Page 1 of 5 123 ... LastLast
Results 1 to 40 of 190
    Senior Member Two Rings casey_tuzziano's Avatar
    Mar 25 2015
    '68 Nova, Subaru Forester
    United States
    Big Turbo A4 Build
    Here is my winter project! After being tired of my K03, I have decided to go all out and install either a Precision 5558 ball bearing turbo or a Garrett GTX3582r. I will be installing the following parts to complete the setup
    For the engine internals:
    ○ IE Rifle Drilled Rods
    ○ Wiseco 9.6:1 pistons
    ○ Clevite stock tolerance rod bearings
    ○ ARP main studs, head studs, and camshaft girdle (valve cover) bolts.
    For everything else:
    ○ Cast log-style T3 manifold
    ē Depending on fitment, the turbine housing may come in contact with the motor mount bracket since the manifold places the turbo further back than the stock location. With that being
    said, I can shave away at the motor mount bracket, or create or J pipe from the manifold so the turbo will be mounted on top.
    ○ While I have the engine disassembled, I am replacing all the gaskets, timing chains and guides, etc.
    ○ I am currently running ECS' Lufteknic Intercooler
    ○ Custom intake manifold with an integrated secondary fuel rail for port injection.
    Fueling!
    ○ As we all know with our B8's, when it comes to high horsepower, the injectors we have will not cut it.
    ○ For the in tank pump; I have a walbro 450 E85 compatible pump.
    ○ upgraded HPFP
    ○ the injectors I plan to run will either be Opel or Bosch injectors, but these will only get me to +- 400whp (from what I have researched).
    ē with the port injection; I plan to run bosch style injectors, controlled by AEM's FIC. I will need to figure out what size injectors I will need.
    ○ I have the option to run W+M, but I have not decided on it.
    Tuning!
    ○ Many people have recommended all sorts of tunes, and tuners. I will have to do my research, I would typically go to Mirza in NJ, but he seems to be AFK....
    Turbo!
    ○ I am in between the two turbos
    ē both will be t3 in/4 bolt out, with a .64 turbine housing.
    ○ For the water and oil feed/return
    ē IE oil feed adapter (-4 AN)
    ē IE oil return (-10 AN)
    ē ATP banjo bolt and crush washers for the coolant return, 3/8 hose from coolant feed into the return on side of block. (Not needed on the PTE or Garret)
    ē AN lines and fittings
    I will update the thread as parts come in!
    May 20 2010
    Quote Originally Posted by casey_tuzziano View Post
    I think you got cut off!
    Mar 25 2015
    United States
    you're right I did! but i updated the post
    Veteran Member Three Rings pierreb's Avatar
    Q7 (4M)
    NH
    Subscribed
    Mar 25 2015
    United States
    I pulled the engine first week of December before it got super cold.
    Started to tear it apart and began to order all the goods.
    Senior Member Three Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI MK7 GTI - B8.5 Q5 - B8 A4
    Hawaii and Utah
    It sounds like a cool project. Since youíre going with some IE internals, you may want to email Peter Blais (owner and engineer at IE) and see if heís willing to write a custom file for you. He already has the box code for the B8 A4. They also sell turbochargers but only Borg Warner.
    CTS K04 / IE custom tune / Wagner FMIC
    Mar 25 2015
    United States
    Quote Originally Posted by Perry01 View Post
    Very cool! I'll shoot Mr. Blais an email!
    Jan 22 2016
    Hawaii and Utah
    IE is known for their hardware but Peter is also good at tuning as well. I just received my 6th revision on a custom Stage 2 e-tune. Iíve been sending him datalogs and each new file has improved the performance. It pulls really strong for a K03.
    Im thinking about putting a big turbo on my MK7 GTI. Peter tuned his brother Dave (co-owner of IE) MK7 Golf R to put down over 400 AWHP on the stock turbo. Iím hoping he can do something similar for me.
    Here is a cool article about Integrated Engineering, there is a video clip at the end with Pete showing off his 600 WHP MK6 GTI:
    http://motonetworks.com/integrated-e...tuning-finest/
    Jun 05 2009
    Ducati Panigale 1199S (Red of course)
    Denver Colorado
    Looking forward to this project! It's gonna be really nice to see something like what you have planned come together. SO much win!
    Black B8 A4 Avant S-Line Prestige Package, CPMB Engine, Tiptronic 8 speed, JHM K04-R, V1 & Beltronics, Eurocode HFC, APR FMIC, Alu Kreuz, Vogtland Coilovers, Stoptech 380mm BB Kit, H&R Swaybar, APR K04 Tune, Rev. "d" DV, R8 Coils, Folding Mirrors, S5 Rear Brakes, 034 Street Density Mounts, OEM Facelift LED Brake lights, Forgestar CF5, and more mods to come!
