Results 1 to 7 of 7
    Active Member Two Rings mk2vrt's Avatar
    Mar 29 2010
    nagaro b5s4 stage3 frankenturbo...
    tri state
    Exclamation WTB: ASAP b7 S4 flywheel manual.
    Doing a manual swap and had the wrong flywheel need this asap cars on the lift.
    Text me at 315-991-5185
    Location is 13215 Syracuse ny
    Thank you
    B7 s4 4.2l 6speed manual flywheel
    New used whatever in good shape that's all.
    Unless you built it yourself I'm not impressed !!![tool]
    Sep 12 2017
    Virginia Beach/VA
    There's a few on the forum. Here's 1 for an RS4, doesn't say wether it's manual or not. Will post another below:
    http://www.audizine.com/forum/showth...el-(13-pounds)
    Mar 29 2010
    tri state
    Thank you. Rs4 is different bolt pattern
    Sep 12 2017
    Virginia Beach/VA
    The second post has a link to a B6 S4
    Senior Member Two Rings vailshred's Avatar
    Aug 20 2011
    2001.5 S4 Avant
    VAIL COLORADO
    I have about 4 b6/7 used fw's. I just sent you a text but imessage has nor said delivered. Pm me if your still in hunt. I can send out Tuesday if needed.
    Sep 09 2014
    Grand Rapids, Michigan
    Rock auto. They’re luk brand and cheap
