Page 2 of 2 FirstFirst 12
Results 41 to 54 of 54
  1. #41
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    I have the Fabless kit with Wilwood ebrake spot calipers. THEY SUCK! I know others that have the kit as well and think the same thing. They are not good for the weight of the B5. If you had a stripped down and lightened B5 sure, go for it you might have better success. Overall though they do not make me feel secured on a slope. I've readjusted over and over and its either not enough or I feel like I'm stretching cable to make it feel tight. Its probably part of the reason fabless quit making the kit....The fabbed parts are great though, but it utilizes the wrong ebrake caliper for our vehicles....
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant
  2. #42
    Mar 17 2017
    chicago il
    Quote Originally Posted by rguil View Post
    the fabbless manufacturing kits used b6 s4 rotors. These are the same id hope
    Here's what's needed
    wilwood calipers P#120-2281 (left)
    P#120-2280 (right)
    Audi b6/7 300mm rotors
  3. #43
    Veteran Member Four Rings 4rings5stars's Avatar
    Jul 31 2011
    Quote Originally Posted by bjaroch View Post
    P#120-2280 (right)
    What caliper does it use? B6/7 S4?
    05.5 Quartz 6spd Avant
    APR Stg1 / BFI snub mount / 034 SD mounts / 034 Tranny mount / ST Coilovers / 034 RSB
    APR Test Pipe / JHM Y-pipe / B6 S4 Exhaust / B6 S4 Pandas / JHM SS / 'Fly-Modded' AFS / 19" VMR V708
  4. #44
    Mar 17 2017
    chicago il
    Quote Originally Posted by Eurotuned_A4 View Post
    Then try the next one ill be making for my personal car. Dual calipers one Brembo and the stock one with a hydro hand brake plus cable parking brake
  5. #45
    Mar 17 2017
    chicago il
    Quote Originally Posted by 4rings5stars View Post
    No.
    The rear brembos from a audi q7. And other cars that come with 17/18z in the front
  6. #46
    Senior Member Three Rings b518's Avatar
    Jun 20 2011
    long island
    When are you planning on making the dual caliper kits
  7. #47
    Mar 17 2017
    chicago il
    Not till these ship out. I have no free time
    I got screwed over by a long time member on here with my custom harness now I'm building the entire thing myself
  8. #48
    Feb 09 2018
    B5 A4 1.8t Time Attack build
    UT
    PMd
  9. #49
    Mar 17 2017
    chicago il
    Quote Originally Posted by Sascha_B5 View Post
    PMd
    Your inbox is full
  10. #50
    Senior Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Any idea if I can run a set of these on a B7 A4? Im assuming yes, because literally everything else works, but I need to know.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
  11. #51
    Jul 04 2015
    Toronto Ontario
    Yes the matching rear calipers to the 17z. You will need wilwood parking brake calipers and I believe it's a rear drilled Mercedes 330mm rotor you will need.
    If people want, I can work out a good deal on redrilling rotors for everyone
    I will have all specific part numbers before the kits are ready, I've just been slammed here at my shop
    Youll want to use the Euro B8 S4/S5 330mm rotors. Ill see what I can find, but AKMotorsports has the Brembo Part numbers listed on their site.
  12. #52
    Mar 17 2017
    chicago il
    Quote Originally Posted by james12lucy View Post
    I'm told the spindles are different but I've gotten alot of people asking for b6 b7 brackets. I'll pick up a rear spindle and see what i can do but it has to wait till the b5 ones are done.
    2001.5 stage 2 to stage 3 k04 to fully built 6266 stk awd drift car
  13. #53
    Jul 04 2015
    Toronto Ontario
    Thanks. Let me know how you progress. Id be interested in two sets (one set doesnt need parking brake provisions, just the bracket).
    Thanks.
  14. #54
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Ill for sure want to watch this!
