Results 1 to 24 of 24
    Apr 04 2016
    Deltona, FL
    Clutch Chatter Less Than 50miles on New Clutch
    Hey so I just had a Stage 2 Eurocode clutch and LWFW installed and picked it up Friday.
    I have less than 50miles on the new clutch and I'm hearing a ton of clutch chatter only when in neutral. Goes away when pedal is pressed or in gear.
    Car has 68,8XX Miles on it. I pretty much drove it straight home and haven't really taken it anywhere or gone over 3000 RPMs.
    My Video below of what it sounds like.
    https://www.youtube.com/watch?v=phPTUjrhIRU
    Second video of an example (Not my video but its what it sounds like and does that exactly!)
    https://www.youtube.com/watch?v=zGo8WDW9mLY
    NOTE: I also had Eurocode Transmission mount insert, 034 Street density mount, and USP SS Clutch line installed at the same time as well.
    Is this normal? If its not normal what could this be?
    Edit: No issues with shifting or going into any gear.
    2012 Black S4 6MT / Revo Stage 1+ tune / Revo SC Pulley / CTS Turbo Intake / Borla Exhaust Modified / Eurocode Stg 2 Clutch and LWFW / Eurcode Transmission Insert / USP SS Clutch Line / APR CPS / Power Stop Drilled&Slotted Rotors and Pads / P3Gauge / RS4 Grille / VMR 710FF 19x9.5
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350/Mountaineer
    SE, PA
    Did you get a new flywheel as well?
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Providence RI
    Welcome to a light weight fly wheel. Remember you paid for that!
    2001.5 b5s4 built bottom stg3 on E - Sold
    2013 B8.5 S4 stage 2 DP
    Apr 04 2016
    Deltona, FL
    Quote Originally Posted by Dr GP View Post
    Yes
    - - - Updated - - -
    Quote Originally Posted by rtl5009 View Post
    Is it supposed to be that loud? Also will it get quieter as it gets broken in?
    Jan 20 2015
    That can't be normal....has to be something wrong with install or defective part. I would make contact with someone on the forum who has a LWFW or JHM/ECS to inquire about cars they've modified. I'd be ticked if my trans sounded like that after an install....
    2015 Audi S4 6MT Glacier White w Black Interior
    2016 Audi SQ5 Technik Glacier White w Black/Red Interior
    1998 Chev Camaro LS2 Rear mount Turbo (710+hp/710+rwtq @ 14# boost at the wheels)
    2010 Audi S5 Coupe 6MT, Daytona Grey/Magma Red Interior - SOLD
    2010 Jeep SRT8 - SOLD
    ​​​​​​​2006 BMW E46 M3 Coupe 6MT - SOLD
    2009 Infiniti G37XS Sedan - SOLD
    2011 Volvo XC70 T6 & S60 T6 - SOLD
    2004 Audi S4 V8 Sedan - SOLD
    2002 Acura TL Type S - SOLD
    Veteran Member Three Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Not sure about that meat grinding low rumble chatter your experiencing. My car chatters here and there but itís a light clack clack clack but it doesnít sound like that. I have a SPEC 3+ and ECS lwfw. How does the pedal feel on engagement/disengagement?
    2014 S4, Audi Exclusive DRM, 6MT, 034 Stage 2+ E40, DP (3.362), AMS Cooler, Autotech HPFP, ADV.1, CR-15, Deval CF, ECS LWFW, Eurocode, SPEC 3+, KW V3, ST6 BBK, USP SS clutch line, XPEL full wrap.
    Gone: 2012 S4 Brilliant Black, Prestige, S-tragic.
    Apr 04 2016
    Deltona, FL
    Quote Originally Posted by RWD2quattro View Post
    Not sure about that meat grinding low rumble chatter your experiencing. My car chatters here and there but itís a light clap clap clap but it doesnít sound like that. I have a SPEC 3+ and ECS lwfw. How does the pedal feel on engagement/disengagement?
    Just went out for a short drive. No issues going through any gears. Did some testing and It pretty much is non existent when I get it to about 1k RPMs. idle at 700 its very noticeable 900 is slightly noticeable.
    Established Member Two Rings LopezMendez's Avatar
    Nov 18 2016
    Yakima
    Does it reappear in-between shifts for a slight moment. ?
    Sent from my SM-N950U1 using Audizine mobile app
    Apr 04 2016
    Deltona, FL
    Quote Originally Posted by LopezMendez View Post
    No. When I was in any gear and coasted while letting the RPMs get down to 700ish the sound will be there. Once I introduced any throttle it would go away. Between shifts the sound wasn't present.
