Results 1 to 9 of 9
    Dec 28 2014
    Norway
    A4 2.0TDI, Studder, won't ride propperly, electrical problem.
    Hello Guys and Girls.
    Lately we have been experience some kind of problems with my fathers Audi, after we swtich to wintertyres we have been experience some problems with the car.
    The the car is a 2.0TDI 2014 with 200 000 km (120 000 miles) on it.
    It all started when i had it for a spinn while i didn't have a car, after a houre or so riding i came out from a round about and while i tried to accselerate the car just vibrated and slowly gained speed, the whole car studders away in "limp mode". Stopped and went out of the car looking for something obvious fault without any luck. Swtiched the ignition on and started the car, was preapering for a uncomfortable ride home, but the fault was gone and it ran like a dream again. After some time my father called me and told me once again the car was misbehaving, stopped over to the side of the road and switched the ignition off and on, bang problem solved for a while.
    third time the sharm, after riding 200 meter to the main road we started noticing it one again, the peadale to the metal and the vibration came back, the car stalls, vibration, no warning in the dash, try to switch the esp off without any luck. My first thought was that the car think it's slides and the esp tries to stopped it.
    Connected the VCDS and only fault came up was a thaillight, fault var over 1 yeard old, checked the taillight was working and deleted the code.
    Now it happends once again, my dad road up to the cabin, on the slimey winter roads the car starts messing with us unce again. when we arived home i searched the car for fault codes is a ABS code, maybe this is the problem ? and a streering assistiance code ?
    I wonderd if the battery was wornout so i checked the status of it, the morning after we parked the car the VCDS read 11.8V and 29ah, tok the car for a 45 min spinn and when i came back i read 12.5V volt and 49ah.
    I wonder if anybody have an ide of what is causing this problem ?
    It's giving me a headace, google the fault codes, syntoms, and cracking my head for a cause of this problem...
    I tried to read the wheel speed aswell wondering if maybe a abs sensor is the cause of the problem. they all read the same, and it seems like they read steady. tried on a long staight, with the cruse controlled inn. They all showed the same, no "flicking" or anything.
    Best regards RkM2
    Autoscan :
    VCDS Version: Release 14.10.0
    Data version: 20141022
    Saturday,13,January,2018,12:27:54:58836
    Chassis Type: 8K (8R0)
    Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 69 72
    VIN: WAUZZZ8K9DA011485 Mileage: 206600km-128375miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CJCC) Labels: 03L-906-018-CGL.clb
    Part No SW: 03L 906 018 HE HW: 03L 906 018 JL
    Component: R4 2.0l TDI H25 9978
    Revision: 45H25---
    Coding: 12194012243401080000
    Shop #: WSC 34629 001 1048576
    ASAM Dataset: EV_ECM20TDI01103L906018HE 003007
    ROD: EV_ECM20TDI01103L906018HE.rod
    VCID: 74EDB725DF5EFB817B3-8021
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 BP HW: 8K0 907 379 BP
    Component: ESP8 front H09 0090
    Revision: -------- Serial number: --------------
    Coding: 169544
    Shop #: WSC 06335 000 00000
    VCID: 0815F3D5BBD6EF6127B-805D
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 205762 km
    Time Indication: 0
    Date: 2018.01.01
    Time: 16:04:42
    Freeze Frame:
    Hex Value: 0x0040
    Hex Value: 0x0082
    Hex Value: 0x1227
    Hex Value: 0x1692
    Hex Value: 0x0000
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 ED HW: 8K0 907 064 ED
    Component: BCM2 2.0 H10 0530
    Revision: 00002001
    Coding: 03A20000000000000000
    VCID: 76E98D2DC122E991457-8023
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H60 0072
    Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
    Component: J764 ELV MLB H40 0046
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8K1 820 043 AB HW: 8K1 820 043 AB
    Component: KLIMA 1 ZONE H02 0123
    Revision: A1000000 Serial number: 01260120120440
    Coding: 342002E000
    VCID: 68D5D3559B960F61C7B-803D
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 DH HW: 8K0 907 063 AH
    Component: BCM1 1.0 H14 0103
    Revision: 08014001 Serial number: 00000025642401
    Coding: 2600C0118034AFC00081490300001D0D011C26082609020100 0004000400020100000020000000
    Shop #: WSC 16728 123 104857
    VCID: 78F58315CB369FE157B-802D
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 200112 H07 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
