Results 1 to 40 of 49
    Active Member Two Rings DOWORKB7's Avatar
    Feb 21 2017
    Cleveland
    Timing belt at 54k miles?
    Hey everyone I’ve always come to Audizine for my A4 needs and need some advice. I just recent changed my timing belt on B7 A4 with 54k miles. Do you guys think it was over kill or rather be safe than sorry? I am going to keep the car to well over 100k Miles so might as well get it done?
    Thanks again!
    https://youtu.be/tXoBKex3Ehc
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Getting a timing belt done before it snaps is always a good idea. And damn that car is new still at that mileage.
    Sent from my SM-G925T using Audizine mobile app
    Ivan
    Aug 04 2015
    Kansas City
    Preventive maintenance is never a bad idea. I changed my timing belt two years ago at 57,000 miles due to the fact that the belt was nearly ten years old rather than the mileage.
    Jun 23 2015
    Michigan
    Not overkill. Timing belt isn't just about mileage. It's also about age. An 8-10 year old belt should be replaced regardless of the mileage.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    I should do mine soon. My car is exactly 10 years old. 2008 model but final assembly date is July 2007....and I just hit 66666 mile!
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Senior Member Two Rings WewannaB7's Avatar
    Dec 07 2014
    Porsche Boxster, M-Benz ML350
    New Jersey
    What mileage are you supposed to do them at according to Audi? My 08 is at 44k miles. APR Stage 1 tuned since around 18k miles.
    08 2.0T Quattro SE, APR Stage 1 - 93 Oct
    Senior Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by WewannaB7 View Post
    110K. nothing here about time.
    A4 B7 2.0T | HPFP upgrade + FMIC | BSR Stage II + exhaust + HFC | RS4 fuel contr., PRV + S3 inj. + DW300c | GFB DV+| 034 RSB + all arms and mounts | S4 brakes | B12 Bilstein suspension + H&R springs | RNS-E + Polk Audio PA D5000.5 - 4 x DB6502 + db840DVC sub + Pioneer 10" sub | LEDs throughout | 19" Audi 2015 RS4 rims
    May 20 2017
    New Hampshire
    Quote Originally Posted by KJack View Post
    This.
    This also works the other way too. I drove 130,000 miles in 2 years without changing the T-belt. I changed it at 150k and 3 years of age. This was a CPO 2012 Jetta TDI I bought with 9,000 miles so every service was done with me as the owner or I wouldn’t have stretched the belt service that long. It’s a balance of mileage and age. Short trips over a long period of time is way worse for a car than longer trips more frequently.
    My current Audi had a belt change at 80k by the PO and I did it myself at 160k.
    Having said all that, the proper time to do a T belt is any time you have to ask yourself, “Should I do a T belt?”😀
    May 20 2017
    New Hampshire
    Quote Originally Posted by Okedokey View Post
    The 2006 service interval chart says at 110K at the bottom. So does the chart you linked. It’s at the very bottom.
    Active Member One Ring bwdysart's Avatar
    Sep 05 2017
    Richmond VA
    I’ve got an 06 at about 57,000 miles, should I be considering replacement? I want to do it myself is it terribly difficult? My parents keep telling me I’m not a mechanic lol
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by EvolutionArmory View Post
    huh?
    May 20 2017
    New Hampshire
    huh?
    You said the link you posted says nothing about time. I assumed you meant timing belt. It does say that the interval is 110K at the bottom.
    Oct 09 2007
    Miele S7
    He meant interval as in miles, not time/duration according to the set list. But I wouldn't wait that long since I hardly drive the thing. In my case by the time I reach 110K miles, it'd be another ten years (already 10 years now). Don't know about anyone else but 20 years for a timing belt replacement is a definite no no for me.
    Aug 04 2015
    Kansas City
    I think it was a misunderstanding. By “time” I think they were referring to length of time that passes before the belt should be replaced. E.g. 7 years, etc.
    May 20 2017
    New Hampshire
    Got it. Wasn’t thinking. If he had said age I would have understood immediately. My mistake.
    I would absolutely consider age of a belt when thinking of replacing one. Timing belts dry out and crack like any other belt.
    Jun 27 2011
    Items for Sale
    Yea the service schedule doesn't have time constraints but realistically, 10 years is the max I would trust an original belt, regardless of mileage. Rubber ages and oxidizes and loses strength over time, just like anything else.
    OP, I also changed my timing belt at 54k, but it was because I was doing a cam replacement and wanted the extra peace of mind of having that be done and not having to deal with it for (likely) the lifetime I would own the car. Did I need to do it? No. But I did it just to get it out of the way and I already had all the components off anyway, it added maybe 15 minutes to the weekend long job so it was a no-brainer.
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant) - Bosch FR6KPP332S plugs - Q5 Rear Aero Wiper
    2012 Q5 2.0t - Stock Mommy Missile
    Former USP CLUB MEMBER #136
    May 20 2017
    New Hampshire
    It’s like when you see a grandpa driving a brand new looking 1997 Ford Taurus. The car is mint looking with 20,000 miles but his tires are all dry rotted with 80% tread life left and his power sterering squeaks like hell 😀
    I think 10 years is a little long regardless of mileage. 5 years regardless of low mileage would be my comfort zone. Location has a lot to do with it too. If you live in sunny California and have tame winters, 10 might be doable. Not in New England though.
    May 20 2017
    New Hampshire
    And the majority of broken belts come from the teeth breaking, not the actual belt snapping which is why visual inspections from the top are almost useless.
    Oct 09 2007
    Miele S7
    It also depends on the climate or if the car has been persistently cared for and garaged throughout its whole life. Like a wild animal, it lives (or lasts) longer in captivity.
