Results 1 to 30 of 30
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Halogen to Bi-xenon headlights question.
    Hey guys so i read phils diy on the retrofit but i'm a little confussed. I have halogens and will get my xenons tomorrow on the mail yay haha very happy. So it looks like i need a connector to plug into the xenons. Also the yellow wire running through the gromet is for high beam enable. I don't care about that at the moment is that necessary to run my low beams? I know i have to code then via vag-com i have access to it so all i need is the connector and plug and play?
    Ivan
    Active Member Two Rings DeciduousAudi's Avatar
    Oct 06 2012
    maryland
    Yes you need the adapter harness. You're new xenon housings will have a different connector
    Sent from my SM-G950U using Audizine mobile app
    Established Member Three Rings wjg22's Avatar
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Not sure what would happen if you didn't connect the yellow high beam wires, but the kufatec harnesses come with the wire already attached so why not just hook it up
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Is not that i don't want to hook it up is that is in berlin germany and it takes 2 weeks to get here so that means i can't drive at night. Anybody know where i can get a connector here in the U.S
    Sent from my SM-G925T using Audizine mobile app
    Ivan
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Yeah the xenon's won't fit with the stock halogen connector without the kufatec, iirc. You checked eBay I assume?
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by wjg22 View Post
    Yes i did check ebay but they all in berlin. The problem is the time frame since i get out of work at 6 is already dark. Ill explain to the cop i'm getting a connector from Germany lol only will be driving with fogs..damn
    Ivan
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Can't you leave your halogens installed until you get the harness? That's what I did, and used the downtime to install clear corners, chrome bulbs and Joey mod
    Senior Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    Buy it from tuning fanatics and mine arrived much quicker than they stated.
    https://www.ebay.com/itm/Xenon-Headl...QAAOSwNSxVMMpk
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Its a part out. I'm giving the guy my halogens plus $100 cash lol so it's a mf steal.
    Ivan
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    I can't make this work correct?
    Ivan
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Ivan
    Senior Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Perth, WA
    Get a wiring diagram and make your own in a few hours.
    A4 B7 2.0T | HPFP upgrade + FMIC | BSR Stage II + exhaust + HFC | RS4 fuel contr., PRV + S3 inj. + DW300c | GFB DV+| 034 RSB + all arms and mounts | S4 brakes | B12 Bilstein suspension + H&R springs | RNS-E + Polk Audio PA D5000.5 - 4 x DB6502 + db840DVC sub + Pioneer 10" sub | LEDs throughout | 19" Audi 2015 RS4 rims
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by Okedokey View Post
    Dude I'm mechanically inclined but when it comes to electrical i'm a dumb ass. did you see my link above for $13? is that what you were referring too?
    Ivan
    Oct 24 2015
    Perth, WA
    yeah man, its pretty simple. If you get that stuff ill help ya.
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    So just get this and you can help me?
    https://www.ebay.com/itm/OEM-HID-Xen...696?rmvSB=true
    Ivan
    Mar 05 2014
    phoenix/az/usa
    I suppose that's possible if you're gonna repin your connector. But I'm sure you'll still need to purchase a separate wire to Run into the cabin for the high beam. Seems a lot of extra work when there's that simple adapter already repinned and spliced for wherever the high beam wire needs to go between the two adapters plus into the cabin. Plus if you out halogens back now you have to repin all over again.
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by onedumslack View Post
    I Don't care about high beams at the moment i can always do that at a later day. all i care about at the moment is having my low beams function.
    Ivan
    Oct 24 2015
    Perth, WA
    yep
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    yep
    Right on man. Ok so i already bought it. Well see when it gets here. Also one more question can i run aftermaket hid kit with my new xenons? I like my 6000k better then 4300k on xenons. I know i need a D1S bulbs instead of H7.
    Ivan
    Oct 24 2015
    Perth, WA
    You can run whatever you want as long as you have the hardware to support it. Wiring looms is just that, wires.
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Already installed just waiting for the connector to arrive in 2 weeks or less i'm so happy about this. Btw i traded my halogens and $100 cash to a part out locally. Such a steal.
    Ivan
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Damn dude, someone just listed a harness in the classifieds today
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Ahhhh fuck really? I can always cancel it i just bought it 2 hours ago hasn't shipped yet.
    Ivan
    Veteran Member Three Rings QuattriumMT6's Avatar
    Aug 24 2013
    1991 Toyota Mr2 Turbo
    Stockton, CA
    ^ yup looks like Vic just listed one for sale. Reputable seller and forum Member.
    http://www.audizine.com/forum/showth...arness-adapter
    Edit: nvm looks like you already reached out to him 👍🏾
    2008 A4 2.0TQ | S-Line | 6MT | Brilliant Black | Ti | JHM | APR | 034 | H&R | Bilstein | Magnaflow | AWE | Apikol | Relak | Cupra | Ziza | DTM | RS6 Grille DIY | CC'd
    1991 MR2 Turbo | Berk Technology | JDM Ceramic CT20b | Works VS-XX | BC Racing | H&R | Pegasus | Twosrus | CRW | Euro Kouki Taillights
    ~Marc
    Jun 15 2011
    2008 audi A4 06 Mini cooper S "Torro"
    cville,VA
    I didn't think that a bi-xenon car can run halogen lamps?
    08 ibis white A4 quattro 6 mt s-line l APR stage 2 l HPFP fuel pump upgrade l RAI downpipe with high flow cat l custom quad exhaust with S4 valance l ECS snub l ECS ultimate catch can l 034 RSB with adjustable end links l 18Z with EBC yellow pads l ss brake lines all around l B6 S4 aluminum mirrors l tint l Vfiz l Carbonio l GFB l bunch of audio stuff l VMR v710 19x8.5 l Lightwerks retro HID headlights l ECS LED tail lights l S4 Recaro l other things I am forgetting l
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by QuattriumMT6 View Post
    Yup my order was shipped anyways. I don't mind waiting oh well. Thanks for the heads up brotha.
    Ivan
    Aug 24 2013
    Stockton, CA
    No worries 😉 and GL 🤞
    ~Marc
    Senior Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Quote Originally Posted by dalmation53 View Post
    Any info on the local part out? Iím sure other fellow AZ members could use a steal...
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by james12lucy View Post
    It's in florida city palm bay.
    Ivan
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    I sent you a pm idk if you saw it already?
    Ivan
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
