Results 1 to 11 of 11
    Sep 18 2013
    A4 avant
    Brewster NY
    Just hit a pothole and right tire is vibrating.
    Dark an unavoidable, don't see anything cracked, could it be I just knocked the alignment off is that a thing when you hit potholes? Super pissed, like hey NY why not take some of my tax money and fix the goddam roads!!!! Just happy I didn't put the VFF103's on yet, next week they go on, just hoping to avoid any surprises as far as damage. But is there anything else that could cause the right side to vibrate after a hard hit like that?
    B8.5 APR Stage 1
    May 20 2010
    Wrecked B7 A4
    Items for Sale
    Probably bent; if you cannot see anything on the outside, could be a bend on the inside rim area. May have also thrown a wheel weight, but I'm willing to bet it's bent.
    PS: Having lived in NJ and now in MD, I feel you pain!
    Jun 09 2017
    West LA
    ya i would go with bent rim also. check your tire pressure also. with bends or cracks they will loose pressure.
    check the tire tread also. i have seem some pot holes take chunks out of the tire.
    Sep 18 2013
    A4 avant
    Brewster NY
    Alright cool, well not cool, but I have a set of wheels to throw on so I can take the hit there. Just hoping nothing structural. Will keep an eye on the tire pressure.
    B8.5 APR Stage 1
    Established Member Four Rings wkhanna's Avatar
    May 12 2017
    needs cleaned
    Land of Archaic Anachronisms
    one other possibility is that you broke some of the cords internally on the tire.
    this will cause the tire to go 'out of round'.....
    Bill
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0t coupe
    2012 A4 quattro 2.0t (The Wife's)
    1983 Porsche 944 (modified)
    1985 BWM K100RS (since new - Heavily Modified)
    1971 Moto Guzzi Ambassador
    Avatar Chart
    Jan 26 2018
    Waldorf/Maryland/US
    Bent rim is probably the most likely culprit unfortunately. If after a self-inspection you don't see anything that is out of the norm, then check the balance on the wheel. losing weights out of the well of the rim can also cause a similar issue if too out of balance. Bent rims suck...I have one each on my S5 and Lincoln MKS (#IhateDCpotholes). fortunately mine aren't totally intolerable and can wait until the Spring.
    Registered Member Two Rings
    Feb 01 2018
    Does it hum? Is it consistent at all speeds?
    When i lived back east in NJ - i drilled a pothole merging on to 95 in Conn - it was horrendous. We were headed to a wedding in NH - on the highway up - i was earing a loud hum/vibration that was pretty noticable around 30mph to 75mph and then it went away at higher or lower speeds than that.
    When i got back i took it to a shop and ended up that i hit the pot hole so hard it busted a wheel bearing.
    Could very well be a bent rim if you're getting shaking/vibrating but if you're getting more of a hum and it varies at speed - could be a shot wheel bearing.
    Aug 04 2010
    Queenz/Westchester
    It's bent. Same thing happened to me on 95n in the Bronx in my A4. I should have known netter and taken a parkway instead of Highway/freeway/thruway. I usually run Higher tire pressures, especially in the winter. Ride is harsher but it helps prevent bent wheels.
    Sep 18 2013
    A4 avant
    Brewster NY
    I haven't had it checked out yet lol, I don't drive much, going to Eurotech next week to have new wheels put on with springs. However, reexamining the wheel, unless the bend is somewhere on the back side since nothing is visible, I think a weight did pop off. I noticed a black square where it looks like a weight was, never knew they could pop off like that, if in fact that's what it was.
    Doesn't look like anyone thinks it could be structural so phew, that's my biggest concern.
    Thanks again. And now I'm going from 19's to 20's in Putnam NY lol, god help me.
    PS If anyone knows anything about lug bolt lengths and what I would need for these wheels, I have a question in the wheel gallery thread that could use an answer!
    B8.5 APR Stage 1
    Feb 01 2018
    Quote Originally Posted by fx_warrior View Post
    Time to buy some clothes pins and out them on your nipples to dull the anxiety of hitting your next pothole.
    I thought escaping the pothole hell of the north east to California was going to be epic but our roads are shit here too lol
    Established Member Two Rings athree20v's Avatar
    Jun 07 2013
    Southbury,CT
    Items for Sale
    Probably bent...
    One day after I just got my brandy-new Vorsteiners on,I went for a drive on the highway. Cruising at around 70-75 I decided to switch lanes and BOOM!...Drove right into a huge pothole that had the divider line sprayed right into it, effectively camouflaging it. Instant vibes and noise...Destroyed my right front wheel with a taco-like bend and the tire had a huge bubble in the side wall...
    $750ish later I got a replacement wheel/tire combo sent to me.
    Yay cars.
