Results 1 to 24 of 24
    Established Member Two Rings Cbotello's Avatar
    Apr 29 2014
    Bellingham wa
    Changed oil pump and still low oil pressure
    My oil pressure light turned on a few days ago so I installed oil pressure gauge and at idle with the car up to temperature it would read about 10psi and on occasions it would drop to 6-7.. I replaced the oil pump along with the pick up tube and I still have low oil pressure same as before.. the old pump and pick up tube had no sludge at all but I decided to swap in the new one anyways just in case?! What should I be looking for?
    Aug 19 2010
    nyc
    What’s the specs on the car? Year?
    Model?
    Motor?
    Mileage?
    Modifications?
    Maintenance?
    Sent from my iPhone 4.11
    Apr 29 2014
    Bellingham wa
    2000 a4 atw 1.8t engine has about 170k no mods really regular oil changes every 3kmiles with 5w30 synthetic
    Aug 19 2010
    nyc
    Worn engine bearings. (Rod/main)
    Worn pressure relief valve
    Dirty/clogged filter
    Leak between pickup and pump
    Leak or worn surface through oil passages(excessive clearances somewhere allowing flow but not pressure)
    Worn oil pickup or return o-rings
    Worn valve guides
    Worn valve stem seals
    Aug 19 2010
    nyc
    Do you burn or leak oil at all?
    Apr 29 2014
    Bellingham wa
    No doesn't burn or leak oil
    Apr 29 2014
    Bellingham wa
    Motor doesn't make any weird ticking or knocking either
    Aug 19 2010
    nyc
    Not saying this IS your issue... I had a customer car that suddenly had poor oil pressure, wound up being pressure relief valve stuck , #4 in following picture
    Aug 19 2010
    nyc
    Apr 29 2014
    Bellingham wa
    Is there a way I could test it ?
    Aug 19 2010
    nyc
    This thread has a TON OF VALUABLE INFORMATION I’ve spent a few hours reading through it on various occasions. This is my best help. direction——>>
    http://www.audizine.com/forum/showth...leshooting-DIY
    Apr 29 2014
    Bellingham wa
    Thank you so much I really appreciate it.. will update when I find a cure for her
    Apr 29 2014
    Bellingham wa
    If I simply disconnect the pcv system from the block will that rule out bad oil pressure due to pcv if it makes no difference?
    Aug 19 2010
    nyc
    In theory you would only need to undo oil cap while doing oil pressure test, rather than fooling with pcv which is easily broken, but I suppose it could be disconnected
    Apr 29 2014
    Bellingham wa
    Also Im running Mobil 1 5w30 synthetic could that be my issue
    Apr 29 2014
    Bellingham wa
    I took off the oil cap multiple times with the car on and it made no difference to the oil pressure
    Aug 19 2010
    nyc
    What is the air temp where you live? What’s the oil temp?
    Have you done any recent work?
    Cam seal?
    Timing tensioner seal?
    Valve cover gasket?
    That enabled debris to collect in your passages?
    Have you checked/changed oil filter(possible bad filter pressure relief spring ) not to be confused with the oil filter housing/oil pump pressure relief valve in 1st pic #4
    Have you taken out the spring/piston/ pressure relief apart (#4)
    I would look at filter, debris, pressure relief, and then move on to compression/leakdown/invasive testing...
    Jan 21 2008
    Tucson
    ATW uses 058 (AEB) block; some of the links refer to the 06A (AWM) block. There are major differences between the two, in terms of lubrication system.
    Apr 29 2014
    Bellingham wa
    Air temp is getting down to like low 30s-50 degrees. After driving for a while the oil temp will get up to I believe 200-220 degrees. I haven't done an work on it recently besides oil change and plugs
    Jun 30 2008
    Erie, Pennsylvania
    I'm assuming the 10psi reading is at idle.
    What are your oil pressure readings at other engine speeds with oil at 200F+? How about cold?
    If you can fill in these charts that might give a better idea of what is going on:
    Cold Start
    Idle ----- - *
    1500 RPM - *
    2000 RPM - *
    3000 RPM - *
    4000 RPM - *
    5000 RPM - *
    Oil at 200F+
    Idle ----- - 10psi
    1500 RPM - *
    2000 RPM - *
    3000 RPM - *
    4000 RPM - *
    5000 RPM - *
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear, 18" RS4 Reps
    "You need to know what you are doing...Its like a rainbow jungle in there." - Redline380
    Apr 29 2014
    Bellingham wa
    Cold. Hot
    Idle 70psi 7-10psi
    1500 rpm 92psi. 25psi
    2000 100psi. 38psi
    3000 100psi. 64psi
    4000 108psi. 82psi
    5000 112psi. 85psi
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    2001.5 1.8T black, 1973 MG midget 2008 GSX650F, 1993 SC SOLD :( , 2016 Jeep GC
    Bmore ish
    Quote Originally Posted by Cbotello View Post
    I Don't think this is the problem but I would say go 5w40 next change with your miles being that high.
    Apr 29 2014
    Bellingham wa
    Any ideas
    Aug 19 2010
    nyc
    My $.02 in no order:
    Faulty oil filter ( it does happen)
    Faulty pressure relief valve
    Faulty/dirt spring/plunger asmbly
    Dirty/faulty anti-drain back parts
    if the car were in my garage I’d be draining the oil, removing the filter-filter housing- and cleaning everything with parts cleaner or diesel and inspecting the springs and seals in the filter housing unit
    Then I’d reassemble it with a Mann oil filter and 5w40 and retest.
    Here’s another possible helping hand
    http://forums.vwvortex.com/#/topics/6979988?page=1
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