    Mar 25 2015
    United States
    Happy New Year everyone! 2018 has some BIG plans for my car. (Pun intended)
    My IE H-beam rods and rod bearings came in today.
    Also went ahead and sand blasted then painted my valve cover wrinkle red on my day off. It honestly doesn't look that bad.
    I will be doing a turbo reveal soon as well!
    Feb 25 2011
    Alpharetta, GA
    Iíve got some of the specific build tools if you need them. The large bar to hold the crank. The guides for setting up the cams etc.
    Mar 25 2015
    United States
    Quote Originally Posted by Mitchmarket View Post
    Haha thanks! But Im an Audi tech and i own most of special tools for the TFSI block lol
    Stage 3 Forum Advertiser Four Rings Jake@JHM's Avatar
    Aug 31 2011
    MK7-GTI-APR-STG2-Grand-Cherokee-R6-Raven-IRON-1250
    Lathrop
    Cool build! Interesting turbo choice.
    Nov 20 2016
    loving the cam cover wrinkle red, i would have done that already on mine if it wasnt for the fact that it holds the cams down lol
    Mar 25 2015
    United States
    Yeahhhhh there's no real good way to remove the girdle without removing the timing chain. I know one guy did it without removing the chain and once he removed the last bolt to the girdle the cams moved and it skipped timing. It was a mess lol
    Established Member Three Rings B8_Dude97's Avatar
    Sep 05 2016
    Antioch, California
    Subbed. Great build that valve cover is sick.
    I got a tiny leak on my valve cover so when I decide itís time to do my timing chain Iíll probably follow suit in a wrinkle blue because racecar
    Mar 25 2015
    United States
    Quote Originally Posted by B8_Dude97 View Post
    Thanks dude! And when you get around to it you should definitely post a pic of the wrinkle blue! Just a reminder you need to use a special anaerobic sealant for the valve cover. D 154 103 A1 is the sealer part number.
    Sep 05 2016
    Antioch, California
    Will do! I got a laundry list of things coming up that I need to do. Replace all wheel bearings and full timing chain job and replace valve cover sealant and do a carbon cleaning and camshaft adjuster magnet.
    I will report back with pics of valve cover. I know a mk6 user said it could only be painted a special way but you say you just sandblasted and did the paint so Iím confused on that if you could shed some light thanks!
    Mar 25 2015
    United States
    You can paint it however you want lol, I've never heard of a special way to paint valve covers besides to prep the surface and make sure everything is clean and masked off. I only sandblasted it to get the smoothest surface as possible.
    Mar 25 2015
    United States
    Parts are slowly rolling in! Went to Wiseco today (they're local to me in Ohio) and put an order in for the pistons. Should be getting a call Thursday the latest from them. On the other hand...
    Got the ARP main studs installed
    And the IE oil feed/drain adapters fitted
    Mar 25 2015
    United States
    Got the bottom end all together and head bolted down!
    Mar 25 2015
    United States
    I'm going to town on the engine! Turbo still has not shown up yet....I also need to tackle the fueling....oh boy
    Senior Member Three Rings Carlos74's Avatar
    Mar 30 2014
    Palatine, IL
    Subbed!!! Iím excited to see such a serious build bro!
    IG: @c_lowsb8
    APR l CTS l EUROCODE l ECS l 034 l PODI l GFB l MAGNAFLOW l H&R l SPC l STANCE l SPULEN l HANKOOK l NGK
    IG: c_lowsB8
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    E46 325ci
    CA/NV
    Beautiful!
    Sent from my SM-G935T using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 2.0t Ibis white/black
    AKA: A4QuattroV6
    Mar 25 2015
    United States
    Quote Originally Posted by Carlos74 View Post
    IG: @c_lowsb8
    Ayyyyyeee Carlos! We follow each other on IG haha. I think you're the first one to sub from there lol. Anwyays, I appreciate it a lot! I hope to get it up and running before car show season.
    Senior Member Three Rings Mina08's Avatar
    Apr 30 2014
    Classic Mini, and lots of bikes
    Sweden
    sub
    Really interested with the turbo install, what exhaust are going with
    2011 2.0 TFSI S-Line Avant/S-Tronic/Quattro/Quartz Grey/19"OEM RS5 Rotors/
    CFBSWheel/VCDS+Mods/XCL+Mirracast/LED/R8Coils/3.0FMIC/K&NFilters
    Mar 25 2015
    United States
    Quote Originally Posted by Mina08 View Post
    sub
    Currently it's catless with a custom bent 2.5in piping. I welded in a vibrant bottle resonator and ultra quiet resonator. When I get the turbo mounted I'm going to have to make a downpipe, stock one will not fit. I'll attach a sound clip.
