Results 1 to 6 of 6
Thread: Cup kits
    New Member Two Rings
    Nov 21 2004
    FL
    Cup kits
    I've been doing a lot of research on a suspension setup for my B5 2.8 Fronttrak. I mostly want a good looking drop with a still compliant ride, not too harsh. I'm not concerned about track-car handling or the such....so I've pretty much ruled out coilovers due to price. I'm looking to spend between $500-$600.
    I've read some good things, but mostly bad things about H&R's cup kit, matched springs and shocks. They seem to give a nice drop, but it's the ride I'm concerned about. Anybody with first hand experience and/or pictures? I welcome opinions and suggestions!!
    Thanks.
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    997S, B7 A4 SLine-Ti, B5 A4...
    Portland, OR
    Re: Cup kits
    Thanks.
    We don't sell them only because while they do offer a nice drop, the ride is not congruent with the other fine suspensions we sell (STaSIS).
    Unfortunately we've found many of H&R's products to be oversprung and underdamped, resulting in a pogo-ing/porpoising ride. It kind of makes you sea-sick.
    Why not look at a set of sport springs for now (although I would HIGHLY recommend you spend a bit more and get aftermarket dampers as well as by using just sport springs, your stock dampers will fail soon.
    Jeremy Williams
    Matrix Integrated Inc.
    Nov 21 2004
    FL
    Re: Re: Cup kits
    Thanks for the suggestion, Jeremy! I have actually thought about doing that, but I hear a distinct clunking, especially over speedbumps, that leads me to believe my stockers are on the verge of failure as it is. And I'm trying to time this so I can do it all at once (I'm doing my tie rod ends, brake rotors, pads, etc. in a few weekends). I'd hate to put some new springs on and have to go right back in there a month or so later
    May 27 2004
    Portland, OR
    Re: Re: Re: Cup kits
    Regarding the clunk, I would look at the strut bearings first. Or, possibly you have a bad control arm (more likely).
    LMK if we can help with anything.
    Jeremy Williams
    Nov 21 2004
    FL
    I replaced my TRE's this weekend and that seemed to help with the sound a little bit. The steering is certainly much more responsive. My OE ends were BAD!!
    If not the H&R kit, how about the suspension "kits" that arent' full on coilovers? e.g. Vogtland, Koni, etc.
    May 27 2004
    Portland, OR
    Ah, we always see vehicles come in with bad TRE's (and control arms; both clunk).
    Unfortunately we haven't used any of the other kits besides Bilstein/H&R, Koni/Eibach; standard damper/spring combos....which are ok.
    But the issue we have seen with those is that regarding ride height, you're stuck. Yes, you can get the grooved Bilstein's to aid in raising/lowering a bit, but still to some degree, it's not as flexible as a coilover is.
    Jeremy Williams
