Results 1 to 21 of 21
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    B5S4 Stage 3
    MD
    Looking For B8.5 S4 Owners running H&R Springs and 19s
    Like the title says, I'm going to be grabbing a set of 19s soon and I'm trying to decide on which H&R springs to go with.
    This is my daily so Id like it to be a comfy ride but get rid of the wheel gap.
    Show me your setup.
    Pic for clicks
    Current:
    01.5 B5 S4 - Stage 3 on Meth -- Thanks to Brad and Country Dubs
    13 B8.5 S4 - EPL Stage 2 / EPL TCU
    11 Treg TDI - About to be bought back
    Oct 14 2012
    Empty...for now...
    Malvern, PA
    Old photos, but here is my previous car B8 S4 on H&R OE Sport Springs with various wheel+tire setups, all 19" with 255/35-19 tires:
    2015 Daytona Gray S4
    Mods: S5 Peelers, Xpel Ultimate, 3M Color Stable Tint 35%, H&R Street Performance Coilovers, Euro Code Alu Kreuz, Eurocode Sway Bars+Endlinks, CR-15, Eurocode Meisterwerk ASTS, AWE Resonated Touring Exhaust, ECS Luft-Technik Intake, 034 Transmission Mount, HCX LED 3000k Fog Lights, E-codes, Apikol Rear Diff Mount
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    2012 Audi S4. 2017 Mini CMS JCW. 2016 Yamaha Z 125. 2007' Honda S2000
    MSP
    There are probably 800 pictures of B8's on HR springs. There are probably dozens of threads already on this exact topic. Google will even net you tons of pics.
    12' Prestige S4 + 6MT - Original Owner
    GIAC stg II v2 + AWE Pulley + Alpha Boost Cooler + Meisterwerk Shrt Shifter + AWE Cat-Back + S-Flow Intake & AFE Filter + H&R Front & Rear Sways + USS End Links + H&R OE Springs & Bilstein B8 Sprt Dampeners + Alu-Kreuz + CR-15 Upper Strut Brace + Ceramic Pads & 2-Piece Drilled/Slotted Rotors & SS Lines + Apikol Diff Mnt + 034 Trans Mnt Insert + ECS Diff Inserts
    Established Member Two Rings Seattle996's Avatar
    Apr 07 2009
    FYI: I had a B8 S4 on H&R OE springs and it rubbed quite a bit with the ECS Flush Kit Spacer combo, even cut out the rubber underneath which helped some. I then sold that B8 and got a B8.5 S4, put the same spring and spacer combo and never rub. I do have the adaptive suspension.. not sure if that is why or if its just car specific.
    2013 Monsoon S4 | EPL Dual Pulley Tuned | EPL S/C Pulley | Fluidampr 183mm Crank Pulley | H&R OE Springs | Niche Form 19x9.5 | Custom X-Pipe Delete | ECS Luft-Technik Intake | RS4 Grill Kit | Euro Impulse Shifter
    Apr 27 2011
    B5S4 Stage 3
    MD
    Quote Originally Posted by Seattle996 View Post
    Thats interesting, I wonder what the diff is between the b8 and b8.5 suspention and springs.
    Current:
    Oct 14 2012
    Empty...for now...
    Malvern, PA
    Quote Originally Posted by bmoreS4 View Post
    It might depend on what the alignment settings are, and how far the subframe is shifted relative to the body between the two cars. In my case, both my B8 and now my B8.5 have the rear subframe apparently shifted toward the passenger side such that when running 255/35-19 tires at +33 offset with equal camber and toe settings, the rear driver side is rub free while the rear passenger side rubs like crazy. There is a visible difference too - the rear passenger wheel clearly sits farther out than the rear driver. I have no idea why they build these cars like this. I'm curious to know on which corner(s) was Seattle996 getting rubbing with his setup?
