Results 1 to 16 of 16
    Mar 05 2016
    Virginia
    DIS and Turn Signal Stalk Retrofit
    I am trying to add trip computer functionality to my 2011 A4 Premium-.
    I had the coding done to enable the Driver Information System, and it works, with the instrument cluster menu appearing in the car menu of the infotainment system. I wanted to be able to switch to the digital speedometer and efficiency program, so I swapped over to turn signal stalks with the rocker switch and reset button (Part number: 8K0 953 502 BK). I kept my original clock spring/steering position sensor (Part number 8K0953568F) and swapped it over to the new stalks. I reinstalled everything, and the rocker switch and reset button still don't work.
    Does anyone have an idea about why the buttons don't work?
    Veteran Member Three Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by pieman123 View Post
    Avant or sedan?
    FL taillights retrofit/Interior leds/Number plate leds/Fog grills with chrome rings/Sideskirts/Bixenon retrofit/MMI 3G High retrofit/ECU tune/VCDS mod/FL gearknob/18" wsp wheels "peelers" style/Color DIS retrofit/Soundproofing/Interior 6D carbon wrap/Rieger look front bumper valance/Added B/O tweeters+Activsub/ADS Limited with switch retrofit/Efficiency program via cluster and gateway flash/FL S5 Cluster look + trim bits, A8 2010+ analog clock in process
    Mar 05 2016
    Virginia
    Its a base sedan with the 6MT
    Oct 21 2012
    Earth...
    Not sure is there difference in wiring(pinouts), but BK version is for avant if catalogue is correct(with rear wiper option PR-7Y0,7Y1+
    8T1+9Q2,9Q4,9Q7,9Q8)!
    Mar 05 2016
    Virginia
    I realized after buying that these stalks are for the avant, but it seems that the only actual difference is the mechanism that allows it to go into the rear wiper "on" position. The circuit boards for both seem almost identical. On the switch that controls the intermittent wiper speed, the two stalks are functionally the same. All of the other wiper functions work correctly, and if I push it back it just seems that nothing happens.
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    Thought about adding this to my sedan as well (2011 Premium base). Please let us know if you get this worked out and proper part numbers.
    Oct 21 2012
    Earth...
    Yep, they are "almost" same, but i cant comment is "linbus" setup same for both or not. Two guys who did this on sedan used BD version. Coding should be simple just activating dis under steering module, but just for test there is bit for avant rear wiper also, so try enable this also!
    Which modules you coded for DIS?
    Jan 03 2013
    Baltimore
    I did this retrofit. You need to have the correct stalk - the avant is different. Take a look through this thread: http://www.audizine.com/forum/showth...MMI3G-Retrofit and here: http://www.audienthusiasts.com/ProjectSteeringSwap.html
    The p/n is 8K0953502BD. There is some coding involved after you install the correct stalk, seems like you put in the avant version which wont work.
    Mar 05 2016
    Virginia
    What coding is needed? I already did the following coding I had seen elsewhere along with enabling the DIS.
    17 Instruments, Byte 1, bit 2
    56 Radio, Byte 9, bit 6
    Is there more coding that needs to be done?
    Oct 21 2012
    Earth...
    Also steering vcds address 16, byte 2 bit 1 and for avant was also bit 0
    Mar 05 2016
    Virginia
    Thank you SO much! That was all I needed to get it to work. Even with the avant stalks it is now working perfectly.
    Oct 21 2012
    Earth...
    Well done, myth busted
    Mar 05 2016
    Virginia
    So it turns out there is a bit more to this. Earlier today, I was driving and the EPC light came on. It turned out to be a code relating to the cruise control module. I tried it and it turned out that it was no longer working. My original long coding for module 16 (steering) was 0014. I changed it to 0013, per your advice, and it had made the stalks work, however with my sedan, it also caused cruse control to malfunction. Changing it back to 0014 made the EPC light go away and cruise control functionality to return. I decided to play around with different codings and for me 0016 (setting byte 2 bits 1 and 2) made both the trip computer controls and the cruise control stalks work with the EPC light off.
    I hope this helps anyone looking to do this swap in the future.
    Oct 21 2012
    Earth...
    No idea how your oem coding can go lower(from 14 to 13) if you enabled bit1 as it must go higher always, but all works it is main thing!
    My one is same as yours + i have bit 0 enabled, as it is avant so i have +1(000017)!
    http://i.imgur.com/jYWJ7YM.png
    Mar 05 2016
    Virginia
    I originally had only bit 2 and 4 checked, but then to get 000013, changed it to bit 0, 1, and 4 checked. As of right now 000016 seems to be working correctly with no errors. Do you know why the avant needs to have bit 0 checked and the sedan doesn't?
    Oct 21 2012
    Earth...
    I only ment to enable bit 1 and 0(0 just in case), nothing needed to be uncheck or to get 000013! Bit 0 is for rear wiper(avant)!
    If you had 14, after you enable bit1 value would be 16!
