Results 1 to 4 of 4
    Veteran Member Three Rings Rocs's Avatar
    May 25 2009
    2004 Audi A4 USP
    Conshohocken, PA
    Items for Sale
    possible to run 275/30/19's on stock S line suspension
    Hey all,
    As the title states, is it possible to run 275/30/19 tires on either ET43 or ET33 wheels?
    I have these tires that i don't know what to do with and i can seem to sell them either. Figured I would run them if i could....
    Anyone have any experience with these tires and similar offsets?
    2012 A4 6mt
    -Prestige
    -S Line
    -Black Optic
    -B&O
    Established Member Two Rings FergusonHD's Avatar
    Aug 16 2013
    Miami
    Items for Sale
    It really depends on the width of the wheels not really the offset, Iím running 255/35ís on 19x10 wheels(mild stretch) and Iím on kw coilovers with no rubbing; you should be fine assuming your wheels are smaller than 10.5 inches wide
    Jul 21 2004
    997S; Camaro SS; e30 BMW, Toyota FJ
    South Florida
    Both wheel width and offset will make all the difference when running 275s. Of course the actual tire brand you choose will also make a difference since different manufacturers may have significantly different tread widths and shoulder block profiles on the same 275 rated tire.
    Check out eurocode tunings thread on their B8 S4 that they fitted 275s to. I'm guessing you'd need somewhere in the range of a 9.5" wide wheel at around ET45 with a bit of negative camber. No way on an et33 offset assuming you are using a wheel wide enough to support the 275 which would be at least 9.5" wide. you'd poke out of the fender significantly.
    2013 Audi S5 DSG
    Unitronic Stage 2++ ECU & TCU, 3.17pr, Revo Charge Cooler, CTS Turbo Intake, ST60 380mm BBK
    11.482 at 118.70mph - 97 octane - +465DA
    11.605 at 118.76mph - 93 octane - +544DA
    Gone:
    2016 A6 -- 2015 S4 -- 2009 A4 -- 2004 S4 -- 2006 A4 -- 2003 A4 -- 2000 A4
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    E46 325ci
    CA/NV
    Items for Sale
    et43 should work. i have ran 45 on 275 30 20s and it rides excellent, but also have a great suspension. i am now et 48 with 275 30 20 and thinking if switching to 285 30 20
    Sent from my SM-G935T using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 2.0t Ibis white/black
    AKA: A4QuattroV6
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