    Established Member Three Rings Strong Man's Avatar
    Jan 24 2017
    tires 255/35R19
    2013 Audi S5 3.0T: Bang & Olufsen, NAV, Audi Quattro Sport Differential, Audi Drive Select, 7-speed dual-clutch automatic with manual shifting mode
    Mods: ||ST2: Unitronic ECU + TCU||Intake: ESC Kohlefaser Luft ||Exhaust: AWE Touring with Resonated DPs 102mm tips||Susp:CR15, Alu K, H&R OE, H&R R Sway Bar, ECS Drv Mnt Insert Kit ||H&R Spacers: 15F/20R || Brakes: ECS SS Lines, StopTech Creo Slotted Rotors F/R, HAWK 5.0 F/R, Motul 600 ||
    Apr 27 2011
    B5S4 Stage 3
    MD
    Quote Originally Posted by Strong Man View Post
    tires 255/35R19
    What springs?
    Current:
    Jan 24 2017
    What springs?
    H&R OE ...signature:)))
    Veteran Member Four Rings PinoyS4's Avatar
    05 ram truck hemi, 09 a4 2.0t AVANT , 2016 s4
    San Mateo, Ca.
    Items for Sale
    work hard, play hard
    Apr 27 2011
    B5S4 Stage 3
    MD
    Quote Originally Posted by PinoyS4 View Post
    What springs? Wheel info?
    Current:
    San Mateo, Ca.
    Items for Sale
    h&r oe sport springs. 1.2” drop. forged 305 ft108 wheels.
    Apr 27 2011
    B5S4 Stage 3
    MD
    h&r oe sport springs. 1.2mm drop. forged 305 ft108 wheels.
    Thanks man, how do you feel about the ride? Your stance looks like what I'm looking for.
    Current:
    Active Member Two Rings steampunkjunker's Avatar
    Jun 22 2017
    2013 Audi S4
    NorCal
    1.2mm drop?
    Junker’s 2013 B8.5 S4
    • Suspension: H&R ARBs, CR-15
    • Braking: Endless MX-72 & RF-650 fluid, StopTech cryo slotted rotors, Tyrolsport brake lines & caliper bushings
    • Motor: Stock, Redline motor oil + LiquiMoly Ceratec
    Feb 02 2014
    2011 STI - full suspension upgrade, Stage II+, 2015 M235 coupe
    Knoxville, TN
    Items for Sale
    The B8.5 has a taller ride height than the B8....especially in the rear. The actual spring/swaybar specs vary by model yr and options.
    Apr 27 2011
    B5S4 Stage 3
    MD
    Quote Originally Posted by steampunkjunker View Post
    1.2mm drop?
    I think he meant 1.2" drop
    Current:
    San Mateo, Ca.
    Items for Sale
    Sorry, thats what i meant. Rides perfect for me. Not too bouncy and pretty comfortable
    San Mateo, Ca.
    Items for Sale
    More angles
    Dec 30 2012
    2008 Gsxr 600 track beast
    Mountain View, Ca
    H&R Sport
    19 x 9 et35 HRE FF04
    Sent from my Pixel XL using Tapatalk
    Established Member Two Rings ShopVac's Avatar
    Feb 02 2016
    2014 JGC Overland Diesel / 2006 MINI Cooper Convertible / 2011 Jetta SE / 2014 Kia Rio
    PA
    H&R sports - Avant Garde wheels - 19" X 9.5" ET40 - running 265/35/19 Michelin PS4S's . Only rubs when I have at least 1 passenger in the back and I hit a bump going down hills, right where the bumper fascia connects to the wheel well (there's a bump that sticks out right there). I have not tried to correct yet...maybe next spring
    __________________________________________________ _____
    Proud owner of two superchargers and one turbo
    Apr 27 2011
    B5S4 Stage 3
    MD
    Thanks for the feedback guys, I ordered the H&R OE Sport springs and a Stoptech front and rear brake kit.
    Just need to decide on wheels.............
    Current:
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
