Results 1 to 15 of 15
    Veteran Member Four Rings itsdarrow's Avatar
    Jan 27 2006
    Nyc
    Angry signs of a bent rim?
    besided visually looking seeing a bend, would it wobble while on the car? like when the car is jacked up and i spinn the wheel manually would it wobbleling mean the rim is bent or something more serious? would an alignment do that
    black B6 a4, 18x8.5 anthracite bbs ch, Full frame gt28rs kit, Unitronic 440 file, high on meth.
    Registered Member Four Rings A4 ABT's Avatar
    Feb 23 2004
    03 A4 1.8T Quattro
    Sunshine state
    looks like a bent wheel.
    find a good wheel repair shop. Shouldn't cost a lot to have it fixed!
    '03 A4 1.8t Quattro
    Exterior:USP front w/ Kerscher splitter--ABT sides--Votex rear--S4 trunk spoiler--S4 Door Blades--Euro blindspot mirrors--19" ACE Klassik
    Brakes/Susp.:NS rear swaybar--Audi Sport Suspension--NS brakelines--ECS OEM 3.0L brakes--Hawk pads
    Engine:GIAC K04--Genesis 380cc injectors--Okada CP--AWE Tuning FMIC--APR stealth exhaust--ER Test Pipe--Carbonio V2--Forge Splitter--Forge TIP--NS snub mount--ECS Stage 3 Clutch
    Interior:AWE Tuning Boost Gauge
    Feb 13 2006
    B6 3.0 Quattro (RIP), E55 AMG
    Bad hub-bearing? how does it sound when you drive...
    Black B6 A4 3.0 QMT6 (RIP)
    Black C5 S6 Avant (For Sale)
    Black W211 E55 AMG
    Veteran Member Four Rings gohan's Avatar
    Items for Sale
    depending on the bend,
    vibrations at high speeds.
    steering wheel would wooble with the car.
    Veteran Member Four Rings flyinb501's Avatar
    Apr 18 2005
    '02 Audi A4 1.8TQ MT5, 2000 CB
    Minneapolis, MN
    Items for Sale
    What he said. Also, you should be able to see it. It may be on the inside of the wheel so you can take each one off and look for bends.
    '02 A4 1.8TQ MT5: Revo tuned k04/ Eurocode FMIC, testpipe/ Neuspeed exhaust, snub, SS/ Forge DVR/ 19" Sevas/ S4 blades/ Painted Lowers/ VDO boost gauge/ Tein springs/ Lip spoiler/ Blackout grilles/ Icelink/ Alacantara shift boot
    Veteran Member Four Rings Duchenbagen's Avatar
    Feb 29 2004
    ATL/FLL
    This is a pretty good sign of a bent rim...
    John
    USP CLUB MEMBER #5
    How much does the illusion of integrity cost?
    Jan 27 2006
    Nyc
    well its on the rear driverside, and it doesnt make any noise which is y i think its bent, just wanted to make sure, is there anything diffrent about fixing a bent bbs rim since they are forged?
    Veteran Member Four Rings akademiks120's Avatar
    Nov 27 2005
    San Francisco, CA
    you bent a bbs rim?? wow....thats the first time i heard of that happening.
    Original Member of the 3.0 Club
    2002 Audi A4 3.0Quattro 6spd - Brilliant Black
    No fat chicks......the car WILL rub.
    Jan 27 2006
    Nyc
    welcome to new york! they were 18s too, and not even low pro tires
    Veteran Member Three Rings h_curtis's Avatar
    pittsburgh
    If your rim is bent you should be able to tell if you rotate you wheel while jacked up. The problem is it may be bent on the inside and that will make it much harder to see. There are more than one type of bend. It can be hit hard and have a dent or it may be out of around which is very hard to tell unless you put it on a balancer. Spinning on a balancer you can see if it is out of around.
    Of course many factors can be in play if you have a wobble. Of course check the lugs to make sure they are tight. Did you use fix-a-flat? If so, that could make your wheel go out of balance. I know first hand and will never use that again. I was like 19 years old and am now.... 40. You could have thrown a weight. There are other possibilities, but this is something to look at first.
    People keep saying you can fix a bent rim. I am not sure you really can. I would like to see a link to some place that fixes them if they are out of round.
    '14 s5, 6sp, sport diff, b&o, panda, estriol blue
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    if its not a circle ur rim is probably bent, i say 90%
    Jan 27 2006
    Nyc
    yep i think its out of round, because when i spinn it while its jacked up it wobbles kind of in and out thats the best way i can explain it, you think it being out of balance would make it wobble?
    Veteran Member Four Rings A4Shizl's Avatar
    Jun 11 2004
    2003 Audi 1.8T, 2005 Honda
    Inland Empire
    Ask and you shall recieve....
    Jan 27 2006
    Nyc
    word a4shizl ill check them out
    Jun 11 2004
    Inland Empire
    only problem for you my friend, is this shop is located in SoCal. However, I'm sure there are shops in your area that can get the job done...
    good luck...
