Results 1 to 11 of 11
    Jan 12 2018
    Tulsa/Oklahoma
    Why do I keep having to bleed the system for heat to work?
    I have a 04 A4 Quattro 1.8T that recently had the radiator and thermostat replaced as well as having the coolant system flushed 3 times due to an issue with the heater. After the system was bled the heater was working well for a couple of days, but then began blowing lukewarm air again. I have bled the system multiple times on a few different occasions now and the heater blows super hot air each time I bleed the system but then returns to lukewarm in a day or so. I am not losing coolant in the system and the engine is getting to proper running temp and staying in place. Are there any ideas as to why air keeps getting into the system and how can I fix it? Thanks for your help
    Nov 03 2010
    Yorba Linda, CA
    First be sure that you are doing the air-bleeding correctly. The engine has to be shut OFF, not running. Disconnect the sensor connector under the coolant reservoir, then raise the reservoir as high as the hoses allow and keep it there. The reservoir should be kept full and the blue cap off, then pull back the heater hose with the small hole in it until just past the end of the heater pipe. When you have a constant little stream of coolant, push the hose back on and re-clamp. Put the reservoir back and you are done.
    Mar 21 2016
    69 Nova
    California
    For all the hate the 3.0 gets, it was pretty easy to bleed the system. I literally just put a couple liters of G12, couple more of distilled water, until it came out of the bleed screw. Tightened it up, and that's basically it.
    I didn't even lift the reservoir. I *might* have jacked the car up, but I don't remember.
    No problems, hot heat whenever I have heat on.
    3.0 ftw, apparently, lol.
    04 A4 3.0 Quattro 6 Speed
    69 Nova with a bunch of stuffs
    Veteran Member Three Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by DarkoNova View Post
    It’s not 3.0 specific lol. I do a lot of work with the b6/b7/b8 and the reason you had no issues is because when the cooling system is working properly that’s all you should have to do! It will self bleed any air.
    Nowadays i use a vacuum refill tool, but never had issues with simply adding coolant to reservoir.
    Jan 12 2018
    Tulsa/Oklahoma
    Thanks for the reply. I've only done it with the engine running because that's what I've been reading in my own research. I will definitely try this process and hope for the best. Thanks again
    Dec 28 2006
    '03 A4, '13 A5, '18 MB-GLA
    Western Maryland
    Items for Sale
    Bleeding info in here: Clicky click®
    A4 Motoza tuned Frankenturbo F21L mixed flow turbo / Bosch 550's / 3" MAF / TyrolSport SMIC / 034 HFC / TT 2.5" DP / Borla Exhaust / Eibach ProKit Springs / Koni Yellows / H-Sport Sway Bars / TyrolSport Brake Stiffeners / HyperShift Short Shifter / Podi
    A5 Mods to come: Little stuff so far. 20/25mm spacers / H&R OE Sport springs / 35% tint / Neuspeed Power Module / black window trim / RS grille.
    Jan 12 2018
    Tulsa/Oklahoma
    Quote Originally Posted by Turbo510 View Post
    So I did this today and I ended up with pretty similar results. The heat got hot but slowly died off throughout the day except when I push the gas pedal it will get really hot. I'm thinking the next step is to replace the heater core. It doesn't seem to be as difficult to replace in this vehicle as some dealerships and mechanics make it out to be so I figured I'm going to give it a shot on Saturday. Any other suggestions to try before then? Thanks for your help
    Veteran Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    Paramus,NJ USA
    Its called a blocked heater core.Your better off replacing it.Should only take about an hour or so.
    VW/Audi Immobilizer removal and immobilizer adapting solutions for any and all VAG Vehicles,Odometer matching, SKC/Pin retrieval services.Located in Northern NJ.For inquries pm for details.
    May 24 2008
    cornish,me
    I would think that if the heater core was blocked you would not get any heat at all. I think that it is more likely that some how air is getting into the cooling system somehow. These cooling systems don't appear to be able to circulate the coolant when there is air in the system. I would drain the coolant and draw a vacuum on the system to see if it can hold the vacuum. This will tell you if there are any air leaks into the cooling system. It won't tell you where the leak is but you will know whether or not you have a cooling system integrity problem.
    Registered Member Two Rings
    Feb 10 2015
    seattle
    Quote Originally Posted by redrubberband88 View Post
    check your j-plug
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by refueler View Post
    Not true.If you have a blocked or partially blocked heater core thats restricted it will blow luke warm at idle and warm under load due to the pressure being built up inside the cooling system.you could try flushing the heater core back and forth.Or run the car with clr in the cooling system for 8 hours and see what happens.However sometimes they are too far gone to save.I recommend a replacement.
