    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Lightbulb B6 A4: How to change your rear diff oil
    Just finished this a few minutes ago, just thought i'd share how I went about it..
    One a scale of 1-10 (1 being easy, and 10 being hard) I'd give this "mod" a 2-3.. Hardest part is jacking up the car and putting it on jack stands.
    Tools/Supplies Needed:
    10mm hex socket
    3/8" socket wrench with a decent amount of extensions (No more than 12")
    1.5L of your diff fluid of choice (I recomend Motul's Gear 300 SAE75w90)
    Hand Pump
    Bucket to catch old diff fluid
    Jack+Stands
    Rags
    Step 1: Jack up car via the rear diff mount and place stands on either side of the car (Or use a lift if you have access)
    Step 2: Locate the 10mm hex bolt drain plug. Its super easy to find, its the only bolt on the bottom of the diff near the drive shaft
    Step 3: Using your socket wrench, losen the drain plug and let contents drain into bucket etc..
    Step 4: Replace drain plug
    Step 5: Locate the 10mm filling plug and losen.. Its located on the right side of the diff towards the back of the car (Plug faces the right rear wheel)
    Step 6: Using your hand pump, pump in about 1.5L of gear oil.. If you had a crappy hand pump like mine, it should only take about 10-15 mins to fill the diff. You'll know the diff is full of fluid, because it will start to dribble out of the filling plug. (I also recomend keeping track of how much you've pumped in via the scale thats on the bottle)
    Step 7: Replace filling plug and check to make sure both the filler plug and the drain plug are tight.
    Step 8: Wipe away any spilled gear oil and your done!
    I will be changing my tranny fluid tomarrow, so look for another write up!
    New Member Two Rings CuStOm's Avatar
    Dec 08 2005
    Portland, OR
    Good Job!
    I've totally been thinking about doing this. I have a couple of questions:
    Is the rear diff factory filled with synthetic?
    What about the center diff?
    You say you are doing your tranny, do you have an MT? Are you gonna do a write-up on it also? What fluid you gonna run there?
    Thanks for your time!
    USP CLUB MEMBER #666
    2004 USP 1.8T, K04, REVO, the list goes on.
    Palo Alto, Ca
    Yea, the factory rear diff oil is apparently a synthetic of some sort.. The center diff fluid is shared with the tranny fluid, and i will be using the same Motul as i used in my rear diff.. I do have a 5 speed..
    I would like to do a write up on changing the tranny fluid, but i looked at the drain plug last night and its a super weird bolt that ive never seen before.. It looks like the multi-pointed torx bit that are used for the head studs, but it has a a little bump in the middle.. Hard to explain, but in sort i dont have the bit for it so i'll have to go hunt one down..
    Veteran Member Three Rings Gallep's Avatar
    Mar 22 2004
    2004 A4 USP
    Colorado Springs, CO
    Re: B6 A4: How to change your rear diff oil
    Quote Originally Posted by Saturnine View Post
    Sounds like a Tamper-proof Torx.
    Veteran Member Three Rings quattroism25's Avatar
    Jun 04 2007
    04 S4, A4 2.8Q, Acura Legend TypeII
    Bronx/Westchester
    Just thought I'd add...Before you pull the drain plug its best to loosen the fill plug first. You don't wanna drain the oil then find that the fill plug is stuck, stripped or whatnot, then you'll really be fvcked.
    WTB 19" BBS RS-GT
    MORO BLUE FTW
    Labree Catless DPs ~ Labree H-pipe Catback ~ Airbox Mod w/K&N ~ JHM Intake Spacers ~ JHM Tune w/Launch Assist ~ JHM Shortshifter ~ JHM STG4 Clutch & LWFW ~ KW V3 Coilovers ~ Hotchkis Swaybars ~ Apikol Rear Diff Mount ~ 19" Neuspeed RS10 ~ Thor Skidplate ~ RNSE Navi ~ Piano Black Trim ~ OEM RS4 Deadpedal ~ RS4 Shifter ~ RS4 Brake Handle ~ AWE Pedals ~ 20% Tint ~ HID Fogs
