w/ Podi Steering Column Pod|
Registered User
Four Rings
Few more pics from tmtuning.com
if u could get that one without the cheezy LED gear # ide be all over it.
Registered User
Four Rings
It'd be cool if it could talk too... "you're in third gear, fool" <-- that's the Mr.T option.
|| Bridgestone | Volk Racing | STāSIS | ÖHLINS | Brembo | Unitronic | EuroGEAR USA | Rawtek | DTH ||
Disclaimer: Read this post at your own risk. The author is not responsible for any hurt e-feelings.
Rawtek - Top quality custom mandrel bent manifolds, exhaust & intercoolers.
Registered User
Four Rings
haha!
or maybe a Woody Allen one
"4th gear? oh.... now that wouldn't be my first choice. do you, now do you really think 4th gear is the optimal gear for this speed?"
Registered User
Four Rings
^ or like if you miss a gear Mr.T says "i pitty the fool"
Registered User
Two Rings
eurocode out here in socal had a demo set-up they used to keep in their lobby. it's actually pretty nice looking while switching the gears. the only thing i didnt like about it is that when you have it in neutral the LEDs make a figure 8 motion.
Cal State University Dominguez Hills
Registered User
Four Rings
Forget this cheesy stuff, I would love a Whalen shifter however... those things are magical.
Registered User
Four Rings
I have a TMTuning shift knob and the fit and finish is perfect. Blends perfectly with the brushed aluminum trim.
And night that bitch lights up.
I tapped into the interior light circuit so it dims with the rest of instrument cluster.
Registered User
Three Rings
i think it looks rather classy
| K04 Turbo upgrade | APR Chip | Miltek Catback exhaust | Miltek Hi-Flow Cat | Diverter Valve | Bilstein PSS9 Suspension | HR Sport front and rear sway bars
| Carbonio Air intake | Bigger Injectors | 18'' R8 Reps | Some stickers and Tint  |
Registered User
Four Rings
Hottness, that trumps the OP's shift knob
Registered User
Four Rings
Registered User
Three Rings
[IMGhttp://forums.audiworld.com/picture.php?albumid=98898&pictureid=198958[/IMG]
[IMGhttp://forums.audiworld.com/picture.php?albumid=98898&pictureid=199394[/IMG]
that shit should be OEM
--James--
2005 Audi A4 1.8T M6 Quattro UltraSport
APR Stage 1--Carbonio CAI--NGK BKR7E Plugs--Forge SPLT-R--PODI
USP CLUB MEMBER #1111
Registered User
Four Rings
well, mine as well whore mine... blurry night pic, but you get the idea.... I absolutely love it! Its round too, which is a must for me. I cant stand any other shape shift knob.
2002 A4 Avant:// PODI with VEI digital gauge// Carbonio hot air intake// 19x9 RS6 reps// KW Variant 3 coil overs// custom turbo back exhaust with magnaflow 14851's// RS4 rear sway// S4 door blades// Ebay ecodes// Carbon Copy carbon fiber trim// RS4 pedals// RNS-E// S-LINE TT steering wheel......
fitch303 "edit: foul language screener will block c,u,n,t but not bitch? fucking funny shitbag mother fucking pussy son of a bitch, hmmm weird."
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
