Results 1 to 30 of 30
    Feb 22 2016
    Alberta Canada
    Just another catastrophic cam follower failure
    Just wanted to share my 06 a4 avant at 95k km. Cam follower failed, hpfp is toast. I'm assuming cam is no good. What else should i be looking to replace?
    Sent from my SM-G930W8 using Tapatalk
    Stage 3 Forum Advertiser Four Rings Jake@JHM's Avatar
    Aug 31 2011
    16 MK7 GTI APR STG2 - 03 Grand Cherokee - 06 R6 Raven - 13 HD IRON
    Manteca/Lathrop
    you can salvage your pump with this: https://jhmotorsports.com/jhm-high-p...-2-0t-fsi.html
    Intake cam here: https://jhmotorsports.com/camshaft-o...wt-engine.html
    We have cam followers here: https://jhmotorsports.com/cam-follow...-2-0t-fsi.html
    We will have anything else you need as well. Best way to know is to dig into and see what got damaged by metal shrapnel.
    Jun 20 2016
    1.8T Vanagon, KTM530, CB550
    Really try and get all the bits of the follower out. Change oil a few times and get a magnetic drain plug to catch any bits. Iíd change your cam chain tensioner while your in there and do the rear coolant flange while itís exposed as well. Iíve got the cam lock and cam gear puller if you need. Iíve also got half tube (opened this week) of the green sealant thatís needed. Pm me if you have any questions.
    Good luck.
    Jun 20 2016
    Iíve also got a spare new hpfp pump too.
    Feb 22 2016
    Alberta Canada
    Thanks guys. Going out to pull it apart and assess damage further. Wish me luck 🤞
    Feb 22 2016
    Alberta Canada
    Also, say I wanted to spend a bit more and upgrade, what would I be looking for, (and how much more $)?
    Jun 20 2016
    Upgrade hpfp.
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Quote Originally Posted by Trickassfoo View Post
    Having done this same thing and seen other people here with the same issues, I needed a new engine, it slowly, 6 miles went from no CEL to not drivable. I wanted to replace things as well but I had a ton of metal shavings in my oil and the nipple got stuck in the engine and screwed me harder.
    just my .02 if you have the $$ to build it, nows the perfect Oppo.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Feb 22 2016
    Alberta Canada
    I don't have the time, nor money, or space to be rebuilding a full motor. It doesn't seem worth investing in a full rebuild on a ten year old car. If anything I'd pick up a used motor slap it in and sell the vehicle for something that won't explode, with less catastrophic design flaws
    Senior Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Quote Originally Posted by IronAudi View Post
    Same thing happened to me. You can maybe save it if you get all the metal out, but if itís not worth it for you to rebuild, Iíd think about buttoning it all up and trading it in before you need a new motor.
    2005.5 A4 2.0T Brilliant Red | 6MT | Quattro | DTM
    Go: K04 | ST Coilovers | Carbonio | Maestro | S3 Injectors | IE Rods | JHM FMIC | Autotech HPFP | ECS SS | JHM Clutch | USP HFC | Quad-tip Exhaust | S4 Brakes
    Show: Panda Recaros | RS4 Grille | Votex Spoiler | OEM CF Trim | S4 Mirrors | Black Ext. Trim | Bixenons | LED Tails | A8 Rings | RNSe | 20% Tint | BFI Shift Knob | 034 Adj. UCAs | Shaved Reflectors | Ziza LEDs
    Mar 24 2013
    A7
    Griswold, CT
    Plenty of motors have survived a follower failure so that isn't necessarily the outcome in every case. I bought a B7 with a toasted follower that was in horrible mechanical condition and I successfully revived the motor. I ran it pretty hard for a few thousand miles as a daily and then sold it. It ran great and never had an oil pressure warning.
    -Adam
    '07 DTM A4 2.0T|6MT|EFR 7163 Twin Scroll|DoTuning|Built Motor|Meth and other go fast stuffÖ
    '06 A4 2.0T Quattro - RIP (Best ľ mile pass 13.634 @ 103.30)
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 2014 Honda Grom
    down town long beach
    Items for Sale
    Go to the dealer... FREE Repair up to 120k miles
    The dealer replaced my cam follower, HPFP, Intake cam, Gaskets and new hardware on my b7 avant when it had 119,200 miles on it. i did not pay a cent. i also got a pretty sweet audi a3 loaner car for 3 days.
    DO NOT throw away your damaged parts... put them back in and tow car to dealer. (call them first)
    Mar 24 2013
    A7
    Griswold, CT
    Quote Originally Posted by nizmosx View Post
    120k miles OR 10 years. His car is an 06 and won't be covered.
    -Adam
    Jun 27 2011
    Items for Sale
    1) he's in Canada
    2) its 10 years or 120k, thats run out for 2006 models
    OP, same failure happened to me. Yours is bad, but mine was actually a bit worse. Either way, I replaced the cam, pump and a few other minor bits and have been relatively problem free for almost 40k miles since I did it in December 2012. I have oil consumption decently bad (1L/1400miles) but since the failure had already occurred before I purchased the car I have no way of knowing if the failure caused the consumption or the consumption caused the failure.
    Either way you'll probably be okay just replacing the cam, pump, and follower.