    Component: G397_RLFS H06 0001
    Coding: 02005D
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
    Component: Humidity_Sens H02 0002
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
    Component: AirbagVW-AU10 H45 0610
    Serial number: 003KFD90JHAK
    Coding: 30514435363030303030554A304C384B3053
    Shop #: WSC 12972 002 1048576
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 489533D5F3562F61E7B-801D
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME6A00323EB
    Crash sensor for side airbag; front passenger side:
    Serial number: 6344MSME68526451B
    Crash sensor for side airbag; rear; driver side:
    Serial number: 6352QSME74670852G
    Crash sensor for side airbag; rear; passenger side:
    Serial number: 6362QSME0E6A0E60S
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME01680342N
    Crash sensor for front airbag; front passenger side:
    Serial number: 63832SME0F6913461
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
    Component: Lenks.Modul H02 0171
    Revision: 00000000 Serial number: 20120124001342
    Coding: 000017
    VCID: 4FA718C91E38F859A61-801A
    Component: E221 - MFL H03 0003
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 931 C HW: 8K0 920 931 C
    Component: KOMBIINSTR. H16 0640
    Revision: 00100000 Serial number: M3A44PG1D
    Coding: 1315100002010008010000
    VCID: 2E59654D79F29151CD7-807B
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8R0 907 468 C HW: 8R0 907 468 C
    Component: GW-BEM 4CAN-M H10 0025
    Revision: 1Y030014 Serial number: 1441Y1211902D5
    Coding: 00CF07FF00
    VCID: 3F872809AE9868D9561-806A
    Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
    Component: J367-BDMHella H03 8041
    Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
    Component: J532_DCDCStab H17 0042
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 Q HW: 8K0 959 793 Q
    Component: TSG FA H02 0506
    Revision: Serial number: 0000020365711
    Coding: 011002204000410001
    VCID: 4E9905CD1932F151AD7-801B
    Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
    Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
    Component: RCEPS H36 0507
    Revision: 00001000 Serial number: 0012308000
    Coding: 100000000001
    Shop #: WSC 16728 000 1048576
    ASAM Dataset: EV_RCEPSAU48X 008014
    ROD: EV_RCEPSAU48X.rod
    VCID: 346D77259FDEBB81BB3-8061
    1 Fault Found:
    2305 - Function Restriction due to Start Voltage Interruption
    U1410 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 111
    Mileage: 204351 km
    Date: 2017.11.26
    Time: 19:38:36
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0167789742
    Coding: 0100062020B900408120023680000000
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 Q HW: 8K0 959 792 Q
    Component: TSG BF H02 0506
    Revision: Serial number: 0000019944417
    VCID: 4D9B02C11434CA49D4D-8018
    Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
    Part No SW: 8K0 907 801 J HW: 8K0 907 801 J
    Component: EPB-4 H01 0001
    Revision: -------- Serial number: 00000000016692
    ASAM Dataset: EV_ParkiBrake 001022
    ROD: EV_ParkiBrake_AU48.rod
    VCID: 36694D2D89A2A991857-8063
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 056 D HW: 4G0 035 056
    Component: Radio U STD H60 0094
    Revision: AB001007 Serial number: 229A60C7539887
    Coding: 010003020100000001
    VCID: 2241817D3D2A253159F-8077
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 8R1 035 652 A HW: 8R1 035 652
    Component: B-BN-EU H62 0175
    Revision: -------- Serial number: 148A%0C7509667
    Coding: 01010001000681ED01802B4E000000030000
    VCID: 31637E3168CC8EA9D05-8064
    Subsystem 1 - Part No: 4G0 919 884 K
    Component: EUR 2012 1308
    Subsystem 2 - Part No SW: 8T0 919 604 HW: 8T0 919 604
    Component: DU6 Basic H42 0098
    Subsystem 3 - Part No SW: 8T0 919 611 HW: 8T0 919 611
    Component: E0380 Bedient H01 0100
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 D HW: 8K0 959 795 D
    Component: TSG HL H01 0506
    Revision: Serial number: 0000022537582
    Coding: 010002204000210001
    VCID: 438F24F9C2700C39329-8016
    Address 69: Trailer (J345) Labels: 8K0-907-383.clb
    Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
    Component: Anhaenger H09 0100
    Revision: 1A001001 Serial number: 00000166110653
    Coding: 010D000000000000
    Shop #: WSC 25397 000 00000
    VCID: 36694D2D81A2A991857-8063
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
    Component: TSG HR H01 0506
    Revision: Serial number: 0000022537351
    End-------------------------(Elapsed Time: 03:10)--------------------------
    Dec 28 2014
    Norway
    Update.