    Senior Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    I recently did an engine swap for a 2.0 that had the belt snap at 139,000 miles. So there’s your peak service interval lol
    Dec 07 2014
    New Jersey
    Quote Originally Posted by b7_Andy View Post
    I like that interval. :)
    May 05 2014
    Adelaide Australia
    Strange that in Australia the recommended interval for the timing belt on the 2.0T is 7 years or 105,000 kilometres (65k miles)
    Oct 23 2015
    +Peter-more often lately
    NSW,Australia
    Quote Originally Posted by Jet08 View Post
    Maybe the perception is that we the shit out of our cars over here...lol
    I'm certainly keeping my end up as I like giving Wolfie a thrashing when the mood strikes me
    Guten tag-Wolfgang's my name,I'm an Audi A4 B7 Q S-line with 6M in handsome avus silver complemented with Alzor 349's/Mich PS riding on Vogtland/Hypercoils,APR1 tune,USP cat/obx dp,034 bar/sd mounts,ceramic tint but hoping for more..
    Other Ride-Can't tell you my name because I'm pure stealth- Ford FG Turbo ​Ute in winter white (google me) tuned to 400hp,tuned ZF6HP26 trans,suspension and subtle aesthetic enhancements.Wolfie and I have never raced but I know who'd win !
    Jun 17 2013
    jersey city nj
    Items for Sale
    Quote Originally Posted by Ringsby4 View Post
    Maybe because its hot as over there in the land of down under ..............
    APR KO4, APR HPFP,RS4 LPFP Cntr,145 bar PRV, APR TP, TT DP, GFB DV+, AWE FMIC, BFI CC, AWE Exhaust, RS4 Exh tips, ST CO, 034 RSB,034 St Dnsty Mtr Mts, New Sth West Bst guage, B7 RS4 8 pot Calipers.Stop Tech slotted rotors.Goodridge SS brake lines frt & rr. Hawk HPS frt & rr. RS4 PS rack, RS4 Servotronic Relay,RS4 rims. S4 mirror caps,RS4 Mesh Style Grill,LED tail lites
    Veteran Member Three Rings cheemn's Avatar
    Jan 21 2010
    Woodstock, NY USA
    Not to hijack this thread but my car is at 42K miles and is a 2007 2.0T on its original belt. It has been garaged its whole life in a temperature controlled environment. Heck this car hardly ever sees salt let alone any harsh weather. So you guys think I should bite the bullet and go for a timing belt change also? My only issue is I am no good at wrenching something this difficult and I have either a dealer or a high priced Audi specialist in my area. I guess the price you pay for living out in the sticks.
    Feb 21 2017
    Cleveland
    Quote Originally Posted by dalmation53 View Post
    Thanks! Ya I try to keep it in really good shape!
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by cheemn View Post
    Ill change it for you you can pay my 1 day hotel stay and $600
    Ivan
    Jan 21 2010
    Woodstock, NY USA
    Lol I thought people flee south this time of the year and not north. Gotta research parts etc first before i make any decision anyways. You guys are awesome though. Thanks for the offer Ivan.
    Nabeel
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Nabeel
    Haha my offer was serious i wasn't kidding. A shop will charge maybe like $1200. I'm ok with a 2 star hotel haha
    Ivan
    Jan 21 2010
    Woodstock, NY USA
    I know you were serious. Hence you are AWESOME! Still gotta do my homework on things first.
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Sure i understand pm me if anything.
    Ivan
    May 20 2017
    New Hampshire
    I would change it. A 10 year old belt is asking for trouble.
    Veteran Member Four Rings RAudiB7A4's Avatar
    Nov 08 2010
    2015 Hyundai Santa Fe Sport AWD
    Rochester/MN/Mid West
    Definitely change it. Not worth the risk. I'm on my 3rd timing belt already @145k miles.
    DTM B7 A4_APR STG II+_RS4 & S4 Pards_S4 Recaros_S4 Peelers_Etc....
    --Build Thread Link
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by RAudiB7A4 View Post
    Damn thats motivation right here.
    Ivan
    Oct 09 2007
    Miele S7
    Aug 15 2017
    Centralia, Wa
    I thought I remember Audi changing the recommended service interval to 90k. In any event, we generally go no more than 75k or 80k. If you've never done one, a timing belt service will take most of the day on a 2.0t. Might as well do a fuel pump cam follower while you're in there, and change any worn hoses.
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by vandal View Post
    95K is the OE manufacturer's upper recommended change interval. (Gates IIRC)
    Established Member Four Rings Theiceman's Avatar
    Feb 15 2016
    Cambridge Ontario
    yeah 10 years is pushing it regardless of mileage . Not sure about the 2.0T but on my old A6 and even on my 944 from years ago it was usually the tensioners and rollers that went or the water pump bearing and took out the belt and everything with it. Poor belt always gets the blame though.
    2014 Nissan Murano
    2006 A4 2.0TQ 6spd
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jun 27 2011
    Items for Sale
    Audi revised the timing belt interval for the 1.8t down to 90k or something. But the 2.0t is 110k. They did some tricky things in the 2.0t like making the crank sprocket elliptical to counteract tension on the belt and reduce stress peaks on it. And they went from a failure prone hydraulic tensioner to a more simple and reliable spring loaded tensioner. Clever little things like that let them raise the interval while using pretty much the same components.
    But I’d still say 90k miles or 10 years is the upper limit I would be consider pushing it in my personal car.
    -CP
    Established Member Three Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    The shop I go to also suggested 10 years as another cap on its life; I had mine done at ~76k last year on an 07. Peace of mind is also worth quite a bit imo
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
