Page 1 of 4 123 ... LastLast
Results 1 to 40 of 149
    Feb 17 2004
    Round Rock, TX
    Items for Sale
    Ultrasport lower with stock upper bumper how-to (lots of pics)
    1) remove bumper from car. remove lower "half" from upper. I put half in quotes b/c as you see, the upper part extends the whole height of the bumper:
    2) cut away any parts that will interfere with the ultrasport lower lip sitting flush. I used a utility knife and a dremel. I cut away more than I needed to it turns out, mostly from the section that separates the center grille area from the L/R grilles:
    this is about how much I cut away:
    here's a closeup of the trimming required near the fogs (same on boths sides so I'll just post one pic:
    make sure everything fits:
    the two center beams of the U/S lip (for lack of a better term) won't fit on top of the upper bumper because the curvature is a little different. You could cut them some, but I didn't want to lose any more structural support, so I didn't worry about it.
    once I was satisfied with the fit, I went ahead and painted black the areas that would be visible once the U/S lip was fitted, the fog surrounds and the 2 center supports. Note that you don't need to paint the fog surrounds if you are using the stock USP fog grilles.
    While I was waiting for that to dry, I went to work on the grilles. I used .75" expanded metal mesh from Home Depot, $15 or so.
    I created cardboard templates since I don't have the U/S grilles to use as a guide. It took a lot of trimming with the dremel, and after I was happy with the fit, I painted them with Plasti-dip rubberized coating ($5 at HD). 3 coats, 30 mins in between coats, let dry overnight. The center grille opening is 27" but the grille sheet is only 24" (largest I could find), so I had to use tiny zip ties and some epoxy to attach two pieces together. Fortunately the ends are cut right down the center of a diamond, so matching them up was no problem. I'd be willing to bet you can't tell where the break is.
    I used self-adhesive rubber door trim as a border for the grilles, don't have any pics of it separate, but it was about $12 for a 25' roll.
    back to the main event. Once the black paint on the stock upper bumper is dry, it's time to attach the U/S lower lip. I used a combination of epoxy, zip ties, and machine screws. I drilled one hole in each of the tabs on the U/S lip, 1 hole on each side of the two center beams, and two holes on each side where the U/S lip attaches near the fogs.
    After the holes were drilled, I mixed up some epoxy and spread it on the stock upper bumper on the areas where the U/S lip would overlap. Then I attached the U/S lip and secured it with the zip ties before the epoxy dried.
    here's the back side of one of the center beams showing the zip tie:
    here's another showing the back side of the fog lamp area:
    Next I drilled 1 hole through each of the center supports straight through the U/S lip. I used a small machine screw with washers on either side and a nut on the bottom (with threadlock of course).
    pic of the screw from the "top":
    and one from the bottom. I dremeled off the excess screws at the nuts after I took the pic
    and that's it for the bumper. There are NO issues with the U/S lip not being secure, even with the amount of cutting done. It doesn't wobble or sway or move an inch even at or above highway speeds.
    Attaching the grilles was pretty easy. I cut them to fit pretty eactly so they fit snugly and really didn't need anything to secure them, but I used a few tiny zip ties just to be sure. Sorry no pics of that as my camera sucks and none of them turned out. The side grilles you have to attach *after* the bumper is put back on the car unless you have mad skills.
    Here's some gratuitous pics of how it turned out, from various angles in the daylight:
    front:
    driver front 3/4:
    pass front closeup:
    pass side w/refinished wheels:
    and some more current pics, with blacked-out upper grille trim and S4 e-codes:
    Thanks for reading, and please post/email/IM me with any questions. I'm sorry more of the pics didn't turn out.
    **Disclaimer: semi-professional modder on a closed course. Do attempt this at home.
    2007 RS4 Sprint/Ebony, Ti, 109k
    JHM/Stasis/Milltek/oCarbon
    Veteran Member Four Rings A4 - Oh Snap's Avatar
    May 03 2004
    Irvine, CA
    Very nice. No one will ever know.
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Damn that looks nice
    Veteran Member Four Rings flyinb501's Avatar
    Apr 18 2005
    '02 Audi A4 1.8TQ MT5, 2000 CB
    Minneapolis, MN
    Items for Sale
    Wow, nice job. Huge improvement.
    '02 A4 1.8TQ MT5: Revo tuned k04/ Eurocode FMIC, testpipe/ Neuspeed exhaust, snub, SS/ Forge DVR/ 19" Sevas/ S4 blades/ Painted Lowers/ VDO boost gauge/ Tein springs/ Lip spoiler/ Blackout grilles/ Icelink/ Alacantara shift boot
    Oct 26 2005
    2003 A4 1.8T Quattro
    Chicago, IL
    super job.. seems like i hvae a new task for my bodyshop!!!
    just one question.. wouldn't it be possible to use the OEM fog grills?