    Ony function active in steering assist is auto Stop/start.
    After a night the car shows 11.9V and 36 Ah.
    Senior Member Two Rings Tyintegra's Avatar
    Sep 13 2010
    2013 A4, 2013 Golf R
    Bothell, WA
    Items for Sale
    The studdering reminds me a lot of what we were experiencing when a spark plug coil went bad. But this caused a check engine light for misfires.
    Dec 28 2014
    Norway
    The car in question is a disel without sparksplugg, it's unfortunately not the sinner in this case.
    It's no faults for the engine, and since the car 99,9% of the time run perfect i think it's something electrical. Unfortunalely...
    Dec 08 2012
    Moldova
    The battery definitely doesnt look right, 11.9v is not a good voltage to have. Thou, that should not really affect the way the engine runs. I also have the 2.0TDI and I've seen it run strange a couple of times, but also no errors recorded so .... no clue. Start with checking if you actually need a new battery, the B8 2.0 TDI is prone to wiring issues in the engine bay, if you dont have around 14v at the battery when the car runs... you have a problem there.
    Audi A4 B8, 2.0 TDI. Retrofits: Bi-xenon. Front parking sensors with graphics. OEM Bluetooth. Servotronic - 1N3. Footwell lights. Color DIS. AMI. Audi Drive Select. EGR off. DPF off. 207BHP CAHA remap. Keyless Entry/Go. Lane change assist. B&O. Aux Heater.
    Dec 28 2014
    Norway
    It happends again, ran straight home and connected the VCDS, no fault at all in the engine. Battery show 14.8 Volts ? 14.6 in terminal 15 and 30... 66Ah
    Established Member Two Rings Tineo's Avatar
    Jul 08 2013
    Dairy Land, Asturias. Spain
    Quote Originally Posted by RkM2 View Post
    Do you have verified the battery aging at 19-gateway Channel?
    It's strange. Electrical power is stable when car is running? Alternator issue?
    2008 A4 B8 3.0tdi Quattro Sedan 6MT
    Ibisweiss | TLR remap to 301hp | S-Line interior | Rotor 19" rims | S4 front and rear brakes | RoadRover gps | Depo taillight LEDs | 80mm exhaust tips | S4 blackgloss grill with blackgloss valence | S4 pedals | fulldynamic LED turn signals ...and more
    Dec 08 2012
    Moldova
    Your battery might be just fine, my bet is on the fuel regulator valve on the HPFP and the fuel regulator valve on the rail, this is what I have changed on my side and the shudder went away. Start with the High Pressure fuel pump regulator first. These are known to have issues but not throw any errors, you will get an error when the part starts to totally wrong.
    Dec 28 2014
    Norway
    Tineo: yess i verified the at gateway ch 19, the battery seems stable when the car runs, but the power drops quicly when the engine is shut down.
    Maybe the battery is fine, just got my head spinning when i saw it showed 11.8-12 volts.
    Andyzaharia: tank you, i will defently look at the High pressure fuel pump and fuel regulator valve and see is this is the problem.
    Give you a update