    Nov 23 2009
    NYC, US
    How much does it cost of all the internals? Would it be more expensive than buying a brand new S4? I know you guys are enjoying the process of building a engine. I wish someone can teach me how to build a car engine from scratch.
    Mar 25 2015
    United States
    Quote Originally Posted by AutoRacer100 View Post
    The rods, pistons and bearings came to +- $1300
    Feb 19 2011
    Earth
    What are your plans for fuelling?
    2000 Achat S4
    Mar 25 2015
    United States
    Quote Originally Posted by jaychen View Post
    Walbro 450 in the tank, upgraded hpfp, injectors off a b8.5 flex fuel allroad. Water/meth injection. And possibly port injection. I have an AEM FIC controller but it'll be a challenge to wire into the ECM. If I can figure it out the I'll run it but I'm not really looking into turning my daily into a racecar lol
    Apr 26 2014
    San Diego, CA
    So, I have a legitimate question - and I don't mean for this to sound like a criticism at all - it's something I'm genuinely curious/concerned about.
    Over the past couple of years, I've seen a few handfuls of people attempt these one-off big-turbo builds. I totally appreciate the effort and love the desire to push the platform further, but it seems like every build falls on it's face the exact same way. People go through the hardware upgrades and complete the engine build without having a confirmed plan for tuning in place. Usually it seems like after a few weeks or months of searching, or trial and error with numerous tuners and custom files that always seem to underwhelm or fall short, and the project gets scrapped with loads of regret.
    Now don't get me wrong, I want you to succeed. I want you to easily break 400+AWHP and set the bar higher for the community. But why push ahead on all these hardware upgrades without having a confirmed Plan A (and a Plan B for that matter) in place with a tuner to best utilize the hardware choices you're making?
    I guess what I'm saying is, these builds always seem to historically fall short when it comes time to tune. So why not gameplan the strategy with a tuner (or two) ahead of time to help mitigate that risk?
    build / instagram / flickr
    Mar 25 2015
    United States
    Quote Originally Posted by adamazing View Post
    I'm glad you brought this up, I've planned this whole project for the past year or so. I've talked to A LOT of tuners, some were confident, some were iffy, some just left me on read, it seems like some of the big turbo guys used maestro or whatever it is. I'm not looking for any ridiculous power numbers, just something fun and unique. In the past month or so, I reached out to Peter Blais from IE and he will be helping me out with the tuning. He's all for it, he thinks port injection might be overkill, but we will see what it comes too.
    Jan 22 2016
    Hawaii and Utah
    I see you took my advice :-)
    Pete has done an awesome job with my custom Stage 2 tune and I plan to reach out to him when it comes to my future turbo swap.
    Apr 26 2014
    San Diego, CA
    Awesome! Thanks for clarifying a little of the behind-the-scenes effort on this, and I'm glad that you have someone on board already who's able to consult and advise along the way.
    Good luck man and I'm eager to see this beast up and running. Keep at it!
    Mar 25 2015
    United States
    Did some test fitting of the turbo after work. I ended up getting the Garrett with a Precision-style ported cover. The downside is that the motor mount bracket will not fit, I knew this was going to happen so I came prepared.
    I can either A: fabricate a J pipe and make the turbo sit top mount B: I have a nifty tool from my college that scans things into Solidworks. So what I can do is scan the motor mount brakcet into Solidworks and modify it to fit.
    You may think that's a ton of work but it's no big deal IMHO (says the mechanical engineering Major). I can 3D print the bracket to test fit, then if I'm satisfied send it off to be made.
    Established Member Three Rings Jezza's Avatar
    Dec 14 2016
    Birmingham/Alabama/South East
    Just curious, why didn't you go with a top mount manifold to begin with?
    Sent from my SM-G930VL using Audizine mobile app
    Mar 25 2015
    United States
    Quote Originally Posted by Jezza View Post
    Don't really want to dish out $1100 on a custom manifold
    Dec 14 2016
    I understand. What's your ultimate hp goal? You said the stock fueling is likely good for 400hp, but I don't think you've said what your goal is.
    Mar 25 2015
    United States
    I'm shooting for 500 but I'll be happy with whatever it comes to.