    Oct 06 2014
    doesnt sound that unexpected given the flywheel you installed
    Apr 04 2016
    Deltona, FL
    Quote Originally Posted by dinkman View Post
    Ok. I just wanted to make sure there was nothing wrong. I can live with the noise.
    Nov 18 2016
    Yakima
    I have the same setup , I do believe you should get that checked. Mine is quiet.
    Apr 04 2016
    Deltona, FL
    was yours loud at first? going to get it checked this week anyways
    Established Member Two Rings TheAsset's Avatar
    Jul 14 2016
    MO
    Go out and do a nice hard launch.
    2014 Audi S4 Prestige - Misano Red
    IG: @TheAss3t
    Dec 29 2011
    The Bay
    Quote Originally Posted by TheAsset View Post
    Nope, please don't give bad advise like that, he will glaze that clutch in an instant. Clutch needs to be broken in first, at least 600 miles of city driving. After that launch whenever you want.
    Established Member Two Rings Tyler8's Avatar
    Jan 20 2012
    Rochester, NY
    Definitely not normal. I have an ECS lwfw and southbend clutch and itís completely silent, always has been from day one
    Active Member One Ring BeasTT315's Avatar
    Jun 07 2017
    12 TTRS, 02 TT, 15 GSXR 1000, 02 A4 totaled (Hit by texting driver when parked)
    I had one installed about 8years ago on my mk1 TT...sounds like a helicopter sitting in neutral. The second I get the clutch pedal depressed it goes away. LW aluminum flywheel and stage 3 Southbend clutch. It was quite embarrassing for a long time until I heard that it is normal for them to chatter like that. Still zero issues with 50k miles and tons of hard launches.
    Apr 04 2016
    Deltona, FL
    For the ones that don't have the issue or have slight rattle. Can you post a video or message me a video please. Thanks
    Apr 04 2016
    Deltona, FL
    Quote Originally Posted by BeasTT315 View Post
    The more and more I'm looking into the lightweight flywheel rattle on idle or lower RPMs it seems normal in other cars as well. I was just curious if anyone had the same setup and if its normal for these cars.
    I had a 2000 Trans AM and got a LWFW/clutch kit and had chatter on low RPMs in gear but no rattle in neutral.
    Jul 14 2016
    MO
    I would honestly just do what the manufacturer suggest.
    Jul 21 2004
    997S; Camaro SS; e30 BMW, Toyota FJ
    South Florida
    Quote Originally Posted by AudiFLS4 View Post
    My lwfw on the b6 would rattle in neutral the worst and then when you press the clutch it stops. Held fine and I was told it was normal. I was told some installations get it worse than others. Either way I just planned on getting a stock flywheel from that point forward haha.
    Mike
    2013 Audi S5 DSG
    Unitronic Stage 2++ ECU & TCU, 3.17pr, Revo Charge Cooler, CTS Turbo Intake, ST60 380mm BBK
    11.482 at 118.70mph - 97 octane - +465DA
    11.605 at 118.76mph - 93 octane - +544DA
    Gone:
    2016 A6 -- 2015 S4 -- 2009 A4 -- 2004 S4 -- 2006 A4 -- 2003 A4 -- 2000 A4
    Veteran Member Three Rings kelseysautobody's Avatar
    Mar 03 2009
    Cape Cod, MA
    OP maybe the video makes it sound worse than it is but that does not seem normal. I had some light chatter in neutral (clutch in it went away) on my B7 S4 but that seems excessive. It was more like a *chich* *chich* *chich* *chich* sound where yours sounds like a rock was thrown in the bell housing.
    Ummmm no. Follow break in by what the manufacturer says.
    2013 S4 S-tronic - APR intake // KI 200mm crank pulley // EPL Stg II DP 93 + TCU tune // PLM hx // Jokerz Blower // Headers
    11.425 @ 118.16
    For sale: 2007 S4 6MT Past: ~ 03 A4 3.0 6MT ~ 99 A4 1.8T
    Active Member One Ring sbw's Avatar
    Aug 26 2008
    I had a clutch install recently thatís making a sound at idle that sounds like a tapping. Pretty sure we isolated it to a flywheel that seems to have become slightly bent. This was a LUK flywheel but I am replacing the flywheel again and attributing this to a damaged part.
    Apr 04 2016
    Deltona, FL
    Just went to the mechanic and found out there was some play in the flywheel assembly. They're going to re torque it and i'll report back with updated sounds.