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant) - Bosch FR6KPP332S plugs - Q5 Rear Aero Wiper
    2012 Q5 2.0t - Stock Mommy Missile
    Former USP CLUB MEMBER #136
    Feb 13 2004
    Items for Sale
    ahh didnt catch the year. my bad. mine was an 07 and tool care of it early this year so i was good to go. =)
    still worth asking maybe?
    Dec 03 2016
    nowhere
    I had a blown cam follower and the engine was never the same. Slowly the oil consumption got worse to where I was putting a quart every week. After it happened everything just started going south slowly and the engine was just unhealthy. If you want to keep it, do like you and Aluthman said, drop in a motor that you know is in good condition. Finding one that is in proper shape without having to rebuild it is another challenge.
    Feb 22 2016
    Alberta Canada
    1) he's in Canada
    I called Audi of Canada already and they told me that since the warranty was up there is a 99% chance they would do nothing. I was also told I could bring it to the dealer for an assessment but since I had opened it to check the cam follower they'd consider that I've "tampered with it" I checked to see if there was a recall listed under transport Canada but there doesn't seem to be. If there was then I'd have a case and Audi could be forced to pay for repairs, no such luck.
    I'm going to slap a cam and hpfp, do the coolant flange and call it a day. I'll flush the engine out with a few oil changes and assess it from there. If I have any problems come summer requiring further action so be it. I can't rebuild a motor at -30. I just purchased the car in April and the avant with 6mt took me ages to find in good condition. I seem have good luck in all aspects of life, and I've seen motors survive worse (blew a supercharger in a corrado and sent metal dust into the motor). I have high hopes that once I put it all together it will happily run another 100k +. Time will tell
    Feb 22 2016
    Alberta Canada
    Also I'm looking for a used cam, I've found two used hpfp on the forums here, but if anyone in Canada has anything let me know! I'm in Alberta. My plan is to hopefully find these parts slightly used and save some money, so I can see how the motor runs without investing 1000$.
    Senior Member Two Rings WewannaB7's Avatar
    Dec 07 2014
    Porsche Boxster, M-Benz ML350
    New Jersey
    Just curious...was the engine tuned?
    08 2.0T Quattro SE, APR Stage 1 - 93 Oct
    Feb 22 2016
    Alberta Canada
    Quote Originally Posted by WewannaB7 View Post
    The engine was tuned at 80k with unitronic stage 1. Cam follower detonated at 95k
    Dec 07 2014
    New Jersey
    Wow, only 15km (9k miles) and then cam failure. Wonder if that had anything to do with it. I tuned to APR stage 1 at around 15k miles, and now at 45k miles 3 yrs later. Maybe I should change my follower soon. Hope your carís fixed soon without issue.
    Feb 22 2016
    Alberta Canada
    You should check it. It takes half an hour to remove the hpfp. My old car was fine when I checked it at 150k, so I assumed my avant would be ok until 100k. Never assume. These cars have a serious design flaw that can cause engine damage. Best to be sure
    Dec 07 2014
    New Jersey
    Thanks. Good advice. What were your symptoms when it failed btw?...car just stopped and died? Any warning signs?
    Jun 17 2013
    jersey city nj
    Items for Sale
    Premature cam follower wear also would be contributed from having a modified HPFP. Stage 2+ and up. It tends to put more psi on the cam itself. Stage 1 still utilizes the stock hpfp. For pre- Id check every 60k or less thou
    APR KO4, APR HPFP,RS4 LPFP Cntr,145 bar PRV, APR TP, TT DP, GFB DV+, AWE FMIC, BFI CC, AWE Exhaust, RS4 Exh tips, ST CO, 034 RSB,034 St Dnsty Mtr Mts, New Sth West Bst guage, B7 RS4 8 pot Calipers.Stop Tech slotted rotors.Goodridge SS brake lines frt & rr. Hawk HPS frt & rr. RS4 PS rack, RS4 Servotronic Relay,RS4 rims. S4 mirror caps,RS4 Mesh Style Grill,LED tail lites
    Feb 22 2016
    Alberta Canada
    No symptoms or warning signs whatsoever. I drove the car very hard sometimes and up until the night before it failed it ran amazing. Then in the morning it wouldn't boost when I stepped on it. Turned around and parked it at home because i heard the pump shaft squeaking on the cam. No cel, I scanned for codes and got code p2293 power train - fuel pressure regulator 2 performance.
    Dec 07 2014
    New Jersey
    Damn...that sucks. Thanks for getting me all worried now. ;-)
    Feb 22 2016
    Alberta Canada
    Looks like yours is a 2008. There may have been a revision around then
    Dec 07 2014
    New Jersey
    Thanks, but I think Iíve read here that they all fail...even the 08s. Iíll have it changed out at my next service prob just to be safe.
    Jun 27 2011
    Items for Sale
    The only thing they fixed on the 2008 is that the cam lobe is much harder so the pump and cam follower wonít damage it as quickly when the CF fails. Which generally means less metal floating around your engine.
    And mine was a 2008 and it failed at 54k miles, totally stock. My old 06 had 80k miles when I checked the follower for the first time in the carís life and it was totally fine. So it has very little to do with tuning or model year and everything to with how on the ball all the owners over the cars lifetime have been with oil changes and using good quality oil.
    -CP
    Dec 07 2014
    New Jersey
    Thanks for the info. Mineís been serviced since new at dealer. Iím at 45k now, and almost at 10-yr mark, so Iíll have them change it at next oil change and see what old one looks like.
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
