Results 1 to 5 of 5
    Active Member Two Rings RacePace's Avatar
    Dec 10 2017
    B8 Audi A4 2.7 TDI & BMW 335i M Sport
    Australia Melbourne
    Question A4 B8 Sunroof wont open
    Hi all,
    For some reason my sunroof wont open. I wonder if this has anything to do with me changing my manual dim mirror to an Auto dim rear view mirror?
    I scanned the car with VCDS and came up with the below errors - is this related to the sunroof? I tried testing the sunroof in VCDS and nothing happened. Even tried the manual reset of holing the knob down for 10 seconds. Checked all fuses in all 3 locations all seem good.
    Dont know what else to try.. if anyone can help it would be much appreciated!
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Part No SW: 8K0 907 064 AL HW: 8K0 907 064 AL
    Component: BCM2 1.1 H71 0134
    Revision: 00002001 Serial number: 0110317516
    Coding: 0100062200390484002001
    Shop #: WSC 41684 123 104857
    VCID: 7AFA7F4CF50BBD95FB-802E
    1 Fault Found
    03021 - Local databus 3
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 129
    Mileage: 134820 km
    Time Indication: 0
    Date: 2018.02.13
    Time: 19:02:46
    Current Garage
    Audi 08 B8 A4 2.7 TDI
    BMW 06 M Sport 335i
    Porsche 07 987 Boxster S SOLD
    BMW 07 M Sport 335i SOLD
    Mitsubishi 99 MR GTO SOLD
    Subaru 01 STI SOLD
    Nissan 99 Skyline R34 GTT SOLD
    Senior Member Four Rings bakedziti's Avatar
    Oct 23 2014
    '77 MGB Roadster
    Buffalo, NY
    Did you remove the overhead center console? If so, did you reconnect all of the connectors? - I think there are 4 or 5 total up there.
    Do you have the full scan? It seems like we're missing info.
    Do you have a light/rain sensor or automatic lights? - I'm not exactly familiar with your market, but I wonder if the autodim relies on the light sensor.
    This may help too: http://wiki.ross-tech.com/wiki/index...(8K/8T)_Tweaks
    2011 A4 P+ Quartz Grey; Black Sport Package; 6MT; MMi; B&O
    GIAC (stage); Eurocode HFC; Stasis Exhaust; Alu Kreuz; H&R RSB; DV+; CR-15; ECS Intercooler & Piping
    the egyptian prescription
    Dec 10 2017
    Australia Melbourne
    Quote Originally Posted by bakedziti View Post
    I think this may be the reason.
    The mirror i bought had a different connector to where my old mirror plugged in. So i took apart the connector of the autodim mirror & placed the pins into the plug. The plug on the car only has 3 wires but the mirror has 6 however the autodim works even with just 2 plugged in (positive & negative) the 3rd wire must be a signal wire of some sort so i may need a wiring diagram.
    Pic 1 is the car plug
    Pic 2 is the pins from mirror plugged in (i taped it up after)
    Pic 3 is side A of mirror plug
    Pic 4 is side B of mirror plug
    I used black/white wire from mirror to car for power. The 3rd wire i used brown as per pin layout
    Sent from my SM-G955F using Tapatalk
    Current Garage
    BMW 06 M Sport 335i
    Subaru 01 STI SOLD
    Oct 23 2014
    '77 MGB Roadster
    Buffalo, NY
    So you went from an 8 pin connector to a 6 pin connector?
    Do you have any humidity sensors or anything in the front of your original mirror?
    I have swapped my mirror, but only for a black one with the same features. The two threads below may help, but the images may not come through.
    http://www.audizine.com/forum/showth...Mirror-Upgrade
    http://www.audizine.com/forum/showth...n-Light-sensor
    Dec 10 2017
    Australia Melbourne
    Yes went from 6 to 8 pin. I finally got the sunroof to work with new mirror. I changed the brown pin to the green one.
    It got rid of the above error only to replace it with a humidity sensor error lol But everything works so I'll leave it alone for now.
    Sent from my SM-P600 using Tapatalk
    Current Garage
    BMW 06 M Sport 335i
    Subaru 01 STI SOLD
