The $20 Ebay Vag Com Cable Walkthrough
This tutorial is Part 1 of 3.
What this section covers:
I chose to start with SWITCHING COM PORTS, since this is one of the biggest "hurdles" in getting this cable to work. This tutorial assumes you already plugged in your cable and installed the necessary drivers from the supplied CD. The CD already comes with a detailed walkthrough regarding driver install, however if there is enough demand I will make a 4th part describing this process. If you need the drivers, you can download them as an .iso image here:
http://www.sendspace.com/file/fo0mhb
mirror:
http://www.yousendit.com/transfer.p...1F02FDD0EF90F20
Tools:
Windows Laptop w/ cable drivers installed and an open USB port
Time:
5 minutes
PART 1: SWITCHING COM PORTS
Step 1:
This tutorial assumes you already plugged in your cable and installed the necessary drivers from the supplied CD. Begin by CLICKING the "Start" button, RIGHT CLICKING the "My Computer" button, and finally CLICKING on "Properties". For those into using keyboard shortcuts, you can hit "Windows Key + Pause/Break" to get to the "System Properties".
Step 2:
You should now see the "System Properties" window. CLICK on the "Hardware" tab, then CLICK on the "Device Manager".
Step 3:
This will bring up the "Device Manager". This is an invaluable tool used check on the status of every piece of hardware connected to your machine. Scroll down until you see "Ports (COM & LPT)" and DOUBLE CLICK to open this section. Inside should be "USB Serial Port (COMX)". DOUBLE CLICK on this to bring up the "USB Serial Port (COMX) Properties".
Step 4:
Now that you are in the "USB Serial Port (COMX) Properties", CLICK on the "Port Settings" tab and then CLICK on the "Advanced..." button.
Step 5:
This opens the "Advanced Stettings..." Start by CLICKING on the "COM Port Number:" drop down menu and select "COM1". If COM1 is "in use" select the next highest number, but it HAS to be in the range of COM1-4. Later we'll go into the VAG COM software options and change it to what we picked here. Finish up by CLICKING on "OK" in the 2 windows.
Notes:
The changes have been made to the COM Port, but I wanted to call attention to the fact that it may not reflect the changes in the Device Manager, until you close and open it again or refresh.
Also, if you plug the cable into another physical USB port, it may change the COM Port. If this is the case, simply repeat these steps.
