Results 1 to 16 of 16
    Aug 13 2012
    Gas smell in car?
    My daughter, who has a 2004 1.8 with about 120k miles, just texted me that her car smells like gas, almost like it is coming through the vents, and that it started hard today, which never happens. Thoughts on where to start or most likely causes?
    Feb 02 2018
    Placerville
    N80 purge valve? Usually comes with a CEL though. Check evap system components
    Senior Member Two Rings EuroKid34's Avatar
    May 22 2016
    2005 Ford F-150
    Reno, NV
    Quote Originally Posted by DenverA4 View Post
    Probably her car heater.
    M
    S4 Prestige
    Veteran Member Four Rings Luxus Panzer's Avatar
    Apr 15 2014
    B6 A4 Avant, B4 90 Sprot Q, B4 90 FWD, 2014 VW Tiguan
    Ottawa/Gatineau Canada
    Quote Originally Posted by EuroKid34 View Post
    M
    How so? Heater is a simple coolant/rad system. Heater would smell of coolant not gas.
    Jun 12 2014
    1999 mustang cobra; 2003 G35 coupe
    Tampa FL
    First place i would check is under the rear seat.
    I'd check the pump and sender gaskets on the passenger and driver side respectively.
    There are other places under the hood to check.
    I don't know where they are, but I think some gas lines run near where the cabin filter is.
    Apr 07 2011
    Quote Originally Posted by nighthawk86 View Post
    I agree. Probably something to do with the N80 valve. Here's a picture for reference OP:
    M
    Troll much?
    Aug 13 2012
    Thanks guys. Will the purge valve show some visible sign of being bad? Assuming I don't see any leaks at the lines or fuel rail or injector seals, how can I know if the purge valve is bad?
    Sep 24 2010
    Costa Mesa, SoCal
    Did this happen after filling up?
    Mine had a slight crack in one of the fuel tank lids, specifically the driver side, that would leach gas for a little bit after filling up. The smell was more prevalent outside the car toward the rear, though.
    2001.5 A4 1.8TQM: F21, Motoza E85/750cc/3" MAF/3bar MAP, 3" HFC, custom 2.5" exhaust, TR18T FMIC, DW200 pump, I.E. con rods, Eibach coilovers, 034 RSB, A8/TT front & S4 rear brakes, SS brake lines, JHM SS/linkage, B7 RS4 clutch, 4:1 center diff, 034 street mounts, E-fan, Apikol diff mount, Stern diff bushings, Nexus 7 HU, custom sound system, bixenon, sport cloths
    2001.5 S4 Avant: JHM shifter, 3" exhaust, Stage 1, receiving lots of love ($$$)
    Senior Member Four Rings blitz2190's Avatar
    Jul 31 2014
    NH
    tell her to stop driving immediately. while it can be the n80 simply leaking, I have had the orings on my injectors leak on two separate cars. and if its a strong smell and starts hard this is likely the case, it will pool up on the engine and can very easily catch fire. I would check with a flashlight for wet areas around the injectors.
    May 20 2015
    Ontario/Canada
    Yea you need to tell her to park that car and stop driving it.
    I had my n80 purge side disconnected for years and never smelled fuel in the cabin.
    Look at the fuel rail/ injector area like blitz said first thing!
    This is how cars burn to nothing.
    02 B6 1.8T quattro 01A Brilliant Black, Gutted Stock Cat, 2.5" stainless custom exhaust to 4 inch tips no res no muffler,
    USP Front lower Valance, Front Head Light Clear Corner Mod, REVO Stage 1, Solo Werks S1 Coilovers
    B6 S4 Front Brakes, Forge Hybrid Diverter Valve, 3M Wrapped Carbon fiber interior trim, PCV & AC Delete
    May 22 2016
    2005 Ford F-150
    Reno, NV
    Quote Originally Posted by Luxus Panzer View Post
    Just a smell I smell man. Thatís all.
    M
    S4 Prestige
    Aug 13 2012
    Since I don't like when people report a problem and not the solution, here is what happened. I went to her work 16 miles away and opened the hood and had her start it, thinking I'd be puzzling for hours over the source. Well let me tell you, even I can see gas shooting out the end of the fuel rail at a rate of probably a cup a minute. She must have dumped half a tank driving a full day like that. Replaced the Schrader valve core on the end of the rail in 5 minutes - after driving an hour to get one and the valve stem tool - and all was good. But yeah, fire is a real risk in that situation.
    May 20 2015
    Ontario/Canada
    Yea a N80 purge won't do that to that extent, I don't care what anyone on here say's.
    Glad to hear you got it fixed.
    Apr 15 2014
    M
    What?
    Jun 26 2015
    Tampa, FL
    What?
    Dude, you're being trolled.
    Apr 15 2014
    Quote Originally Posted by rocket1420 View Post
    Glad he/she is contributing to the community, :(