    May 27 2004
    03 A4 QMtS 77 Blazer 4x4
    Sacramento, CA
    very nice, now get the blackout upper grill :)
    Jay
    Jay
    Veteran Member Four Rings Tinman's Avatar
    Aug 25 2004
    nice n' low a-fo, 2006 Saaburu, 1978 Corvette
    Fairfax, VA
    looks hot, matt! very nice. you should make those lower grills and sell 'em. heh, I'd buy one!
    L8
    ~ben
    no TURBO, no CARE.
    pics of the car: the original BB USP w/ gunmetal RS4s
    407awhp and 408awtq on a Mustang with 93oct and meth. still 1.8L
    GOT EFR? (543chp/544clb-ft)
    Twitter: t1nman
    That looks pro, good job. Definitely one of the better DIY grille projects.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    That's a great mod job.
    Excellent end reult and it looks sharp.
    Veteran Member Three Rings RASTA4's Avatar
    Feb 26 2005
    2002 A4 3.0
    Metro Detroit
    Nice work. Can't wait to see the matching upper grill. That sure beats spending +/- $1000 on a complete USP bumper conversion.
    |2002 3.0 SEDAN Q6MT|POLAR WHITE|PLATINUM BUFFALINO|SPORT|CONVENIENCE|COLD|BOSE|BNS-NAV|PARKTRONIC|SUNSHADES|ODO=34XXX|
    MODS
    |PES G3 SC|SUPERSPRINT|AFE PRO-DRY|18x8 BBS RE-G FORCE SPORT|17x8 BBS RC-CONTIEXTREME|H-SPORT S4 SWAYS|AMS SS|APR SNUB|STOPTECH 332 FRONT-BREMBO X-DRILLED REAR|HAWK HPS|SS LINES|OPTIMA-REDTOP35|XENON ECODES|LED CITYLIGHTS|HOEN|SYMPHONY II+|DICE|35% SOLAR GARD|S4 DOOR FLARES|MOTUL 5.1|MOBIL 1 0W40|
    Veteran Member Four Rings hyperspeed's Avatar
    Feb 13 2004
    Chino Hills, CA
    wow... i love it!
    and the job u did was great with the matching and eveyrthing. good job
    Veteran Member Four Rings shehatezme's Avatar
    12 BMW F10 528i | 02 Honda S2k
    Bay Area
    Damn looks good , nice DIY!!!!
    Took 2 years for someone to figure this out.
    Feb 17 2004
    Round Rock, TX
    Items for Sale
    sure, all the OEM grilles would work just fine. I could have used the OEM fog grilles and just made the center one, but the grille pattern would not have matched exactly, and even if they did, they cost more than I'd want to spend.
    Veteran Member Four Rings A4rce1's Avatar
    Jan 19 2005
    London
    You did it! Thats awesome and everyone said it couldnt be done
    It looks flawless, congrats
    Registered Member Four Rings |Sandman|'s Avatar
    Jan 02 2005
    A6 3.0 TDI QTip
    Lisboa, Portugal
    congrats man !!! that looks AWESOME.. very good job
    2005 Audi A6 3.0 TDI Quattro | 2002 Supercharged 330ci
    AKA Silveraudi
    Veteran Member Four Rings audidood's Avatar
    56 Oval
    bay area
    correction: only 2 years for someone to have the balls to just bust out the dremel and go to town.
    Nice work on the bumper, and i love how all the grills match. Good job!
    2004.5 USP A4 1.8t with mild mods.
    1956 VW Bug with major mods.
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B7A4, B8A4
    Honolulu, HI
    Items for Sale
    Nice work! Looks great!
    2006|A4 Avant 2.0T Quattro S-line
    2016|A4 2.0T Quattro S-line
    Veteran Member Four Rings element256's Avatar
    Apr 15 2005
    Is about to change completely
    Destin Florida
    bout time someone did this... good job man and nice writeup...Alot of people will be using this I'm sure.
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    Great job and it looks clean.
    His '64 Porshe 356, '15 A8 - Stock
    Hers '16 A6 3.0T
    His -> Hers -> Daughters 2003 A4 1.8TQ TIP - GTRS Eliminator, STG 3 REVO, Delphi 440's, ASP FMIC, Extreme TIP, TP, TT-DP, S4 door blades.
    Senior Member Three Rings jokas's Avatar
    Jun 11 2004
    2003 Audi A4 1.8T Quattro
    North Jersey
    Items for Sale
    that is fantastic!! wish i had the skillz... would really like to get the USP Front for my car.
    Great Job!!
