Results 1 to 3 of 3
    Jul 27 2011
    IN
    Bad power steering pulley or belt?
    My 98 AEB is having some squealing noise coming from the power steering/water pump V belt area. I did some testing with spraying water on the belt as you can see in the video below. When I put water on the belt, squealing goes away for few seconds and then it returns. I assume its a belt issue since noise is going away with water... any other comments?
    Senior Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    There's a belt dressing product that you can spray on to eliminate squeaks, or a belt is like $7 (not that cheap, but cheap). Replace that first before moving to the power steering pump. Sounds like a belt issue to me though. Power steering pumps have a different "whine" to them when they go bad.
    Jul 27 2011
    IN
    Quote Originally Posted by Rodgman15 View Post
    Okay, will try a belt conditioner and see how it goes.
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
