    Active Member One Ring kob1801's Avatar
    Dec 03 2017
    Honolulu Hawaii
    Upstream O2 Sensor Replacement
    I have a 2008 B7 A4 Quattro 2.0t and I am trying to replace my upstream O2 we sensor. The problem I'm running into is that when I follow the lead from the sensory seems to disappear into a wireing harness behind the engine, but I can't really tell. Any help with this would be appreciated.
    Sent from my SM-N950U using Audizine mobile app
    Veteran Member Four Rings Andrew149's Avatar
    Apr 19 2009
    Modesto/CA
    Use a mirror with a flashlight.
    Sent from my iPhone using Tapatalk Pro
    2008 Audi A4 Avant 2.0t 6speed
    JHM K04 tune, JHM Full B6 S4 exhaust system, JHM HPFP UPGRADE, JHM RS4 clutch, JHM Shifter Knob, S3 Injectors, S3 K04 Turbo, RS4 Grille, RS4 RSB, H&R Sport Spring, K&N, Bilstein Sport Shocks, Snub Mount, AWE Boost Gauge, 034 motor mounts, 034 Transmission mount, 15mm Rear Spacers, 12mm Front Spacers, Audi TT wheels.
    Apr 24 2015
    San Diego, CA
    Itís routed behind the engine and terminates to a connector mounted to the firewall, which is behind the coolant reservoir.
    I canít recall if the upstream sensor is brown or black connector.
    Itís a bit of a pain to remove it from the wiring bundle that is traveling with it due to visibility.
    May 20 2010
    Wrecked B7 A4
    Items for Sale
    I believe the upstream one is the black connector.
    Senior Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Perth, WA
    I run mine over the engine cover towards the back. Is there any reason that could be a problem that anyone knows of?
    My respray thread