    Veteran Member Four Rings A4Technik's Avatar
    Aug 08 2005
    Porsche 944 Turbo / Audi A4 Front Trash
    Corona
    Thats awesome....
    Garage:
    1993 KS Auto Burnout Widebody Rx7
    2005 Kraftwerks Supercharged s2000
    2006 Evo IX MR
    2005 Audi A4 1.8T - Sold
    Go Fast Goodies:
    K-03 Sport | ER Sport FMIC | ER Test Pipe | ER Rebar | EVOMS CAI w/ HKS Super Mega Flow | Neuspeed Catback | REVO BI | BOSCH 380cc Inj. | STRATMOSPHERE Hyperboost DV
    Nice
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant.
    Current: 2001 Amulet Red Audi TT 225 6-speedQ/Stage 2 with 3" Downpipe/Neuspeed/Magnaflow exhaust/Bilstein Shocks/034 breather kit/Forge/EuroCollective/DW 65v fp/Racing seats/OEM Rear seat delete rep kit/H&R Rear sway/Megan racing adj c arms/Vei afr/boost gauge/
    Feb 18 2004
    cape cod
    Nice! Now I can finally have the u/s lower that's been sitting in my basement for a year and a half painted and installed. Thanks!
    Are there any issues with the belly pan lining up correctly?
    http://i78.photobucket.com/albums/j1...gpicCustom.jpg
    QED Built Motor/PP'd head, Revo GTRS.
    Veteran Member Four Rings LAZY TURBO's Avatar
    Jun 01 2005
    La Crescenta, CA
    looks really clean, nice job!!
    ~Sevan
    USP CLUB MEMBER #1 <~CLICK IT
    Feb 17 2004
    Round Rock, TX
    Items for Sale
    nope, everything lines up as before
    Registered Member Four Rings HighPSI's Avatar
    Jun 30 2004
    DC
    nice job matt, looks real good...
    Palo Alto, Ca
    You dont have any pics of just the lower USP portion do you? I've found myself with an upper bumper to play with..
    Feb 17 2004
    Round Rock, TX
    Items for Sale
    best one I've got:
    Registered Member Two Rings
    Sep 16 2005
    Issaquah, WA
    Superb...
    Mar 23 2006
    Vancouver, Canada
    Nice job there, Matt Devo.
    BTW, what's the name of the colour on your car? That blue looks great!
    Senior Member Three Rings NightRider's Avatar
    Sep 18 2006
    Fort Collins, CO
    wow man, beautiful job. I will be attempting this shortly...
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Gone:A4 USP+ / A4 S-Line+
    long island, ny
    it's baaaaack....
    Veteran Member Four Rings pdxa4's Avatar
    Mar 26 2004
    12 Golf-R, 03 S8, 08 GTi, 06 MX-5
    Austin TX was San Jose, CA
    Very nice work, came out looking amazing...
    Current: 12 VW Golf-R, Rising Blue
    Former: 03 S8, Ming Blue
    Former: 08 GTi, 4dr DSG
    Current: 06 Mazda NC MX-5 many mods
    Former: 03 B6 A4 Avant 1.8TQ
    Former: 00 B5 A4 1.8TQM J31-K04
    Former: 04.5 Euro Passat PD TDI
    Original PDX
    V1.0 Member since 02/24/2002
    Matrix Integrated**
    Veteran Member Three Rings JWERNER24's Avatar
    Nov 08 2005
    1983 Porsche 944 (Track Toy), 1997 Toyota 4Runner (Offroad Toy)
    Central Oregon
    I followed this How-Do when I did mine... well done!
    Sold: 2002 Ming Blue A4 3.0 MT6Q
    Current: 2001 Brilliant Black allroad 2.7tQ
    FOR SALE: 1983 Porsche 944 - PM for details!
    Veteran Member Four Rings seph's Avatar
    Norwalk, CT
    Items for Sale
    y was this never moved to the DIY section....
    -Ant
    2012 A5 2.0TQ 6MT Ibis white
    2002 A4 3.0 TIP Quattro - Sold
    For sale: ADR M-Classics 19" w/ Toyo proxes 4s- DTH USP splitter
    Registered Member Two Rings Uber Hans's Avatar
    Feb 13 2006
    Chino Hills
    please move it to the DIY
    Veteran Member Four Rings 617 Bones's Avatar
    Wife's - MK3 GTI VR6 Vortech S/C
    Boston
    Anyone know if this MOD wiggles or wobbles at all??
    it looks awesome, but with winter and alot of snow coming soon, will this DIY bumper be able to take a little abuse or is it somewhat flimsy??
    thanks!
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Veteran Member Four Rings Monizzle's Avatar
    Dec 27 2005
    Mercedes S550, 2012 Audi A4 quattro
    thanks!
    if you do it like Matt it won't wiggle or wobble.
