Results 1 to 14 of 14
Thread: Need new clutch
    Nov 12 2017
    Port Jeff Ny
    Need new clutch
    Yup was talking shit to friend w 340 bmw that I would beat him. First time driving hard and clutch definitely slipped and didn't go no where. What clutch should I get I'm newly stage 1 and new to car 70k miles guessing stock clutch. What should I get I'm prob gonna go stage 2 in future.
    2011 Spirit Blue B8 S4 6 Speed Manual Sport Differential RS4 Grill Roc-Euro Intake Euro Spec Front Lights APR Stage 1 AWE Touring Exhaust.
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Providence RI
    South bend or xtend
    2001.5 b5s4 built bottom stg3 on E - Sold
    2013 B8.5 S4 stage 2 DP
    Nov 12 2017
    Port Jeff Ny
    What am I looking at cost of aftermarket upgrade and install of clutch?
    Jul 28 2009
    Providence RI
    Search
    Jan 20 2015
    Holy crap! I've swapped out a clutch and flywheel in my 1998 Camaro (turbo car making 710hp/tq at the wheels). Easily done in a couple hours. I just did a quick search and found an installation guide from ECS on a clutch swap. Our manual transmission cars are crazy complicated...i could see this being a 1-2 day job to do.
    ECS: Southbend Clutch and lightweight flywheel
    http://bd8ba3c866c8cbc330ab-7b26c6f3...lywheel_R2.pdf
    https://www.ecstuning.com/b-ecs-part...3886ecs01akt4/
    JHM: Lightweight Flywheel and clutch kits
    https://jhmotorsports.com/products/t...-3-0t-fsi.html
    2015 Audi S4 6MT Glacier White w Black Interior
    2016 Audi SQ5 Technik Glacier White w Black/Red Interior
    1998 Chev Camaro LS2 Rear mount Turbo (710+hp/710+rwtq @ 14# boost at the wheels)
    2010 Audi S5 Coupe 6MT, Daytona Grey/Magma Red Interior - SOLD
    2010 Jeep SRT8 - SOLD
    ​​​​​​​2006 BMW E46 M3 Coupe 6MT - SOLD
    2009 Infiniti G37XS Sedan - SOLD
    2011 Volvo XC70 T6 & S60 T6 - SOLD
    2004 Audi S4 V8 Sedan - SOLD
    2002 Acura TL Type S - SOLD
    Apr 20 2011
    Hackettstown, NJ
    Sachs Xtend clutch. Unless you're going more than stage 2 that's what I'd stick with as it gives the most OEM pedal feel.
    2012 Phantom Black Pearl S4 6MT / B&O / Sports Diff / 3G+ Conversion
    Jul 28 2009
    Providence RI
    I have done my clutch twice- took about 12 hours each time.
    Nov 12 2017
    Port Jeff Ny
    Another question is I never felt slip before drives fine under normal conditions can I expect have some time before needing to replace or does it totally fail quickly once starts slipping?
    Apr 20 2011
    Hackettstown, NJ
    Generally a clutch can last a while after it starts slipping under heavy load, if you're easy on it it should be fine. But I would get ready to replace it soon.
    Mar 20 2015
    McKinney,TX
    BMW 340, lol
    I ran one of those, looked stock, it was a slow walk and I was stage 2 so make sure the new clutch is overkill just in case you go stage 2 or beyond
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350/Mountaineer
    SE, PA
    I had 2 incidents where went WOT and shifted 1-2 the clutch pedal just stayed on the floor, engine revved and car went nowhere Burnt smell and car shifted unusually for a few days there after. On both occasions, the clutch feel and action returned to normal. Definitely burned the clutch .But it still worked OK after the clutch materiel wore off of the pressure plate. Car had 20 K at the time. Now on my 3rd MT S4. I don't repeat that same scenario . But my current 2011 with 80k miles and 2 previous owners, works just fine as long as I don't beat it it. So if you plan on racing it or driving it hard, a new clutch is in order. If you drive it conservatively but aggressively, and not do WOT burn outs from less than 5 MPH, you can keep your clutch for a while.
    Oct 06 2014
    Quote Originally Posted by fstr n u View Post
    holy smokes. didnt realize clutch/fly wheels were so expensive on these cars!
    Jun 08 2005
    SE, PA
    Quote Originally Posted by dinkman View Post
    Is it absolutely necessary to replace the flywheel if no track or drag racing is going to be done? Can the original flywheel be resurfaced if necessary?
    Veteran Member Three Rings S4tranquility's Avatar
    Dec 29 2005
    Baltimore
    Items for Sale
    Quote Originally Posted by Dr GP View Post
    Original flywheel can be reused as long as condition is okay.
    2013 Monsoon 6MT S4, GIAC dual pulley 3.18 ratio
    Former: B5 S4 120+ club; Sleeper, Stages, and more B5 S4 vids
